    CoreMP135 Debian image
    46 Posts 8 Posters 61.9k Views 4 Watching
      ajb2k3 @mgrouch
      @mgrouch yes but you will need to access the coreMP135 directly to find the initial IP address. I have been working on documentation but been busy since I started work on making the image compilation steps.
        mgrouch @ajb2k3
        @ajb2k3 said in CoreMP135 Debian image:
        Documentation is definitely lacking steps on
        using CAN, i2c, uart, RS-485 on coremp135
        What is Linux kernel version on Debian image?
          ajb2k3 @mgrouch
          @mgrouch bookworm
            prima @ajb2k3
            The mDNS service aka Zeroconf aka Avahi aka Bonjour is already enabled on the device, so if you have the client tools installed on your PC you can connect in SSH using the .local address like this:
            ssh root@M5Core135.local
            M5Core135 is the default hostname.
              mgrouch @teastain
              @teastain said in CoreMP135 Debian image:
              @mgrouch https://github.com/m5stack/M5Stack_Linux_Libs
              The Official M5Stack CoreMP135 library repository.
              I’d like to port my esp32 LVGL app to Linux on coremp135.
              This app:
              https://github.com/bareboat-necessities/bbn-m5stack-tough
              Are there any guides on porting?
              teastainT ajb2k3A 2 Replies Last reply Reply Quote 0
              • teastainT Offline
                teastain @mgrouch
                @mgrouch I am no expert on the CoreMP135, but it looks like it is more of a Raspberry Pi, than an Arduino or ESP32 microcontroller without WiFi or BT.
                In the link I sent you there is a LVGL demo to try.
                As to porting your cool Boat app over, it would be easy to do to another ESP32 machine like Core Basic, Core2 or CoreS3, but at some point this is not an M5Stack issue, but a LVGL issue, they may have some guidance over at their GitHub repository.
                -Terry
                  ajb2k3 @mgrouch
                  @mgrouch said in CoreMP135 Debian image:
                  This app:
                  not directly as the CoreMP135 is too new.
                  The CoreMP135 runs linux and so you will need to learn how to program on a linux based computer.
                    mgrouch @ajb2k3
                    Ok. I got the device and I loaded Debian image M5_CoreMP135_debian12_20240628 from
                    https://docs.m5stack.com/en/guide/linux/coremp135/image
                    It did boot.
                    However, upon boot it didn't resize the root partition to occupy whole SD card.
                    As a result I can't install anything because there is no space.
                    I had to use fdisk to resize /root partition (#5 for me, making sure I use same starting block and preserve filesystem type, see https://askubuntu.com/questions/24027/how-can-i-resize-an-ext-root-partition-at-runtime) and then
                    resisz2fs command (something like resize2fs /dev/mmcblk0p5).
                    It would be too hard for an average user to repeat that.
                    Also the kernel on it is very old. 5.15.118
                    On Raspberry Bookworm it is much newer. (6.x)
                    There are many errors related to USB reported by dmesg.
                    I have powered USB HUB and keyboard is connected via it.
                    Keyboard works though.
                    Is it possible for next versions to have image which would resize to SD card size?
                    Same way as Pi OS does?
                    Is it possible to have have newer linux kernel? I think USB errors might be related to old version of it.
                    M ajb2k3A 2 Replies Last reply Reply Quote 0
                      mgrouch @mgrouch
                      It did boot.
                      USB errors were my fault. I plugged usb 3.0 hub into usb 2.0 port.
                      One more question:
                      What are the tty devices names of RS-485 and UART6 under /dev?
                        ajb2k3 @mgrouch
                        @teastain here is the dev directory listing
                        M teastainT 2 Replies Last reply Reply Quote 0
                          mgrouch @ajb2k3
                          What is /dev/ttySTM2 ?
                          • teastainT Offline
                            teastain @ajb2k3
                            @ajb2k3 "But, for mine own part, it was Greek to me."
                            (Casca, Julius Caesar: Act 1, Scene 2)
                              ajb2k3 @mgrouch
                              ttySTM2
                              From what I can find, the /dev/ttystm0 2 and 3 could be UART ports
                                ajb2k3 @prima
                                @prima said in CoreMP135 Debian image:
                                I cant get a ssh login with the latest Debian release. the default password return access denied in SSH
                                ajb2k3A J 2 Replies Last reply Reply Quote 0
                                  ajb2k3 @ajb2k3
                                  Finally getting around to looking at the GPIO's on the CoreMP135.
                                  not getting far at the moment as it took all weekend to work out how to expand the OS to use the whole card then get it to install GPIOD.
                                    mgrouch @ajb2k3
                                    What were the changes between
                                    M5_CoreMP135_debian12_20240919
                                    and
                                    I can find it in github.
                                      ajb2k3 @mgrouch
                                      @mgrouch I don't have the slightest idea.
                                      I run the apt update and apt upgrade to make sure I have the latest version.
                                        JNVoirol @ajb2k3
                                        Hello, I have the same problem using latest image of the OS. When I try to login as root I got the message access denied. How did you handle this ?
                                          ajb2k3 @JNVoirol
                                          @JNVoirol I still haven't solved the ssh issue yet so still directly logging in.
