    M5Stack - Simple Applications Menu + some APPs
    40 Posts 10 Posters 246.6k Views 6 Watching
    • SunWukongS Offline
      SunWukong @TomSuch
      @tomsuch Hi Tom, I have change the code of my Branch and like to pull it back to yours. But you have advanced your Code quick and my branch is now behind yours. So I would like to ask you to look over my code and if you like what you see, then I want to integrate it into your master.
      The next step is, I have tried Push Button based WPS, first with a LOLIN32 and now with the M5Stack and I like to add this to your SAM in the new way I added the the appBME280.
        TomSuch
        @sunwukong Hi, Thank you for the subject. I will look at it.
        For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
        http://forum.m5stack.com/topic/85/m5stacksam-application-menu-library
          TomSuch @kaotiklabs
          @kaotiklabs Hi, Thank you for the subject. I will look at it.
            TomSuch @m5stack
            @m5stack For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
            • reaper7R Offline
              reaper7
              Accu meter app (MAX17043 module soldered inside Battery Module)
              T JJJ 2 Replies Last reply Reply Quote 3
                TomSuch @reaper7
                @reaper7 Good work, thank you ...
                • JJJ Offline
                  JJ @reaper7
                  @reaper7
                  Yes - nice mod & addition to the menu system Reaper7 ! Ordered the module already. Thanks.
                    TomSuch
                    A new version of the M5StackSAM library
                    https://github.com/tomsuch/M5StackSAM
                    Added features to easily create and navigate the list.
                    (APPLICATIONS -> LIST DEMO)
                    Added support for the FACES QWERTY keyboard.
                    (APPLICATIONS -> FACES GET STRING)
                    • JJJ Offline
                      JJ @TomSuch
                      @tomsuch Excellent thanks Tom.... look forward to trying it esp. with the new Faces keyboard support. Will try later tonight....
                        sheepDog
                        what version/type of wire.h do you use?
                        I got this error at "Wire.requestFrom(0x08,1,true);":
                        In file included from /Users/.../Documents/Arduino/libraries/M5Stack/src/M5Stack.h:92:0,
                                         from sketch/M5StackSAM.h:1,
                                         from sketch/M5StackSAM.cpp:1:
                        /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h: In member function 'void M5SAM::keyboardEnable()':
                        /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:66:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int, int)
                             uint8_t requestFrom(int, int, int);
                        /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:61:12: note: candidate 2: size_t TwoWire::requestFrom(uint8_t, size_t, bool)
                             size_t requestFrom(uint8_t address, size_t size, bool sendStop);
                        Can anyone help me?
                        • W Offline
                          wschnell @SunWukong
                          @sunwukong Hey, where did you get the enclosure for the grove sensor? - I've been looking for something like this.
                          • W Offline
                            wschnell @SunWukong
                            found it - it's a Seeed Studio Wrapper
                              TheAlphaGhost
                              Hi Guys,
                              ihm new with M5Stack. I have a MCore2 and try compile this in visual code with plattform.io.
                              How i must use the code in Plattform.io ? If i compile the code, the device showing black screen.
                              Can anyone help me ?
