    M5Stack - Simple Applications Menu + some APPs
    40 Posts 10 Posters 250.3k Views 6 Watching
    • m5stackM Offline
      @TomSuch I got your mind, and similar to me, i really hope it like a swiss knife. useful and meaningful.
        Kryten
        I get errors on all
        [code]
        #pragma mark
        [/code]
        Will comment out and try again
          TomSuch @Kryten
          @kryten Please specify the error. Arduino version. Take PrintScreen.
          Do you have installed M5.libraries ? ESP32 libraries ?
          • reaper7R Offline
            reaper7
            @tomsuch 在 M5Stack - Simple Applications Menu + some APPs 中说:
            APP - GY-512
            very nice system!
            APP - GY-512 works also with built-in MPU9250 :)
            Can You modify TIM MEASUREMENT APP?
            S/S button should 1.START->2.STOP->3.START without reset between 2 and 3 step...(something like continous measurement with pause). For reset value we have RES button
              TomSuch @reaper7
              @reaper7 Hi, thanks for the subject. I edited the application of the stopwatch and is already out. Regards...
              • JJJ Offline
                JJ
                T 2 Replies Last reply Reply Quote 0
                  TomSuch @JJ
                  @jimit Hi, good work. But I did not find the code on your git ...
                  • JJJ Offline
                    JJ @TomSuch
                    @tomsuch
                    Oops... sorry bout that. Have added them now....
                      TomSuch @JJ
                      @jimit OK, I'm going to check it out ..
                        TomSuch @JJ
                        @jimit Hello Jimi, I have redesigned your WiFi scanner application and there is a new version M5Stack-SAM with this APP out there.
                        https://github.com/tomsuch/M5Stack-SAM
                        • JJJ Offline
                          JJ @TomSuch
                          @tomsuch Thanks Tom... looks much better ! One thing - for me once the scan is done it lists the networks but the screen refreshes immediately before they can be read.... tested on two different M5s ? Strange if it's not happening for you too. Hate to respond with a negative when you've done such nice work. BTW, the system info page you added is great to have and the others too. Awesome work.
                            TomSuch @JJ
                            @jimit Hi Jim, I think I found and remove the bug. Can you try a new, fixed version? Thank you...
                            https://github.com/tomsuch/M5Stack-SAM/
                            • JJJ Offline
                              JJ @TomSuch
                              @tomsuch
                              Awesome... all wifi scanner functions working perfectly - thou i couldn't test the page function due to lack of networks... excellent work Tom !! Thanks for making it happen.
                                TomSuch @JJ
                                @jimit No problem Jim. Regards....
                                  kaotiklabs
                                  Would be awesome to have a generic menu system so you could focus only on core development.
                                  I have tried to use yours for my app but had no time to fully understand it.
                                  Could you write a little doc explaining how can we use it in our apps?
                                  • SunWukongS Offline
                                    SunWukong @TomSuch
                                    @tomsuch Hi Tom, I have change the code of my Branch and like to pull it back to yours. But you have advanced your Code quick and my branch is now behind yours. So I would like to ask you to look over my code and if you like what you see, then I want to integrate it into your master.
                                    The next step is, I have tried Push Button based WPS, first with a LOLIN32 and now with the M5Stack and I like to add this to your SAM in the new way I added the the appBME280.
                                      TomSuch
                                      @sunwukong Hi, Thank you for the subject. I will look at it.
                                      For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                                      http://forum.m5stack.com/topic/85/m5stacksam-application-menu-library
                                        TomSuch @kaotiklabs
                                        @kaotiklabs Hi, Thank you for the subject. I will look at it.
                                          TomSuch @m5stack
                                          @m5stack For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                                          • reaper7R Offline
                                            reaper7
                                            Accu meter app (MAX17043 module soldered inside Battery Module)
                                            T JJJ 2 Replies Last reply Reply Quote 3
