    CoreMP135 Debian image
    46 Posts 8 Posters 61.9k Views 4 Watching
      ajb2k3 @ajb2k3
      Ah ha I got it to compile, the instructions are wrong.
      You need to run
      make BR2_EXTERNAL=../CoreMP135_buildroot-external-st/ m5stack_coremp135_515_defconfig
      make -j4
      To get it to compile.
      I'm Using a CM4Stack so its slow going.
      The issue turns out to be a typo in the line. The guide says /Core135_ but the command is actually CoreMP135
        prima
        On a side note and not sure this is a related issue, but I can't seem to shut down the device cleanly. I have tried: shutdown, poweroff, halt and the device always reboots instead of shutting down.
          ajb2k3 @prima
          @prima yeh I noticed that too after issuing the Shutdown now command.
          • N Offline
            nnn @ajb2k3
            A script to build Debian image is now available in the M5Stack repository.
            • CoreMP135_buildroot-external-st
              https://github.com/m5stack/CoreMP135_buildroot-external-st/blob/st/2023.02.10/tools/creat_coremp135_debian12_image.sh
            • How to implement (Japanese)
              https://qiita.com/nnn112358/items/44921e2470353653058e
            ajb2k3A M 2 Replies Last reply Reply Quote 0
              ajb2k3 @nnn
              @nnn said in CoreMP135 Debian image:
              Nice
                mgrouch @nnn
                @nnn
                Is there Debian image for CoreMP135 which includes kernel built with all drivers for hardware interfaces of CoreMP135.
                I’m considering buying that CoreMP135 and
                I need to make sure I will be able to use CAN Bus interfaces, i2c, uart, USB, Bluetooth, RS485, Both Ethernets and WiFi, as well as
                touchscreen of CoreMP135 with the Debian image provided.
                When it boots, does it boot into some kind of framebuffer LVGL GUI on 2” touchscreen?
                Is there code example how to do that?
                Or CoreMP135 is sold as hardware platform and users are left to build own Linux kernel and Debian images to support hardware CoreMP135?
                Or there is a Debian image which fully supports
                CoreMP135 Hardware and all interfaces?
                Hardware is not much of use for me if there is no software with drivers supporting it.
                Thanks!
                P teastainT 2 Replies Last reply Reply Quote 0
                  prima @mgrouch
                  @mgrouch said in CoreMP135 Debian image:
                  AFAIK there is no wifi/BT on this device. Dual ethernet works using the available Debian image though. That image has some defects but I guess this is being sorted out.
                  You can now build your own image (see post above) but I haven't tried that yet.
                  • I have not tried the CAN bus and the other interfaces.
                  • USB: seems to work, but I only plugged in a mouse and keyboard
                  • The serial console works over USB-C and I also use the USB-C cable to power the device from my PC.
                  If that can help: I recently posted on how to develop Python apps in GTK or QT, using the frame buffer with Xorg/Openbox.
                  This is roughly the approach I have used for developing on Raspberry PI and other SBCs.
                  The touch screen work without problem for me.
                  • teastainT Offline
                    teastain @mgrouch
                    @mgrouch https://github.com/m5stack/M5Stack_Linux_Libs
                    The Official M5Stack CoreMP135 library repository.
                      mgrouch @prima
                      @prima said in CoreMP135 Debian image:
                      Ok. No wifi or bt is not an issue for me as long as Ethernet works.
                      Is it working as DHCP client? I mean it’s just plug into router and I could ssh?
                      I do care about working CAN, i2c, UART, and RS-485 out of the box with provided Debian image.
                      Does anyone have experiences with those interfaces on CoreMP135 with their provided OS image?
                        ajb2k3 @mgrouch
                        @mgrouch yes but you will need to access the coreMP135 directly to find the initial IP address. I have been working on documentation but been busy since I started work on making the image compilation steps.
                          mgrouch @ajb2k3
                          @ajb2k3 said in CoreMP135 Debian image:
                          Documentation is definitely lacking steps on
                          using CAN, i2c, uart, RS-485 on coremp135
                          What is Linux kernel version on Debian image?
                            ajb2k3 @mgrouch
                            @mgrouch bookworm
                              prima @ajb2k3
                              The mDNS service aka Zeroconf aka Avahi aka Bonjour is already enabled on the device, so if you have the client tools installed on your PC you can connect in SSH using the .local address like this:
                              ssh root@M5Core135.local
                              M5Core135 is the default hostname.
                                mgrouch @teastain
                                @teastain said in CoreMP135 Debian image:
                                I’d like to port my esp32 LVGL app to Linux on coremp135.
                                This app:
                                https://github.com/bareboat-necessities/bbn-m5stack-tough
                                Are there any guides on porting?
                                teastainT ajb2k3A 2 Replies Last reply Reply Quote 0
                                • teastainT Offline
                                  teastain @mgrouch
                                  @mgrouch I am no expert on the CoreMP135, but it looks like it is more of a Raspberry Pi, than an Arduino or ESP32 microcontroller without WiFi or BT.
                                  In the link I sent you there is a LVGL demo to try.
                                  As to porting your cool Boat app over, it would be easy to do to another ESP32 machine like Core Basic, Core2 or CoreS3, but at some point this is not an M5Stack issue, but a LVGL issue, they may have some guidance over at their GitHub repository.
                                  -Terry
                                    ajb2k3 @mgrouch
                                    This app:
                                    not directly as the CoreMP135 is too new.
                                    The CoreMP135 runs linux and so you will need to learn how to program on a linux based computer.
                                      mgrouch @ajb2k3
                                      Ok. I got the device and I loaded Debian image M5_CoreMP135_debian12_20240628 from
                                      https://docs.m5stack.com/en/guide/linux/coremp135/image
                                      It did boot.
                                      However, upon boot it didn't resize the root partition to occupy whole SD card.
                                      As a result I can't install anything because there is no space.
                                      I had to use fdisk to resize /root partition (#5 for me, making sure I use same starting block and preserve filesystem type, see https://askubuntu.com/questions/24027/how-can-i-resize-an-ext-root-partition-at-runtime) and then
                                      resisz2fs command (something like resize2fs /dev/mmcblk0p5).
                                      It would be too hard for an average user to repeat that.
                                      Also the kernel on it is very old. 5.15.118
                                      On Raspberry Bookworm it is much newer. (6.x)
                                      There are many errors related to USB reported by dmesg.
                                      I have powered USB HUB and keyboard is connected via it.
                                      Keyboard works though.
                                      Is it possible for next versions to have image which would resize to SD card size?
                                      Same way as Pi OS does?
                                      Is it possible to have have newer linux kernel? I think USB errors might be related to old version of it.
                                      M ajb2k3A 2 Replies Last reply Reply Quote 0
                                        mgrouch @mgrouch
                                        It did boot.
                                        USB errors were my fault. I plugged usb 3.0 hub into usb 2.0 port.
                                        One more question:
                                        What are the tty devices names of RS-485 and UART6 under /dev?
                                          ajb2k3 @mgrouch
                                          @teastain here is the dev directory listing
                                          M teastainT 2 Replies Last reply Reply Quote 0
                                            mgrouch @ajb2k3
                                            What is /dev/ttySTM2 ?
