    [M5Paper] UiFlow support
    Scheduled Pinned Locked Moved Features Wish List
    33 Posts 12 Posters 106.2k Views 6 Watching
      doubleness
      @felmue Hey, are you able to run the code on your device? Not sure what I am doing wrong, I burned UiFlow alpha version, and connected to my device, also it seems like code is being uploaded to m5paper device, and screen refreshes probably restarting, but nothing shows up in the screen.
      Everytime I try to upload the code I get warning ' Lack block "Set screen set show" or "Set screen parital show" '
      Not sure what I am doing wrong, any idea?
      world101W ajb2k3A 2 Replies Last reply Reply Quote 0
      • world101W Offline
        world101 @doubleness
        @doubleness said in [M5Paper] UiFlow support:
        You need to have one of those blocks in your program to update the screen. They are under UI, then Screen in uiFlow.
          ajb2k3 @doubleness
          You need to have the "Set Screen Show" block as the information is only stored in memory and not drawn to the screen until set screen show or set screen partial show is called.
            doubleness
            @world101 @ajb2k3
            Thank you guys it works! You saved me :) ... finally I can switch to micropython, programming using arduino IDE was kind of slow and painful
              Jank
              Any information on when the support for M5paper is coming to the official VS code extension for micropython? I can set my device to usb mode but it doesn't find it.
                ajb2k3 @doubleness
                @world101 @ajb2k3
                Like having teeth pulled!
                No worries, glad to help.
                • TitiMobyT Offline
                  TitiMoby
                  That's very nice to be able to use UIFlow with M5Paper, thanks. 🥰
                  This also open the door to micropython.
                  I tried it and it works in UIflow.
                  Now, I'm trying to figure out how to add libraries.
                  With M5 core, I use either thonny or rshell.
                  But I could not connect to M5Paper with those.
                  The only tool that worked was Mu editor, but only to see the REPL. Could not access files.
                  Is there a trick to upload files on M5Paper?
                  • TitiMobyT Offline
                    TitiMoby
                    Does anyone have ideas to put MicroPython libraries on the M5Paper?
                      ajb2k3 @TitiMoby
                      @titimoby said in [M5Paper] UiFlow support:
                      Yes, there is a trick but alas i forget the trick and struggle to upload.
                      I'm using thonny and its hit and miss accessing the paper.
                      • TitiMobyT Offline
                        TitiMoby
                        So no stable solution for now, that’s sad.
                        It’s a bit frustrating to have some micropython working but not the full experience.
                        At some point, that could be better to switch to hardware that runs CircuitPython, less struggle.
                          OK, I got it.
                          To use Thonny or other micropython IDE's with the M5Paper, you need to put the paper into "App Mode" in the menu as UIFlow and USB mode do not allow access to REPL.
                          • TitiMobyT Offline
                            TitiMoby
                            As this is not my first M5 board, I think I was in App mode. But as the main source of errors is often between the chair and the keyboard, I'll focus my attention on this point 😉
                              ajb2k3 @TitiMoby
                              I'm writing a book on the coreink and m5paper and spent a week trying to work it out!
                              now if i could only get the internal sht30 to work
                              Z 1 Reply Last reply Reply Quote 0
                              • Z Offline
                                zappawaddawadda @ajb2k3
                                @ajb2k3 would love info on your M5 books
                                  ajb2k3 @zappawaddawadda
                                  @zappawaddawadda Look me up on Github as I post stuff there, I haven't updated the E-Ink docks in ages due to Core2 AWS and massive software dev issues on OSX.
                                  UIFlow 2.0 is coming next year so expect an update.
                                    romor001 @ajb2k3
                                    UIFlow 2.0 is available now and m5paper is supported, but I fail to find the built in SHT30 sensor. This sensor was supported in blockly in UIFlow 1.
                                    Any suggestions on how to solve getting temperature and humidity measurements from the SHT30 sensor in UIFlow 2.0?
                                      felmue @romor001
                                      Hello @romor001
                                      please check out my example in the UIFlow2 Project Zone: M5Paper_Read_Intern_Temp_Humid_UIFlow2.0.9
