    LLM Module
    Modules
    5
    14
    4.4k
    • B
      Bipman
      Hi
      Is the LLM module to be used on it's own or can it be attached to the CoreS3 via the connectors i.e. plugged in to the S3 connector? I can't seem to find a picture of it connected to the S3 unit.
      Steve
      • kurikoK
        kuriko @Bipman
        @Bipman
        LLM can be debugged separately or plugged into any Core
        Just simply plug it in
        • B
          Bipman @kuriko
          @kuriko Thank-you. I presume it is powered separately?
          Steve
          • teastainT
            teastain @Bipman
            @Bipman It's all here, mate!
            https://docs.m5stack.com/en/module/Module-LLM
            What you are suggesting is a bit of a challenge, but do-able, I guess.
            The Cores make a nice power-and-interface though.
            • B
              Bipman @teastain
              @teastain OK, ta. For some reason it won't go into programming mode either. I've tried the 'hold button and add power' but it just goes to the green 'on' light. I've tried everything and I have added the driver first. Been through all the docs and not sure what I'm missing.
              Steve
              • teastainT
                teastain @Bipman
                @Bipman Right at the bottom of the link I sent you:
                And here:
                https://docs.m5stack.com/en/guide/llm/llm/arduino
                and
                https://github.com/m5stack/M5Module-LLM
                • B
                  Bipman @teastain
                  @teastain Sorry to be really thick but how does that help set it into programming mode? Love the signature by the way, I also have way too many units and modules!
                  Steve
                  • teastainT
                    teastain @Bipman
                    @Bipman
                    It?
                    The LLM or the CoreS3?
                    What programming language/IDE do you use?
                    I don't have an LLM, so I am offering generic M5/ESP32S3 advice!
                    • B
                      Bipman @teastain
                      @teastain Ah, OK! I have the CoreS3 with the LLM attached. It's the LLM unit I'm having issues with in that it won't go into programming mode.
                      Steve
                        ajb2k3 @Bipman
                        @Bipman I don't have one at present but I wonder how we'll it will work with the CoreMP135.
                          Snyder_br
                          Hello guys,
                          A basic question: how can I connect (plug physically) a LLM module to Core 2?
                          Thanks,
                          • teastainT
                            teastain @Snyder_br
                            @Snyder_br
                            Yes.
                            Bottom of the docs:
                              Snyder_br @teastain
                              @teastain Thanks for answer but the Pin doesn't fit. Its necessary to remove original battery (Core 2) to plug-in the LLM module? have some pictures?
                                ajb2k3 @Snyder_br
                                @Snyder_br Yes, you have to remove the bottom plate/battery to connect modules.
