    195 Posts 79 Posters 571.2k Views 13 Watching
    • Q Offline
      Quakernate
      Hi All.
      New here and quite confused. Got the stickCplus2. Love the device, but writing/blocking some code is a pain in the a.. atm.
      Can't seem to recreate the experiment in the docs (https://docs.m5stack.com/en/quick_start/m5stickc_plus2/uiflow); turning on (one of) the LED(s)? In the docs it's blocked with the PIN blocks. Why are those not in the 'built-in hardware' section? The LED's are built-in, right? But also the exact same compilation as in the example does not turn on a LED when run.
      Then in the built-in section you can choose RGB, which definetely is not built-in?
      Some schematic overview of what button/led is which in the code language would be nice. (Just a picture of the device having the code-name next to where it would be placed in the device. Understand what I'm trying to say?
      Is UIflow1 still more stable? Must say, UI2 looks very good. But that's about it for now it seems.
      Sorry for such a long comment already. Got a lot more questions, but I will come back with those later. Still a noob in the esp32 anyway, so I'll keep trying to find out stuff by myself as well.
      Cheers!
      • Q Offline
        Quakernate
        Hi, Quakernate again.
        Seems like there just isn't a LED available in UIFlow2.0. (thought it would maybe be named different) Was toying around in the UIFlow1 and there I was able to turn on the LED nd stuff way easier. (especially since there is a LED block at all)
        Will code some in UIF1.13 until UIF2.0 is suitable (enough) for play.
        If usefull I'm willing to keep fooling around in 2.0 as well just to list more bugs.
          There is an RGB LED available in UIFLow but you need to use the Micropython code to call it.
          • B Offline
            BritOnTour
            Is there any option to import or convert a UiFlow 1 Blockly project to UiFlow 2?
            1 Reply Last reply Reply Quote 4
            • teastainT Offline
              teastain @ajb2k3
              @ajb2k3 I wonder what the difference is between UIFlow ver 1 and ver 2?
              Can sketches be ported over from ver to ver 2, but not vice/versa?
              • dissyD Offline
                dissy
                Bug fix request
                UIFlow2 "http" block is completely non-functional, failing to load the 'requests' library. There is a typo with an errant 'u' that should not be there.
                ImportError: no module named 'urequests'
                  ajb2k3 @teastain
                  @teastain I'm not sure exactly but what I have found, there is some minor alteration to the backend and it would appear that UIFlow2 dropped the original graphic back end and moved to a unified LVGL graphics library.
                  Its possible that everything had to be rewritten because of the ESP32S3 devices and updates to ESP-IDF in Micropython.
                  I do know part of the rewrite was because older devices were running out of memory to run Micropython due to the amount of duplication.
                    ajb2k3 @dissy
                    @dissy This is already known as there is a discussion on trying to work around this typo
                    dissyD 1 Reply Last reply Reply Quote 0
                    • dissyD Offline
                      dissy @ajb2k3
                      @ajb2k3 My intent was making it known to the devs, in the hopes the problem could be fixed.
                        ajb2k3 @dissy
                        @dissy Oh Ok , Just a tip but the forum uses a form of tags so add @m5stack to get the attention.
                        • L Offline
                          lothy
                          @m5stack In UIFlow v2.0.1 I can't find the CO2L unit in the list (SKU:U104). Am I missing something? I'm trying to use it with the M5dial via the I2C port.
                          • W Offline
                            wifi-guy223
                            how can i add apps multiple apps to my stickc plus 2?
                            I want to have more than on app ruing on it and idk how to set that up
                              ajb2k3 @wifi-guy223
                              @wifi-guy223 Its not a computer, it is a microcontroller, it doesn't have an OS.
                              • E Offline
                                ecobeast @m5stack
                                @m5stack Feature request to add CANBus unit (U085) to available units for the M5Dial. I've successfully tested the unit with the dial via the arduino IDE and a library but ideally I'd like to develop my project using UiFlow.
                                • W Offline
                                  Waittherack @Waittherack
                                  @waittherack said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                                  It seems like I can't download my programs anymore, neither in Wifi nor with the USB-C cable. I have a M5Stack Core2. This is what i get both ways : 0_1707839419278_644aa359-ea71-4ef4-a3e3-4ea80718fc6f-image.png 0_1707839440797_7063265d-eb2f-4c59-9f4d-f0b3d6ef1009-image.png
                                  Can someone explain that to me ? It blocks everything, maybe the answer is within the yellow lines but I don't really know what to do :/
                                  • robskiR Offline
                                    robski @Waittherack
                                    is your device firmware(2.0.0 alpha) matches web UIFlow2 version (current 2.0.1)? if not then update via M5Burner
                                      crami25 @ajb2k3
                                      @ajb2k3 ??? Using UIFlow or Python you can have multiple Apps or Programs on your M5Stack device !!
                                      https://www.hackster.io/AJB2K3/multipage-programs-on-the-m5stack-core2-bc302c
                                      • B Offline
                                        BritOnTour
                                        I have an S3 with UIFLOW2 installed. I cannot get it to connect on the WEB interface of UIFLOW2.0_1709933512731_2024-03-08 15_30_09-.png
                                        When I click on the device I get the S3 showing with a red dot. Help!
                                          ajb2k3 @BritOnTour
                                          @britontour Have you installed the UIFlow2 firmware to the CoreS3 and is the screen of the CoreS3 showing that its connected to the server?
                                          • B Offline
                                            BritOnTour @ajb2k3
                                            @ajb2k3 said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                                            This is the info on the S3. UIFLOW2 is loaded, but I notice that it says Private, but my connection in the Web interface is Public.
