I am delighted with my new MQ Unit with the MQ-5 sensor, but would really like to see more sensor units, particularly the MQ-7 which measures Carbon Monoxide levels.
Best posts made by Boomvalt
MQ Unit - additional sensors
Latest posts made by Boomvalt
Example YAML code for PowerHub missing.
The link to the PowerHub esphome code returns a 404.
Is there another source for the code? -
TAB5 Demo RTC setting bug
I burned the TAB5 official demo today, January 3, and wanted to set the RTC.
2026 is not listed in the 'year' list.
After setting at 40 seconds to midnight, 2025, it forced the year date to 2026, but year list still had no choice of 2026, only 2025. -
RE: PaHub v2.1 Doesn't recognise ENV III Unit
@felmue Finally got it working correctly. In addition to your code, I initialised the Pahub, and then changed the dip switch to 0x71. Additional units work fine when assigned to 0x71.
Thanks for the help! -
@felmue I followed the instructions, and am getting this result"
File "<stdin>", line 21, in <module>
File "<stdin>", line 15, in setup
File "unit/env.py", line 41, in init
File "driver/qmp6988.py", line 99, in init
File "unit/pahub.py", line 100, in readfrom_mem
File "unit/pahub.py", line 37, in select_channel
OSError: [Errno 19] ENODEVHere is the relevant code
Having difficulty with getting my ENV III Unit recognised. Setup below:
UIFlow2.0 AtomS3R v2.2.8
PaHub v2.1 - DIP switches on factory setting.
ENVIII UnitThe ENV III works fine without the hub. but will not work in any assigned port, whether on it's own, or with other units.
Other I2C units work as expected. Only the ENV III has this problem.
All channels tried.Has anyone else had this happen?
Thanks in advance for any help. -
RE: Strange program running in after installing UIflow2 on factory set new AtomS3 Lite
@ajb2k3 There was no previous firmware that I installed. This was an out-of-the-box installation. I downloaded the latest update - I think 2.2.7 - and that's when the problem occurred.
Also, when I went to press burn, there was no opportunity to erase before burning. -
Moved from General
Experienced a strange event while using my ATOM S3 Lite for the first time.
MacOS
M5Burner was already running when I attached the device.
Downloaded the latest uiflow2 dated 29-05-2025
Configured, and started burn, which ran quickly, without the usual bind request.
Started a new project.
Connected, but was unable to Run or Load.
Process running in terminal installed itself as something suggesting a BT Beacon, and established
a WiFi AP on a 192.168.4.1 IP. It also appeared to be transferring data.Unfortunately I don't have a copy of the output.
I restarted M5 Burner, and a new update from the same date was available. Burning this version solved the problem.
Does anyone know what happened here?
RE: EZ Data dissapered from UIflow2
@ajb2k3 The point of EZData is that it stores data in a cloud, making it accessible from anywhere in the world. Also, you can set up an mqtt server on a €30 Pi Nano, a NAS, or pretty much any other computer with a network connection.
