Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • Does uiFLow allows http post with password?
    kurikoK
    @digiajay UiFlow 2.0 currently have no authentic support for http
  • Where does M5Burner store Wifi name and password?
    1k Views
  • IR Remote for Line counter
  • UIFlow web IDE error after using timer: "Upload code failed"
    12
    7k Views
    ajb2k3A
    @mb UIFlow Web predates WEB USB. You need to use UIFLOW2 for WEB USB
  • Issues with Pahub - Some I2C units work, others don't
    1 Votes
    1k Views
    felmueF
    Hello @BJHSartorius first of all for your setup there is no need for a PaHub as all four I2C units have different I2C addresses and therefore all four units can be connected in parallel using these. You can read about I2C here. I2C addresses of your four units: NCIR: 0x5A; Weight I2C: 0x26; Tof4m: 0x29; ENV III: 0x44/0x70 That said, I don't know why there is an issue when ToF4m is added. However, I do know why there is an issue with PaHub and ENV III. They both share the same I2C address (0x70). In other words PaHub and ENV III can never be used on the same I2C bus unless you manually (soldering required) change the I2C address of the PaHub; see here. Thanks Felix
  • Rotate text with UIflow 2.0
    6
    4k Views
    A
    [image: 1729477903998-%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88-2024-10-21-11.30.49.jpg] Hi, There. I found something. Like this screenshot, put "mpy code block" to create text labels after rotation block. It works.
  • Image+ problem
    7
    6k Views
    ajb2k3A
    @stanislav-drca I use the image Editor G.I.M.P from gimp.org. as to the image formatting. the setting are on the forum somewhere.
  • Error Request failed. Check the network and try again!
    12
    2 Votes
    7k Views
    S
    Started with UIFlow 2.0/M5Paper today and just when I got things to work, I got network error. Unable to transfer program using USB also... or the USB seems to work but the program transferred is an old version... Restarted my PC end lost quite a bit but still "Check network..."...
  • MQTT message to JSON issues
    T
    I solved it. See below: [image: 1727478984737-solution.png] First step was removing the b' at the beginning and ' at the end Then convert that to JSON with "loads json" block The "loads json" for the individual elements are redundant and you just pull straight from the json variable
  • Uploading custom blocks (m5b files) to UiFlow 2.0
    1 Votes
    R
    How to convert M5B to M5B2?
  • Learn UIFflow 2.0
    4k Views
    K
    @ajb2k3 I like your videos and guides. I've seen and learned before. From now on, I would recommend it to my friends. thanks
  • 0 Votes
    4k Views
    R
    Hi @teastain . I don’t know how to program in C++, that’s why I have fun with the Uiflow blocks. I am very grateful for your intention to help me and I will try to test the code, although modifying it will be my problem. Thanks
  • My m5stick c plus2 is not recognized in Windows 10 via USB Type C
    S
    @robski everything is fine now
  • UIflow 1.0 Run looks perfect, download everything scrambled
    3k Views
    G
    Found a solution, so this is now closed. The fix for me was enabling wifi at the start of my code, I knew I needed wifi for the RTC functions but assumed it wouldn't affect positioning of objects, but it did. I added a check loop to make sure wifi is connected before proceeding. [image: 1723874010227-screenshot-2024-08-17-075257.png]
  • UIFlow Down?
    6
    1 Votes
    5k Views
    T
    Hi all, it's working again for me (London, UK)
  • Local e Global Variables in UiFlow 2.0
    F
    @teastain I have a function that is executed in successive iterations and needs to have local variables. On Arduino it's very easy to create local variables that work within the function. In UiFlowin i see that it's not possible. thanks anyway.
  • This topic is deleted!
  • cardputer stuck on develop
    24
    23k Views
    E
    @ROLF_STEINER M5Stack documented this for each device. "Press G0 while booting...." or similar. Yes, I had problems too.
  • Data Logging using UiFlow for model rockets?
    1k Views
  • Accurate timesource / loop execution time?
    1k Views
