    [M5Paper] UiFlow support
    Features Wish List
    12
    33
    91.6k
    • J
      Jank
      Any information on when the support for M5paper is coming to the official VS code extension for micropython? I can set my device to usb mode but it doesn't find it.
      • ajb2k3A
        ajb2k3 @doubleness
        @doubleness said in [M5Paper] UiFlow support:
        @world101 @ajb2k3
        Thank you guys it works! You saved me :) ... finally I can switch to micropython, programming using arduino IDE was kind of slow and painful
        Like having teeth pulled!
        No worries, glad to help.
        • TitiMobyT
          TitiMoby
          That's very nice to be able to use UIFlow with M5Paper, thanks. 🥰
          This also open the door to micropython.
          I tried it and it works in UIflow.
          Now, I'm trying to figure out how to add libraries.
          With M5 core, I use either thonny or rshell.
          But I could not connect to M5Paper with those.
          The only tool that worked was Mu editor, but only to see the REPL. Could not access files.
          Is there a trick to upload files on M5Paper?
          • TitiMobyT
            TitiMoby
            Does anyone have ideas to put MicroPython libraries on the M5Paper?
            • ajb2k3A
              ajb2k3 @TitiMoby
              @titimoby said in [M5Paper] UiFlow support:
              Yes, there is a trick but alas i forget the trick and struggle to upload.
              I'm using thonny and its hit and miss accessing the paper.
              • TitiMobyT
                TitiMoby
                So no stable solution for now, that’s sad.
                It’s a bit frustrating to have some micropython working but not the full experience.
                At some point, that could be better to switch to hardware that runs CircuitPython, less struggle.
                • ajb2k3A
                  ajb2k3
                  OK, I got it.
                  To use Thonny or other micropython IDE's with the M5Paper, you need to put the paper into "App Mode" in the menu as UIFlow and USB mode do not allow access to REPL.
                  • TitiMobyT
                    TitiMoby
                    As this is not my first M5 board, I think I was in App mode. But as the main source of errors is often between the chair and the keyboard, I'll focus my attention on this point 😉
                    • ajb2k3A
                      ajb2k3 @TitiMoby
                      I'm writing a book on the coreink and m5paper and spent a week trying to work it out!
                      now if i could only get the internal sht30 to work
                      Z 1 Reply Last reply Reply Quote 0
                      • Z
                        zappawaddawadda @ajb2k3
                        @ajb2k3 would love info on your M5 books
                        • ajb2k3A
                          ajb2k3 @zappawaddawadda
                          @zappawaddawadda Look me up on Github as I post stuff there, I haven't updated the E-Ink docks in ages due to Core2 AWS and massive software dev issues on OSX.
                          UIFlow 2.0 is coming next year so expect an update.
                          R 1 Reply Last reply Reply Quote 0
                          • R
                            romor001 @ajb2k3
                            UIFlow 2.0 is available now and m5paper is supported, but I fail to find the built in SHT30 sensor. This sensor was supported in blockly in UIFlow 1.
                            Any suggestions on how to solve getting temperature and humidity measurements from the SHT30 sensor in UIFlow 2.0?
                            • felmueF
                              felmue @romor001
                              Hello @romor001
                              please check out my example in the UIFlow2 Project Zone: M5Paper_Read_Intern_Temp_Humid_UIFlow2.0.9
                              Thanks
                              Felix
                              Code examples
