    M5Stack - Simple Applications Menu + some APPs
    40 Posts 10 Posters 250.0k Views 6 Watching
    • JJJ Offline
      JJ
      T 2 Replies Last reply Reply Quote 0
        TomSuch @JJ
        @jimit Hi, good work. But I did not find the code on your git ...
        • JJJ Offline
          JJ @TomSuch
          @tomsuch
          Oops... sorry bout that. Have added them now....
            TomSuch @JJ
            @jimit OK, I'm going to check it out ..
              TomSuch @JJ
              @jimit Hello Jimi, I have redesigned your WiFi scanner application and there is a new version M5Stack-SAM with this APP out there.
              https://github.com/tomsuch/M5Stack-SAM
              • JJJ Offline
                JJ @TomSuch
                @tomsuch Thanks Tom... looks much better ! One thing - for me once the scan is done it lists the networks but the screen refreshes immediately before they can be read.... tested on two different M5s ? Strange if it's not happening for you too. Hate to respond with a negative when you've done such nice work. BTW, the system info page you added is great to have and the others too. Awesome work.
                  TomSuch @JJ
                  @jimit Hi Jim, I think I found and remove the bug. Can you try a new, fixed version? Thank you...
                  https://github.com/tomsuch/M5Stack-SAM/
                  • JJJ Offline
                    JJ @TomSuch
                    @tomsuch
                    Awesome... all wifi scanner functions working perfectly - thou i couldn't test the page function due to lack of networks... excellent work Tom !! Thanks for making it happen.
                      TomSuch @JJ
                      @jimit No problem Jim. Regards....
                        kaotiklabs
                        Would be awesome to have a generic menu system so you could focus only on core development.
                        I have tried to use yours for my app but had no time to fully understand it.
                        Could you write a little doc explaining how can we use it in our apps?
                        • SunWukongS Offline
                          SunWukong @TomSuch
                          @tomsuch Hi Tom, I have change the code of my Branch and like to pull it back to yours. But you have advanced your Code quick and my branch is now behind yours. So I would like to ask you to look over my code and if you like what you see, then I want to integrate it into your master.
                          The next step is, I have tried Push Button based WPS, first with a LOLIN32 and now with the M5Stack and I like to add this to your SAM in the new way I added the the appBME280.
                            TomSuch
                            @sunwukong Hi, Thank you for the subject. I will look at it.
                            For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                            http://forum.m5stack.com/topic/85/m5stacksam-application-menu-library
                              TomSuch @kaotiklabs
                              @kaotiklabs Hi, Thank you for the subject. I will look at it.
                                TomSuch @m5stack
                                @m5stack For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                                • reaper7R Offline
                                  reaper7
                                  Accu meter app (MAX17043 module soldered inside Battery Module)
                                  T JJJ 2 Replies Last reply Reply Quote 3
                                    TomSuch @reaper7
                                    @reaper7 Good work, thank you ...
                                    • JJJ Offline
                                      JJ @reaper7
                                      @reaper7
                                      Yes - nice mod & addition to the menu system Reaper7 ! Ordered the module already. Thanks.
                                        TomSuch
                                        A new version of the M5StackSAM library
                                        https://github.com/tomsuch/M5StackSAM
                                        Added features to easily create and navigate the list.
                                        (APPLICATIONS -> LIST DEMO)
                                        Added support for the FACES QWERTY keyboard.
                                        (APPLICATIONS -> FACES GET STRING)
                                        • JJJ Offline
                                          JJ @TomSuch
                                          @tomsuch Excellent thanks Tom.... look forward to trying it esp. with the new Faces keyboard support. Will try later tonight....
                                            sheepDog
                                            what version/type of wire.h do you use?
                                            I got this error at "Wire.requestFrom(0x08,1,true);":
                                            In file included from /Users/.../Documents/Arduino/libraries/M5Stack/src/M5Stack.h:92:0,
                                                             from sketch/M5StackSAM.h:1,
                                                             from sketch/M5StackSAM.cpp:1:
                                            /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h: In member function 'void M5SAM::keyboardEnable()':
                                            /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:66:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int, int)
                                                 uint8_t requestFrom(int, int, int);
                                            /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:61:12: note: candidate 2: size_t TwoWire::requestFrom(uint8_t, size_t, bool)
                                                 size_t requestFrom(uint8_t address, size_t size, bool sendStop);
                                            Can anyone help me?
