Need Module with I/O for connections...
I'm having a lot of trouble finding a list of modules for the M5Stack Core2 AWS that I have, where I can make some connections for a project.
I need to make about 20 external connections for a project consisting of about 4 analog inputs, 11 digital outputs and 6 digital inputs.
Is there a module that I can add to the M5Stack that will give me access to the I/O?
What I/O is available?I've been searching and can't find the answers that I need.
Sir Michael
@SirMichael Have you looked on the M5Stack website?
@SirMichael M5Stack website Products/Sensors/ IO
@robski Yes, I have looked at the website (wasn't easy to find on the website). I was looking for a module to expose more of the GPIO pins.
I gave up on using the M5Stack for the project. I can't get access to enough pins.
Thanks though.
Sir Michael
@SirMichael They core basic has a lot of pins in the battery base, did you look at it? (about 15 GPIO)
https://docs.m5stack.com/en/core/basic_v2.7
Also you may can add the PaHub or PbHub to expand.
https://docs.m5stack.com/en/unit/pbhub -
@SirMichael Did you not see the GPIo breakout modules or units?
Did you looking the MBUS connector?
