๐Ÿค–Have you ever tried Chat.M5Stack.com before asking??๐Ÿ˜Ž
    [M5Paper] UiFlow support
    Scheduled Pinned Locked Moved Features Wish List
    33 Posts 12 Posters 103.6k Views 6 Watching
    • TitiMobyT Offline
      TitiMoby
      That's very nice to be able to use UIFlow with M5Paper, thanks. ๐Ÿฅฐ
      This also open the door to micropython.
      I tried it and it works in UIflow.
      Now, I'm trying to figure out how to add libraries.
      With M5 core, I use either thonny or rshell.
      But I could not connect to M5Paper with those.
      The only tool that worked was Mu editor, but only to see the REPL. Could not access files.
      Is there a trick to upload files on M5Paper?
      • TitiMobyT Offline
        TitiMoby
        Does anyone have ideas to put MicroPython libraries on the M5Paper?
          ajb2k3 @TitiMoby
          @titimoby said in [M5Paper] UiFlow support:
          Yes, there is a trick but alas i forget the trick and struggle to upload.
          I'm using thonny and its hit and miss accessing the paper.
          • TitiMobyT Offline
            TitiMoby
            So no stable solution for now, thatโ€™s sad.
            Itโ€™s a bit frustrating to have some micropython working but not the full experience.
            At some point, that could be better to switch to hardware that runs CircuitPython, less struggle.
              OK, I got it.
              To use Thonny or other micropython IDE's with the M5Paper, you need to put the paper into "App Mode" in the menu as UIFlow and USB mode do not allow access to REPL.
              • TitiMobyT Offline
                TitiMoby
                As this is not my first M5 board, I think I was in App mode. But as the main source of errors is often between the chair and the keyboard, I'll focus my attention on this point ๐Ÿ˜‰
                  ajb2k3 @TitiMoby
                  I'm writing a book on the coreink and m5paper and spent a week trying to work it out!
                  now if i could only get the internal sht30 to work
                  Z 1 Reply Last reply Reply Quote 0
                  • Z Offline
                    zappawaddawadda @ajb2k3
                    @ajb2k3 would love info on your M5 books
                      ajb2k3 @zappawaddawadda
                      @zappawaddawadda Look me up on Github as I post stuff there, I haven't updated the E-Ink docks in ages due to Core2 AWS and massive software dev issues on OSX.
                      UIFlow 2.0 is coming next year so expect an update.
                        romor001 @ajb2k3
                        UIFlow 2.0 is available now and m5paper is supported, but I fail to find the built in SHT30 sensor. This sensor was supported in blockly in UIFlow 1.
                        Any suggestions on how to solve getting temperature and humidity measurements from the SHT30 sensor in UIFlow 2.0?
                          felmue @romor001
                          Hello @romor001
                          please check out my example in the UIFlow2 Project Zone: M5Paper_Read_Intern_Temp_Humid_UIFlow2.0.9
                          With your input, this post could be even better ๐Ÿ’—
