I was looking for this for 2 hours and after posting I found a solution by chance after 5 min.
I will leave this with my solution if someone have the same problem later.
this page show how it is done in python: https://www.freecodecamp.org/news/how-to-substring-a-string-in-python/
now I started trying to find any function in UIflow that could replicate this and...
"bytearray in list xxx get sub-list from # to #" actually writes this code!
That is because the PIR sensor is a port B device (black connection and by default is assigned to PortB, however, when you select the Unit In Uiflow2, you have the option to change the port.
I just tried to record a simple .wav file via the built in microphone on my core2 with the M5Go Bottom2 using the blocky 'record to file' block. I am using UI flow 1.12.2 on my core2 and yes it does record and I can play the .wav file back but even at max volume of 6 the sound is very faint.
I am surprised that none of the 109 viewers proposed the proper way of doing. Or maybe the PaHub is not their concern ?
Anyway and for future beginners who could face the issue.
1)There is no need to add the PaHUB as a component as with the other I2C captor
2) These captors must then be declared as PaHUB and not as port A
Thanks for the answer. So what I thought to be a last chance solution becomes the rule. In the videos and tutorials I have been through so far, this question has never been raised. One is told how to download a program to the device starting from scratch but never how to download program number 2..
This is not an Uiflow specific solution. Try as following:
Decide how many steps you want from start color to end color. e.g. 10 steps
find the step size from start to end color e.g. you want from value 100 to 200 (difference / steps) = step size 10.
loop for the number of steps and increase/decrease the value with the calculated step size.
@ebksuper
Hi bro, I'm having the same problem. That's why I am here and noticed that you are having the same problem.
After a few hours of trying, I finally got the data I wanted. I would like to share my solution here. Maybe it will help you, or not, either way, it's worth a try.
POST example
My project is to monitor power , security , humidity , temperature and water leaks at a remote business premises . Thats part 1
Part 2 is to push actions over MQQT based on reports .
Will be using a Stick C plus for sensing and Core 2 at home plus Andoid app for real time alert.
