    M5stack basic core battery power on issue (ip5306 strange power management)
    Cores
    6
    28
    137.1k
    • arzamanA
      arzaman @liushasha
      @liushasha no problem...I had an old schema and did not check the note you add to the new one. Your documentation level is quite good and indeed If there is a problem I see there is quite good support on the forum and community ... in a way or another I get the info :-)
      most important that now I have more understanding of power management and the fact I can control battery via SW is very important (M5stack is perfect for portable applications battery pwered)
      could be VERY USEFUL a sort of translation of IP5306 Chinese data sheet
      there are few register that provide info but not able to unerstand the usage !!
      from various source I undertand that
      0x78 provides battery level (25/50/75/100)
      0x71 battery charging level (but not sure)
      what about the other registers ? what about control register ??
      simple table with register and functions/value will help a lot "non Chinese" speaking people
      hope to see soon in the documentation !
      thanks
      Davide
      m5-docsM arzamanA 2 Replies Last reply Reply Quote 0
      • m5-docsM
        m5-docs @arzaman
        @arzaman Thanks. Your seriousness really touched me.
        M5Stack documentation URL
        https://docs.m5stack.com
        • arzamanA
          arzaman @arzaman
          I got also documentation for power management
          https://docs.m5stack.com/#/en/api/power?id=getbatterylevel
          clear and comprehnesive
          all ok issue "solved"
          Davide
          • ajb2k3A
            ajb2k3 @arzaman
            @arzaman said in M5stack basic core battery power on issue (ip5306 strange power management):
            Davide
            If you are getting an understanding of the power management of the IP5306, would you mind helping me write it up for my book please?
            You will be credited for the information in the book.
            • ajb2k3A
              ajb2k3
              As an addendum to this, the IP5306 is available from LCSC
              https://lcsc.com/product-detail/PMIC-Battery-Management_IP5306_C181692.html
              • C
                ckuehnel
                Here is a working code example:
                • Test of IP5306 functions
                #include <M5Stack.h>
                void setup()
                // initialize the M5Stack object
                M5.begin();
                Wire.begin(); // required to access IP5306
                M5.Lcd.fillScreen(BLACK);
                M5.Lcd.setCursor(0, 10);
                M5.Lcd.setTextColor(WHITE);
                M5.Lcd.setTextSize(2);
                M5.Lcd.printf("IP5306 Function Test\r\n");
                if(!M5.Power.canControl())
                M5.Lcd.setTextColor(RED);
                M5.Lcd.printf("No communication with IP5306 chip");
                while(1);
                void loop()
                M5.Lcd.fillRect(0,180,360,60,0);
                uint8_t bat = M5.Power.getBatteryLevel();
                M5.Lcd.setCursor(0,180);
                if (M5.Power.isCharging()) M5.Lcd.printf("Battery is charging\r\n");
                else M5.Lcd.printf("Battery is not charging\r\n");
                M5.Lcd.printf("Battery Level %d", bat);
                M5.Lcd.progressBar(0, 220, 360, 20, bat);
                delay(5000);
                ajb2k3A C 2 Replies Last reply Reply Quote 1
                • ajb2k3A
                  ajb2k3 @ckuehnel
                  @ckuehnel Thanks friend.
                  • C
                    cepics @ckuehnel
                    @ckuehnel said in M5stack basic core battery power on issue (ip5306 strange power management):
                    void setup()
                    M5.begin();
                    while(1);
                    void loop()
                    delay(5000);
                    Hi, doesn't compile for me!!!
                    this is the arduino IDE output:
                    Arduino: 1.8.7 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
                    Build options changed, rebuilding all
                    /Users/AD/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp: In member function 'void POWER::powerOFF()':
                    /Users/AD/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp:361:28: error: 'gpio_deep_sleep_hold_dis' was not declared in this scope
                       gpio_deep_sleep_hold_dis();
                    Multiple libraries were found for "SPI.h"
                     Used: /Users/AD/Documents/Arduino/hardware/espressif/esp32/libraries/SPI
                     Not used: /Users/AD/Documents/Arduino/libraries/SPI
                    Multiple libraries were found for "SD.h"
                     Used: /Users/AD/Documents/Arduino/hardware/espressif/esp32/libraries/SD
                     Not used: /Users/AD/Documents/Arduino/libraries/SD
                     Not used: /private/var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/AppTranslocation/395E70C5-F1F6-4076-AA11-9C132A2C6ACF/d/Arduino 1.8.7.app/Contents/Java/libraries/SD
                    exit status 1
                    Error compiling for board M5Stack-Core-ESP32.
                    This report would have more information with
                    "Show verbose output during compilation"
                    option enabled in File -> Preferences.
                    tnks
