    [M5Paper] UiFlow support
    Scheduled Pinned Locked Moved Features Wish List
    33 Posts 12 Posters 103.6k Views 6 Watching
    • OyczEO Offline
      OyczE
      Since @Zontex is away maybe @lukasmaximus or @m5stack could give us some update.
        Medy
        Well as long as it comes ... ideally 2021 ... im cool ... was just afraid there would be no support at all ... since I dont plan on learning C or using arduino ide ....
        Hopefully this is just the start of bigger screens.... I would love to have a bigger m5 lcd version as well
        • ZontexZ Offline
          Zontex @ajb2k3
          @ajb2k3 regarding the API difference, we are actually working now to merge them together into one API.
          @Mati @Medy @ben-myburgh Sorry guys ! for some reason I didn't get a notification over this post, I'll follow up on the progress and keep you guys updated. seems this is the highest priority we currently have.
          • ZontexZ Offline
            Zontex
            Guys, good news - the estimated release of this support is by the Chinese new year holiday which will be in approximately 2 weeks from now :)
            OyczEO 1 Reply Last reply Reply Quote 1
              @Zontex sweet, I will get to see how my guesses have worked out.
              • OyczEO Offline
                OyczE @Zontex
                @zontex said in [M5Paper] UiFlow support:
                nice to hear ! I am disappointed by the fact that the product appeared in the store and only after more than a month does it receive the advertised functionality.
                  Hello guys
                  today in M5Burner I discovered an Alpha version of UIFlow for M5Paper. Already seems to work reasonably well.
                  Cheers
                    doubleness
                    @felmue Hey, are you able to run the code on your device? Not sure what I am doing wrong, I burned UiFlow alpha version, and connected to my device, also it seems like code is being uploaded to m5paper device, and screen refreshes probably restarting, but nothing shows up in the screen.
                    Everytime I try to upload the code I get warning ' Lack block "Set screen set show" or "Set screen parital show" '
                    Not sure what I am doing wrong, any idea?
                    world101W ajb2k3A 2 Replies Last reply Reply Quote 0
                    • world101W Offline
                      world101 @doubleness
                      @doubleness said in [M5Paper] UiFlow support:
                      You need to have one of those blocks in your program to update the screen. They are under UI, then Screen in uiFlow.
                        ajb2k3 @doubleness
                        You need to have the "Set Screen Show" block as the information is only stored in memory and not drawn to the screen until set screen show or set screen partial show is called.
                          doubleness
                          @world101 @ajb2k3
                          Thank you guys it works! You saved me :) ... finally I can switch to micropython, programming using arduino IDE was kind of slow and painful
                            Jank
                            Any information on when the support for M5paper is coming to the official VS code extension for micropython? I can set my device to usb mode but it doesn't find it.
                              ajb2k3 @doubleness
                              @world101 @ajb2k3
                              Like having teeth pulled!
                              No worries, glad to help.
                              • TitiMobyT Offline
                                TitiMoby
                                That's very nice to be able to use UIFlow with M5Paper, thanks. πŸ₯°
                                This also open the door to micropython.
                                I tried it and it works in UIflow.
                                Now, I'm trying to figure out how to add libraries.
                                With M5 core, I use either thonny or rshell.
                                But I could not connect to M5Paper with those.
                                The only tool that worked was Mu editor, but only to see the REPL. Could not access files.
                                Is there a trick to upload files on M5Paper?
                                • TitiMobyT Offline
                                  TitiMoby
                                  Does anyone have ideas to put MicroPython libraries on the M5Paper?
                                    ajb2k3 @TitiMoby
                                    @titimoby said in [M5Paper] UiFlow support:
                                    Yes, there is a trick but alas i forget the trick and struggle to upload.
                                    I'm using thonny and its hit and miss accessing the paper.
                                    • TitiMobyT Offline
                                      TitiMoby
                                      So no stable solution for now, that’s sad.
                                      It’s a bit frustrating to have some micropython working but not the full experience.
                                      At some point, that could be better to switch to hardware that runs CircuitPython, less struggle.
                                        OK, I got it.
                                        To use Thonny or other micropython IDE's with the M5Paper, you need to put the paper into "App Mode" in the menu as UIFlow and USB mode do not allow access to REPL.
                                        • TitiMobyT Offline
                                          TitiMoby
                                          As this is not my first M5 board, I think I was in App mode. But as the main source of errors is often between the chair and the keyboard, I'll focus my attention on this point πŸ˜‰
                                            ajb2k3 @TitiMoby
                                            I'm writing a book on the coreink and m5paper and spent a week trying to work it out!
                                            now if i could only get the internal sht30 to work
                                            Z 1 Reply Last reply Reply Quote 0
                                            With your input, this post could be even better πŸ’—
