Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • Interrupts?
    Moved
    10k Views
    H
    flow.m5stack.com, buttonA, B, C has been implemented using interrupts, or try: from m5stack import m5button button = m5button.register(_BUTTON_PIN) [image: 1553909251570-074bc216-f4e2-4c8a-a9c3-b66a9e4d9064-image.png]
  • 0 Votes
    7k Views
    T
    @ajb2k3 The app starts after reboot M5 Fire, but the code is triggered in the exception block and displays message "Got Error!".
  • UIFlow questions: modules, docs, restart
    6k Views
    T
    Thank you very much for your reply!
  • QR Code and remote connectivity without internet connection
    6k Views
    m5-docsM
    @hyperion We have developped the offline coding software just now. https://m5stack.com/download [image: 1553139010098-%E5%BE%AE%E4%BF%A1%E6%88%AA%E5%9B%BE_20190321112756-resized.png]
  • UIFlow Firmware Installer (Version 1.2.2)
    3k Views
  • UiFlow interface suggestions
    14k Views
    J
    I have a few more suggestions. It would be great to be able to add comments in uiflow. Microbit has this option and it's very helpful. [image: 50056519-397f4200-0155-11e9-95dc-580ef81c7df6.gif] It would be great to be able to double click on the canvas and type, at which point a list of the common blocks with that typed letter would be listed and able to be selected for use. This would allow the user to more quickly access the blocks required and to stay in the flow - no pun intended. Here is an example in grasshopper. [image: 94c19e3f69bc5ba312a88f658e417193a8bf985f.jpg]
  • UI-Flow的版本升级说明在哪可以看到?
    Moved
    5k Views
    m5-docsM
    @wobotyuan 我去问下攻城狮
  • uiflow USB mode
    6k Views
    lukasmaximusL
    Thanks for notifying us, and apologies for the inconvenience
  • 有没有什么办法能显示中文utf-8的字符?
    Moved
    5k Views
    m5-docsM
    uiflow 的UI界面还不支持中文显示的label
  • 在python代码编辑区,代码不能保存
    Moved
    6
    10k Views
    m5-docsM
    @wobotyuan 以后会有这个功能
  • UIFlow 1.2.0 Now available.
    5k Views
    ajb2k3A
    @world101 Yeh I wish there was a release notes. A few bug fixes have been done and the colour sensor is now added.
  • Would you like to play a game?
    5k Views
    ajb2k3A
    @watson huh?
  • BTC Base
    Moved
    6k Views
    m5-docsM
    @gadjet Sorry, UIFlow does not support the DHT12 which's built in BTC.
  • MQTT UIFlow problems
    Moved
    19
    41k Views
    world101W
    @the_stacker said in MQTT UIFlow problems: Thanks! That worked. Just out of curiosity: What's the difference between the two? Run is just for quick testing of your program. It is erased on a reboot. Download will add the program to the flash storage on the device so you can access it from the APP.LIST menu (middle button when the M5stack is booting up - inbeteeen upload and setup).
  • Interesting image generated in UIFlow
    5k Views
    ajb2k3A
    @lukasmaximus said in Interesting image generated in UIFlow: pictures or it didn't happen :p Pictures are there!
  • MQTT working ....mostly
    Moved
    6k Views
  • Problems with the Labels
    Moved
    16
    32k Views
    G
    @world101 It's in the "Graphic" group ![LCD.Print]([image: LCDprint.jpg?dl=1])
  • Where is firmware 1.1.2?
    Moved
    10k Views
    world101W
    make sure you refresh the page a few times or clear your browser cache/cookies. it was there when I updated my firmware this morning (about 5 hours ago). i'm using v1.1.2 now.
  • M5Stack UIFlow Reboots in Setup [Fixed]
    Moved
    6
    12k Views
    ajb2k3A
    Nice Work.
  • UIFlow : connect with multiple AP's
    Moved
    8k Views
    lukasmaximusL
    @kurthofman Whenever you boot up the device and select setup > change wifi connect and setup a new wifi connection it will be added to a list on the same page as the change wifi connect menu
