  • 0 Votes
    5k Views
    A
  • how do i get to the bottom save bar?
    5k Views
    ajb2k3A
    Check your web browser and OS screen settings
  • Custom blocks with a variable input
    6k Views
    S
    Hello, In case you don't have an answer here is an example of custom block I made for Parsing Text. It will ask for 3 inputs (via variables) and then return a result to a variable [image: 1644545337737-020d3478-9387-4d1f-82d9-f3af909e87b0-image.png] Don't forget to use the ${} to reference your "Variables" when creating the formulas. It also reminds you when in the block creater. [image: 1644545553311-f6364133-289d-4d73-a3f0-970d1279bd9d-image.png] This is what it looks like in UIFLOW. Note the 1st three are inputs and "DataResults" is the output. In my UIFLOW example DataParse and DataResults are UIFLOW variables not the same as the Custom Block variables [image: 1644545423986-5569aa80-88c6-4c0e-9803-3c0b28dd4fd0-image.png]
  • Tip and a minor Bug
    7k Views
    N
    @m5stack The link was in the Flow UI. The User Manual Button under the Create and Open file buttons. [image: 1631207605553-a81b87d5-280f-4917-9126-89214e32ad3c-image-resized.png]
  • Editing Custom Blocks Problem
    11k Views
    T
    @gaviota I confirm that I found the problem you described also on the on-line version 1.7.0 of UIFlow. Thanks to your trick (click on each block again in Black-Maker will fix the proper rendering once imported into UIFlow) I was able to rescue.
  • [solved]The download button disappears from the screen (Block Editor)
    7k Views
    P
    @world101 Thank you for the fast answer, "strg - works" :)
  • [solved] No name appears in the self-created block.
    5k Views
  • Opening and Editing Custom Blocks
    9
    20k Views
    C
    Thank you! I'm continually impressed with your rate of development!
  • Grove - GSR Sensor and UiFlow
    8k Views
    D
    thank you. It is indeed not an I2C but analog (stupid of me) I removed the double post
  • How does one use Block Maker?
    9k Views
    D
    Thanks! Yeah, one can't scroll down to it: You have to have a display that is big enough (or a resolution high enough) to see it.
  • Questions on Block Maker
    8k Views
