  • [RULES] Please READ before posting here!
    Pinned Locked
    5 Votes
    12k Views
  • Cardputer ADV Section in M5 Burner
    2 Votes
  • CardPuter clamshell edition!
    2 Votes
    H
    Yes! Full size😍 But also keep the small screen. Cardputer X!
  • PSRAM upgrade for the CardputerADV
    3 Votes
    3k Views
    E
    I hope M5Stack comes up with some kind of Stamp S3B which can be inserted right into the Cardputer ADV without the need to upgrade the Cardputer itself. Or someone else could maybe make a Stamp S3 clone that has PSRAM? Would love to see that.
  • Stamp-S3Bat HAT2 Bus
    1 Votes
    R
    In addition, the following screen snippet shows two possible suggestions how the 2x9@2.54mm pins can be assigned. [image: 1774182873732-efd89c09-1cce-4886-8c79-39b9ed5a4d05-image.png]
  • M5Burner for Raspberry Pi 500+
    1 Votes
  • Prototype board for AtomS3R-Ext
    1 Votes
    R
    the following is a screen snippet of this board: [image: 1773945187568-257aff04-e4f1-494f-bec9-7aa804edaf32-image.png]
  • Industrial Analog pH Meter
  • MOSFET unit
    6
    9 Votes
    6k Views
    L
    @teastain can you please share the scheme how to built a MOSFET inside a M5Stack Proto Unit. Thanks
  • Atom with ESP-H2
    2 Votes
  • Tough with larger screen
    tough screen size
    2 Votes
  • [Product] Round shaped Core Controller
  • 0 Votes
  • [MQTT-Core] Support for RETAIN
    8
    5 Votes
    16k Views
    felmueF
    Hello @magister in the mean time you could try and copy the correct Python statement into an Execute mpy code block. You can find it under System. Thanks Felix
  • Core2 Ink Display
    1 Votes
  • Spare parts
  • MQ Unit - additional sensors
    1 Votes
  • Option to compile the UIFlow2 code
    5k Views
    B
    @ajb2k3 I'm not so sure. It is a fairly large request, and probably needs funding. It needs to be initiated by the suppliers, only then it will be directed to the micropython writers.
  • Code acceleration options
    1 Votes
    1k Views
  • [New Firmware]StamPLC internal firmware support OTA update
