    M5Stack - Simple Applications Menu + some APPs
    40 Posts 10 Posters 246.6k Views 6 Watching
      kaotiklabs
      Would be awesome to have a generic menu system so you could focus only on core development.
      I have tried to use yours for my app but had no time to fully understand it.
      Could you write a little doc explaining how can we use it in our apps?
      • SunWukongS Offline
        SunWukong @TomSuch
        @tomsuch Hi Tom, I have change the code of my Branch and like to pull it back to yours. But you have advanced your Code quick and my branch is now behind yours. So I would like to ask you to look over my code and if you like what you see, then I want to integrate it into your master.
        The next step is, I have tried Push Button based WPS, first with a LOLIN32 and now with the M5Stack and I like to add this to your SAM in the new way I added the the appBME280.
          TomSuch
          @sunwukong Hi, Thank you for the subject. I will look at it.
          For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
          http://forum.m5stack.com/topic/85/m5stacksam-application-menu-library
            TomSuch @kaotiklabs
            @kaotiklabs Hi, Thank you for the subject. I will look at it.
              TomSuch @m5stack
              @m5stack For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
              • reaper7R Offline
                reaper7
                Accu meter app (MAX17043 module soldered inside Battery Module)
                T JJJ 2 Replies Last reply Reply Quote 3
                  TomSuch @reaper7
                  @reaper7 Good work, thank you ...
                  • JJJ Offline
                    JJ @reaper7
                    @reaper7
                    Yes - nice mod & addition to the menu system Reaper7 ! Ordered the module already. Thanks.
                      TomSuch
                      A new version of the M5StackSAM library
                      https://github.com/tomsuch/M5StackSAM
                      Added features to easily create and navigate the list.
                      (APPLICATIONS -> LIST DEMO)
                      Added support for the FACES QWERTY keyboard.
                      (APPLICATIONS -> FACES GET STRING)
                      • JJJ Offline
                        JJ @TomSuch
                        @tomsuch Excellent thanks Tom.... look forward to trying it esp. with the new Faces keyboard support. Will try later tonight....
                          sheepDog
                          what version/type of wire.h do you use?
                          I got this error at "Wire.requestFrom(0x08,1,true);":
                          In file included from /Users/.../Documents/Arduino/libraries/M5Stack/src/M5Stack.h:92:0,
                                           from sketch/M5StackSAM.h:1,
                                           from sketch/M5StackSAM.cpp:1:
                          /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h: In member function 'void M5SAM::keyboardEnable()':
                          /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:66:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int, int)
                               uint8_t requestFrom(int, int, int);
                          /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:61:12: note: candidate 2: size_t TwoWire::requestFrom(uint8_t, size_t, bool)
                               size_t requestFrom(uint8_t address, size_t size, bool sendStop);
                          Can anyone help me?
                          • W Offline
                            wschnell @SunWukong
                            @sunwukong Hey, where did you get the enclosure for the grove sensor? - I've been looking for something like this.
                            • W Offline
                              wschnell @SunWukong
                              found it - it's a Seeed Studio Wrapper
                                TheAlphaGhost
                                Hi Guys,
                                ihm new with M5Stack. I have a MCore2 and try compile this in visual code with plattform.io.
                                How i must use the code in Plattform.io ? If i compile the code, the device showing black screen.
                                Can anyone help me ?
