Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • UIFlow 2.0 TCP Client example
    felmueF
    Hello @gabrielgc75 check out the example in the Project Zone: M5Dial_TCP_Client_Example_UIFlow2.0.8 It sends "hello" to a public echo server after clicking button A and receives the string back. Thanks Felix
  • Label disappears
    7
    4k Views
    C
    Now that things seem to work: is there a really pressing reason to migrate to UIFlow2.0? My ultimate goal is to eventually start running openHASP on them and remotely control what they display through Home Assistant, so ideally I do no extra coding, but maybe there's a security concern or something that should change my mind?
  • This topic is deleted!
  • UIFLOW Device not Connected
    7
    13k Views
    K
    @michaelxy said in UIFLOW Device not Connected: Its also not possible to use FlowUI without a Internet-Connection? Yeah, Its not possible to use FlowUI without a Internet-Connection
  • Core2 Uiflow download getting nowhere
    1k Views
    ajb2k3A
    @soren_jepsen sounds like a server issue.
  • M5 Card Computer NOT respond
    1k Views
    ajb2k3A
    @qatar20-22 you didn’t erase the cardputer before burning firmware
  • TVOC in UIFLow 2.0
    1k Views
  • Nesting of multiple PAhubs
    11
    6k Views
    U
    hi @felmue Yes, thank you! Manual adding of the Init pahub_0 block has solved this.
  • UiFlow 2.0 Graphics
    11
    7k Views
    Y
    Got it figured out! Added an Image and the Lines began to appear. Thanks to everyone who tried to help.
  • How use Bluetooth?Help please!
    3k Views
    P
    @Hedio90 Hi, Check out these links(only reference) https://community.appinventor.mit.edu/t/ble-and-esp32-just-a-new-test-example-send-and-receive-in-uart-service/112677 https://www.youtube.com/watch?v=E495XIsM1PI
  • UIFlow and BLE in Central Mode
    P
    @whotopia Hi, ESP32 microcontroller supports both BLE and Wi-Fi simultaneously. The ESP32 chip has dedicated hardware for both BLE and Wi-Fi, allowing them to operate independently and concurrently. This means you can run BLE and Wi-Fi tasks concurrently without one interfering with the other. Now M5Fire device with UIFlow only supports BLE Uart profile, not HID profile
  • Set Accel range for built in M5StickC IMU?
    P
    @Haavarnv Hi, The next firmware version (1.13.5) will include this feature
  • How can I display a £ symbol on the LCD
    W
    The problem here is that none of the default fonts have the full font set, nor are Unicode compliant. However, on UIFlow 1.13, and in my case the Fire board, I have a font "Unicode 24". This one actually supports the pound symbol just fine. [image: 1714585178101-screenshot-2024-05-01-at-19.38.39.png] I suggest best if you are trying to make a UI to import a separate PNG for the GBP symbol and place it where needed. Cheers
  • Sorry, but new firmware breaks my projects... Again...
    17
    1 Votes
    14k Views
    B
    @felmue , I just spent a bit of time struggling to get any firmware to load onto either Dial that I have, but I finally got the --hotfix firmware loaded, and I can confirm that the GPS now works again! Thank you M5Stack for taking the time to resolve!
  • 8encoder+cardputer
    1 Votes
  • M5Dial GPS UART
    5k Views
    felmueF
    Hello @BrianR glad to hear you got it working. And thank you for reporting back. Thanks Felix
  • Where can I find examples of using UART module in UIFlow?
    25
    26k Views
    Z
    Thanks Felix! I will study your new example.
