Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • MQTT
    Moved
    26
    114k Views
    ajb2k3A
    @dvd78 I think..... If you just power it on it should autoload the program.
  • How to use the Buzzer in M5Stick
    Moved m5stick buzzer
    11k Views
    ajb2k3A
    @an-erd said in How to use the Buzzer in M5Stick: I tried to use the buzzer on M5Stick. In UIFlow I used Advanced > PIN > digital write pin 26 to 1, but you don't hear the buzzer. You can feel that M5Stick "tries" to do it. So what did I wrong? I expected to have a buffer as in a mobile phone to at least feel if vibrating or to hear a beep? You don't do that in UIflow, you use speaker.tone(1600, 200) or speaker.sing(220, 1) from m5stack import * from m5ui import * clear_bg(0x111111) speaker.tone(1600, 200) speaker.sing(220, 1) or the Speaker beep and play tone blocks in the blocky mode.
  • [Solved]uiflow new FW(v1.1.0) can't writting.
    Moved
    10k Views
    world101W
    @heybin While you are at it, please update the entire zip file for the Mac version of the M5Burner. What is linked in flow.m5stack.com today only goes up to v1.0.1. I need v1.1.0 please. http://flow.m5stack.com/download/M5Burner_MacOS.zip
  • uiflow 1.1 mqtt
    Moved
    11k Views
    ajb2k3A
    @watson Yes, I need to understand MQTT to work out part of my book but I'm just not understanding it.
  • Neopixel Experiments in uiflow
    Moved
    9
    13k Views
    ajb2k3A
    @watson said in Neopixel Experiments in uiflow: @ajb2k3 How about your neopixel breathing project? That's the base layer code but it only lights the Pixels in a predefined sequence. Need to find a way to randomize the sequence instead of hard-coding the pattern.
  • UIFlow : standalone
    Moved
    6k Views
    H
    sorry, currently it is not possible because of security issues.
  • M5Stick's mini and UIFlow
    Moved
    10
    20k Views
    H
    hello, lcd.print() is not support in m5stick uiflow
  • python back to blocks not working
    Moved
    13k Views
    m5-docsM
    @360fashion Hello, it's normal. UIFlow likes Blockly(designed by Google) and MakeCode(designed by MicroBit and Microsoft) You need to save it
  • What does this mean?
    Moved
    8k Views
    H
    hello,if wifi connect fail will appear thoese msg, Btn retry mean you can press btn to retry connect wifi, long press btn mean press long time(2 sec) can go to wifi setup, change wifi connect
