    M5stack basic core battery power on issue (ip5306 strange power management)
    28 Posts 6 Posters 145.8k Views 1 Watching
      The little white label I mentioned is the date stamp (2018.3)
      Mine is 2017.6 and I don't have the issue but the black component between the chip and sdcard slot above the date stamp is gray on my model.
      • arzamanA Offline
        arzaman
        Here is a video showing the problem
        when I shut down the M5stack basic core no chance to boot again
        link text
        any idea so far ?
        Davide
        • m5-docsM Offline
          m5-docs @arzaman
          @arzaman How about BASIC Core boots only with Type-C USB cable without BASIC bottom?
          M5Stack documentation URL
          https://docs.m5stack.com
          arzamanA 1 Reply Last reply Reply Quote 0
          • arzamanA Offline
            arzaman @m5-docs
            @m5-docs sorry but don't understand the question
            with USB Type C off course the M5 basic core boots regularly...the problem is with the battery power suppy either basic bottom or my custom expansion baord. If I shut down the M5 basic core with double clik and battery power no chance to restart
            Davide
            • L Offline
              liushasha
              Seems like the battery enters into protection mode after power off. Could you please try to pull out the battery in the bottom and plug in back in to restart the battery and try again.
              • arzamanA Offline
                arzaman @liushasha
                @liushasha battery has no "protection" circuit ...all is manged by IP5306
                anyway removed and reconnected the LiPo battery (or the core bottom) few times and always same behaviour
                and more over same battery on other M5stack basic core works perfeclty
                Davide
                • L Offline
                  liushasha @arzaman
                  HI, @arzaman, this IP5306 is i2c version, it can be programmed via the i2c protocol. Since the only problem is just the shutdown operation. the chance that the ic is totally broken on the hardware side is pretty rare. so could it be possible that you have accidentally modified the code? Would you please refresh the firmware by M5burner to exclude the software problem? Thanks
                  • arzamanA Offline
                    arzaman @liushasha
                    @liushasha maybe you refer to a different Core version (fire ??)
                    My M5stack BASIC core comes with IP5306 that has no I2C interface to ESP32 (should be very very useful to have and move power management to SW level)
                    here the schematic (or at lease what is public) of the power management...now SW no I2C
                    so I assume a "faulty" core (I have two in a lot of 12)
                    Davide
                    • L Offline
                      liushasha
                      This schematic is wrong, every core is used i2c ip5306.
                      • L Offline
                        liushasha
                        2 out of 12? that's pretty high rate. I thought its 1 out of ten. I from M5Stack by the way. I will help you target the problem, and handle it afterward. I apologized for the bad experience.
                        • m5-docsM Offline
                          m5-docs @arzaman
                          Hello @arzaman, In order to confirm that if the IP5306 is IIC version on all CORE you have. It's better to download the following testing code.
                          https://github.com/m5stack/M5Stack/tree/master/examples/Advanced/I2C_Tester
                          • arzamanA Offline
                            arzaman @liushasha
                            @liushasha said in M5stack basic core battery power on issue (ip5306 strange power management):
                            Really ? I don't know if this is a good or a very bad news...
                            having IP5306 with I2C and enable SW control of power management is nice but knowing that the official schematic where I have based the design of my custom HW and development of SW is not the real one really puzzle me !
                            this is the official schema on github
                            https://github.com/m5stack/M5-Schematic/blob/master/Core/Basic/M5-Core-Schematic(20171206).pdf
                            Is there an updated one ? are there other differences ??
                            I know that M5Stack is not "open source" but without a real schema quite difficult to mange any HW/FW development
                            Davide
                            • arzamanA Offline
                              arzaman @m5-docs
                              @m5-docs Thanks for the suggestion... and you are right my core has I2C version of IP5306 ! Sorry if I miss it
                              The bus scan found the IP5306 at address 0x75
                              I upload a simple sketch to monito battery level and it works
                              this is good but still don't solve my problem
                              -if I power m5 core with USB all ok
                              -if I disconnect USB using core bottom battery the core stays on and I can do reset with power on again
                              -if I power off (double click) no change to power on again
                              anything now that I can modify in IP5306 register to fix the power on ?
                              Davide
                              • m5-docsM Offline
                                m5-docs @arzaman
                                @arzaman Really sorry about that. I do not clearly know your problem.
                                "-if I disconnect USB using core bottom battery the core stays on and I can do reset with power on again
                                -if I power off (double click) no change to power on again"
                                • L Offline
                                  liushasha @arzaman
                                  @arzaman I apologize for the misleading on schematics, it is surely our mistake, we didn't well organize all of the material. We are working on it, will have better material come out soon.
                                  • arzamanA Offline
                                    arzaman @m5-docs
                                    @m5-docs I think we can conclude that is and "HW failure of IP5306" no big issue I can use this core for the lab or for application with no battery
                                    maybe if you can send me a replacement or tell me where to buy the I2C version of IP5306 I can try to replace by myself
                                    thanks for the support anyway
                                    • m5-docsM Offline
                                      m5-docs @arzaman
                                      @arzaman The IP5306 which is iic version is customized. The best way for you is to ask saler for a replacement or ask our saler for a new core or iic version IP5306. Sorry for the inconvenience !
                                      • arzamanA Offline
                                        arzaman @liushasha
                                        @liushasha no problem...I had an old schema and did not check the note you add to the new one. Your documentation level is quite good and indeed If there is a problem I see there is quite good support on the forum and community ... in a way or another I get the info :-)
                                        most important that now I have more understanding of power management and the fact I can control battery via SW is very important (M5stack is perfect for portable applications battery pwered)
                                        could be VERY USEFUL a sort of translation of IP5306 Chinese data sheet
                                        there are few register that provide info but not able to unerstand the usage !!
                                        from various source I undertand that
                                        0x78 provides battery level (25/50/75/100)
                                        0x71 battery charging level (but not sure)
                                        what about the other registers ? what about control register ??
                                        simple table with register and functions/value will help a lot "non Chinese" speaking people
                                        hope to see soon in the documentation !
                                        thanks
                                        Davide
                                        m5-docsM arzamanA 2 Replies Last reply Reply Quote 0
                                        • m5-docsM Offline
                                          m5-docs @arzaman
                                          @arzaman Thanks. Your seriousness really touched me.
                                          • arzamanA Offline
                                            arzaman @arzaman
                                            I got also documentation for power management
                                            https://docs.m5stack.com/#/en/api/power?id=getbatterylevel
                                            clear and comprehnesive
                                            all ok issue "solved"
                                            Davide
