    Need Module with I/O for connections...
    Modules
    6
    2.1k
      SirMichael
      I'm having a lot of trouble finding a list of modules for the M5Stack Core2 AWS that I have, where I can make some connections for a project.
      I need to make about 20 external connections for a project consisting of about 4 analog inputs, 11 digital outputs and 6 digital inputs.
      Is there a module that I can add to the M5Stack that will give me access to the I/O?
      What I/O is available?
      I've been searching and can't find the answers that I need.
      Sir Michael
      ajb2k3A robskiR 2 Replies Last reply Reply Quote 0
        ajb2k3 @SirMichael
        @SirMichael Have you looked on the M5Stack website?
        • robskiR
          robski @SirMichael
          @SirMichael M5Stack website Products/Sensors/ IO
            SirMichael @robski
            @robski Yes, I have looked at the website (wasn't easy to find on the website). I was looking for a module to expose more of the GPIO pins.
            I gave up on using the M5Stack for the project. I can't get access to enough pins.
            Thanks though.
            Sir Michael
            teastainT ajb2k3A 2 Replies Last reply Reply Quote 0
            • teastainT
              teastain @SirMichael
              @SirMichael They core basic has a lot of pins in the battery base, did you look at it? (about 15 GPIO)
              https://docs.m5stack.com/en/core/basic_v2.7
              Also you may can add the PaHub or PbHub to expand.
              https://docs.m5stack.com/en/unit/pbhub
                ajb2k3 @SirMichael
                @SirMichael Did you not see the GPIo breakout modules or units?
                Did you looking the MBUS connector?
