    M5Stack - Simple Applications Menu + some APPs
    40 Posts 10 Posters 250.1k Views 6 Watching
      TomSuch
      New version:
      Added:
      • APP - GY-512 (MPU6050) - gyro/accelerometer
      • APP - variable speed Serial PASS-THRU USB<->UART2
      • SYSTEM - System Informatins (CPU Speed, Flash Size, Flash SPEED, SDK Version .......)
      • Serial Commands - WiFiScan, I2CScan
      • m5stackM Online
        @TomSuch I got your mind, and similar to me, i really hope it like a swiss knife. useful and meaningful.
          Kryten
          I get errors on all
          [code]
          #pragma mark
          [/code]
          Will comment out and try again
            TomSuch @Kryten
            @kryten Please specify the error. Arduino version. Take PrintScreen.
            Do you have installed M5.libraries ? ESP32 libraries ?
            • reaper7R Offline
              reaper7
              @tomsuch 在 M5Stack - Simple Applications Menu + some APPs 中说:
              APP - GY-512
              very nice system!
              APP - GY-512 works also with built-in MPU9250 :)
              Can You modify TIM MEASUREMENT APP?
              S/S button should 1.START->2.STOP->3.START without reset between 2 and 3 step...(something like continous measurement with pause). For reset value we have RES button
                TomSuch @reaper7
                @reaper7 Hi, thanks for the subject. I edited the application of the stopwatch and is already out. Regards...
                • JJJ Offline
                  JJ
                  T 2 Replies Last reply Reply Quote 0
                    TomSuch @JJ
                    @jimit Hi, good work. But I did not find the code on your git ...
                    • JJJ Offline
                      JJ @TomSuch
                      @tomsuch
                      Oops... sorry bout that. Have added them now....
                        TomSuch @JJ
                        @jimit OK, I'm going to check it out ..
                          TomSuch @JJ
                          @jimit Hello Jimi, I have redesigned your WiFi scanner application and there is a new version M5Stack-SAM with this APP out there.
                          https://github.com/tomsuch/M5Stack-SAM
                          • JJJ Offline
                            JJ @TomSuch
                            @tomsuch Thanks Tom... looks much better ! One thing - for me once the scan is done it lists the networks but the screen refreshes immediately before they can be read.... tested on two different M5s ? Strange if it's not happening for you too. Hate to respond with a negative when you've done such nice work. BTW, the system info page you added is great to have and the others too. Awesome work.
                              TomSuch @JJ
                              @jimit Hi Jim, I think I found and remove the bug. Can you try a new, fixed version? Thank you...
                              https://github.com/tomsuch/M5Stack-SAM/
                              • JJJ Offline
                                JJ @TomSuch
                                @tomsuch
                                Awesome... all wifi scanner functions working perfectly - thou i couldn't test the page function due to lack of networks... excellent work Tom !! Thanks for making it happen.
                                  TomSuch @JJ
                                  @jimit No problem Jim. Regards....
                                    kaotiklabs
                                    Would be awesome to have a generic menu system so you could focus only on core development.
                                    I have tried to use yours for my app but had no time to fully understand it.
                                    Could you write a little doc explaining how can we use it in our apps?
                                    • SunWukongS Offline
                                      SunWukong @TomSuch
                                      @tomsuch Hi Tom, I have change the code of my Branch and like to pull it back to yours. But you have advanced your Code quick and my branch is now behind yours. So I would like to ask you to look over my code and if you like what you see, then I want to integrate it into your master.
                                      The next step is, I have tried Push Button based WPS, first with a LOLIN32 and now with the M5Stack and I like to add this to your SAM in the new way I added the the appBME280.
                                        TomSuch
                                        @sunwukong Hi, Thank you for the subject. I will look at it.
                                        For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                                        http://forum.m5stack.com/topic/85/m5stacksam-application-menu-library
                                          TomSuch @kaotiklabs
                                          @kaotiklabs Hi, Thank you for the subject. I will look at it.
                                            TomSuch @m5stack
                                            @m5stack For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
