    M5stack basic core battery power on issue (ip5306 strange power management)
    28 Posts 6 Posters 148.8k Views 1 Watching
    • m5-docsM Offline
      m5-docs @arzaman
      Hello @arzaman, In order to confirm that if the IP5306 is IIC version on all CORE you have. It's better to download the following testing code.
      https://github.com/m5stack/M5Stack/tree/master/examples/Advanced/I2C_Tester
      M5Stack documentation URL
      https://docs.m5stack.com
      arzamanA 1 Reply Last reply Reply Quote 0
      • arzamanA Offline
        arzaman @liushasha
        @liushasha said in M5stack basic core battery power on issue (ip5306 strange power management):
        This schematic is wrong, every core is used i2c ip5306.
        Really ? I don't know if this is a good or a very bad news...
        having IP5306 with I2C and enable SW control of power management is nice but knowing that the official schematic where I have based the design of my custom HW and development of SW is not the real one really puzzle me !
        this is the official schema on github
        https://github.com/m5stack/M5-Schematic/blob/master/Core/Basic/M5-Core-Schematic(20171206).pdf
        Is there an updated one ? are there other differences ??
        I know that M5Stack is not "open source" but without a real schema quite difficult to mange any HW/FW development
        Davide
        • arzamanA Offline
          arzaman @m5-docs
          @m5-docs Thanks for the suggestion... and you are right my core has I2C version of IP5306 ! Sorry if I miss it
          The bus scan found the IP5306 at address 0x75
          I upload a simple sketch to monito battery level and it works
          this is good but still don't solve my problem
          -if I power m5 core with USB all ok
          -if I disconnect USB using core bottom battery the core stays on and I can do reset with power on again
          -if I power off (double click) no change to power on again
          anything now that I can modify in IP5306 register to fix the power on ?
          Davide
          • m5-docsM Offline
            m5-docs @arzaman
            @arzaman Really sorry about that. I do not clearly know your problem.
            "-if I disconnect USB using core bottom battery the core stays on and I can do reset with power on again
            -if I power off (double click) no change to power on again"
            • L Offline
              liushasha @arzaman
              @arzaman I apologize for the misleading on schematics, it is surely our mistake, we didn't well organize all of the material. We are working on it, will have better material come out soon.
              • arzamanA Offline
                arzaman @m5-docs
                @m5-docs I think we can conclude that is and "HW failure of IP5306" no big issue I can use this core for the lab or for application with no battery
                maybe if you can send me a replacement or tell me where to buy the I2C version of IP5306 I can try to replace by myself
                thanks for the support anyway
                • m5-docsM Offline
                  m5-docs @arzaman
                  @arzaman The IP5306 which is iic version is customized. The best way for you is to ask saler for a replacement or ask our saler for a new core or iic version IP5306. Sorry for the inconvenience !
                  • arzamanA Offline
                    arzaman @liushasha
                    @liushasha no problem...I had an old schema and did not check the note you add to the new one. Your documentation level is quite good and indeed If there is a problem I see there is quite good support on the forum and community ... in a way or another I get the info :-)
                    most important that now I have more understanding of power management and the fact I can control battery via SW is very important (M5stack is perfect for portable applications battery pwered)
                    could be VERY USEFUL a sort of translation of IP5306 Chinese data sheet
                    there are few register that provide info but not able to unerstand the usage !!
                    from various source I undertand that
                    0x78 provides battery level (25/50/75/100)
                    0x71 battery charging level (but not sure)
                    what about the other registers ? what about control register ??
                    simple table with register and functions/value will help a lot "non Chinese" speaking people
                    hope to see soon in the documentation !
                    thanks
                    Davide
                    m5-docsM arzamanA 2 Replies Last reply Reply Quote 0
                    • m5-docsM Offline
                      m5-docs @arzaman
                      @arzaman Thanks. Your seriousness really touched me.
                      • arzamanA Offline
                        arzaman @arzaman
                        I got also documentation for power management
                        https://docs.m5stack.com/#/en/api/power?id=getbatterylevel
                        clear and comprehnesive
                        all ok issue "solved"
                        Davide
                          ajb2k3 @arzaman
                          @arzaman said in M5stack basic core battery power on issue (ip5306 strange power management):
                          Davide
                          If you are getting an understanding of the power management of the IP5306, would you mind helping me write it up for my book please?
                          You will be credited for the information in the book.
                            As an addendum to this, the IP5306 is available from LCSC
                            https://lcsc.com/product-detail/PMIC-Battery-Management_IP5306_C181692.html
                              ckuehnel
                              Here is a working code example:
                              • Test of IP5306 functions
                              #include <M5Stack.h>
                              void setup()
                              // initialize the M5Stack object
                              Wire.begin(); // required to access IP5306
                              M5.Lcd.fillScreen(BLACK);
                              M5.Lcd.setCursor(0, 10);
                              M5.Lcd.setTextColor(WHITE);
                              M5.Lcd.setTextSize(2);
                              M5.Lcd.printf("IP5306 Function Test\r\n");
                              if(!M5.Power.canControl())
                              M5.Lcd.setTextColor(RED);
                              M5.Lcd.printf("No communication with IP5306 chip");
                              while(1);
                              void loop()
                              M5.Lcd.fillRect(0,180,360,60,0);
                              uint8_t bat = M5.Power.getBatteryLevel();
                              M5.Lcd.setCursor(0,180);
                              if (M5.Power.isCharging()) M5.Lcd.printf("Battery is charging\r\n");
                              else M5.Lcd.printf("Battery is not charging\r\n");
                              M5.Lcd.printf("Battery Level %d", bat);
                              M5.Lcd.progressBar(0, 220, 360, 20, bat);
                              delay(5000);
                              ajb2k3A C 2 Replies Last reply Reply Quote 1
                                ajb2k3 @ckuehnel
                                @ckuehnel Thanks friend.
                                  cepics @ckuehnel
                                  @ckuehnel said in M5stack basic core battery power on issue (ip5306 strange power management):
                                  void setup()
                                  while(1);
                                  void loop()
                                  delay(5000);
                                  Hi, doesn't compile for me!!!
                                  this is the arduino IDE output:
                                  Arduino: 1.8.7 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
                                  Build options changed, rebuilding all
                                  /Users/AD/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp: In member function 'void POWER::powerOFF()':
                                  /Users/AD/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp:361:28: error: 'gpio_deep_sleep_hold_dis' was not declared in this scope
                                     gpio_deep_sleep_hold_dis();
                                  Multiple libraries were found for "SPI.h"
                                   Used: /Users/AD/Documents/Arduino/hardware/espressif/esp32/libraries/SPI
                                   Not used: /Users/AD/Documents/Arduino/libraries/SPI
                                   Used: /Users/AD/Documents/Arduino/hardware/espressif/esp32/libraries/SD
                                   Not used: /Users/AD/Documents/Arduino/libraries/SD
                                   Not used: /private/var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/AppTranslocation/395E70C5-F1F6-4076-AA11-9C132A2C6ACF/d/Arduino 1.8.7.app/Contents/Java/libraries/SD
                                  exit status 1
                                  tnks
