Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • No RGB LED unit for UIFLOW 2.0?
    6
    4k Views
    felmueF
    Hi guys have you tried the RGB module in Hardware? Works fine for me. I created an example using an M5Atom to control 10 SK6812 RGB LEDs. You can find it in the UIFlow2 Project Zone: M5Atom_RGB_Test_UiFlow2.3.3 Thanks Felix
  • UIFlow TAB5 text scaling
    4k Views
    S
    I did a check and set scaling to 1 and the display is properly shown i.e. as 9:59 etc
  • UIFlow digital input interrupt
    13
    26k Views
    A
    @bozho did you have any luck. It is clear on Uiflow1 how to detect rising inputs but I don't see this on Uiflow2...or is this is actually what is meant by the 'button press' block on the 'pin button' hardware module?
  • Inconsistent UI behavior for mouse wheel
    1k Views
  • Tab5 Power up sequence
    8
    6k Views
    S
    You would need to strap the board to do this. I created a board and getting it made at JLCPCB. The CANPwr board is quite expensive, reasonably enough, it is electrically isolated.
  • Tensile test machine?
    Y
    @killernils Your project is feasible with UIflow2 (MicroPython). Here's the breakdown: Hardware Compatibility: CoreS3 (SKU:K128) supports both Unit Weight-I2C and Module13.2 Stepmotor Driver v1.1 (SKU:M039-V11) via I2C Stepper driver provides precise control with microstepping (FULL to 1/32 step) and step counting Weight unit offers calibration, tare function, and filter settings through UIflow2 blocks Required Functions Implementation: Load Cell Calibration: Use WEIGHT_I2CUnit.set_calibration() with known weights Tare Function: Implement via WEIGHT_I2CUnit.set_reset_offset() Stepper Control: Utilize StepMotorDriverModule methods for direction, microstepping, and PWM frequency control Position Tracking: Count steps using motor control commands and convert to displacement based on T8x4 rod (4mm per revolution) Data Logging: Use UIflow2's file system blocks to save CSV data to internal storage HMI Interface: Create buttons and plots using CoreS3's display blocks Implementation Considerations: Ensure proper power supply (9-24V) for the stepper driver Implement step delay logic for smooth motor movement Add error handling for load cell over-range conditions Use filter functions on weight readings for stable measurements https://chat.m5stack.com/
  • Can't get m5Dial to display an image loaded via UIFlow2
    1k Views
  • This topic is deleted!
  • SyntaxError: invalid syntaxError
    3k Views
    kurikoK
    @zism5 post your code will be more helpful
  • Need help with Activating looping functions in UiFLow
    kurikoK
    @icarus121 great job!
  • 3 things kind of odd in UIFlow2
    1 Votes
    4k Views
    P
    UIFlow2 can feel odd due to inconsistent block behavior, limited error feedback, and occasional cloud sync issues, making it tricky for users to debug and manage projects efficiently.
  • Connect connect via API KEY?
    7
    7k Views
    H
    The green icon likely means the device connected to flow.m5stack.com successfully, but the API key connection might need extra steps. First, ensure you entered the API key correctly in UIFlow Web. Also, check if your firewall or network settings block the device from appearing in Fritzbox. For logs, try enabling debug mode in the M5Stack settings or use serial output to inspect connection details. Sometimes, the device uses a separate network interface that Fritzbox might not show. Double-check your Wi-Fi credentials and restart both device and router.
  • uiflow audio playback
  • Problem with button input during loop. (interupt loop)
    4k Views
    P
    To interrupt a loop using a button input, ensure the program continuously checks the button state within the loop. If the loop doesn't monitor inputs regularly, it may miss the button press. Use flags or conditions triggered by the button to break or exit the loop immediately when pressed.
  • M5Burner cannot publish BIN file due to DBus error
    5k Views
    P
    The M5Burner DBus error when publishing a BIN file usually indicates a permissions or communication issue between the app and system services. To fix it, try running M5Burner as administrator (or with sudo on Linux), ensure DBus is properly installed, and check USB device access permissions on your system.
  • Cardputer Mic 🎤
    1 Votes
  • M5Fire and UART
    7
    2 Votes
    7k Views
    B
    @felmue I was struggling to figure out why my FIRE was restarting each time I tried to use the UART port... Using Port B worked though. Thanks for the suggestion! [image: 1743470766797-screenshot-2025-03-31-at-21.25.56.png]
  • Help
    1 Votes
    B
    @I_am_Exiled When I get situations lie that I just use M5 Burner to erase and start over
  • Problem with Lists over ESP-now in Blocky
    1 Votes
    3k Views
    B
    @nabstar Did you ever find a solution for this? I’m having a similar problem
  • 0 Votes
    3k Views
    B
    Hi Liquidbeam, I know it has been a long time since you posted this, and I am curious if you ever got it to work. While I have worked with M5Stack (Blockly) for years. I know I can help you with the other aspects of your desired application and am more than willing to assist. This however is my first experience with BLE device scanning. I copied your code into my CoreS3 with UIFLOW2 V2.2.4, and I can't even replicate what you have done. I would very much appreciate an update on your experience. Thank you Bruce Kusens
