    [M5Paper] UiFlow support
    Scheduled Pinned Locked Moved Features Wish List
    33 Posts 12 Posters 106.3k Views 6 Watching
    • OyczEO Offline
      OyczE @ben.myburgh
      @ben-myburgh said in [M5Paper] UiFlow support:
      Any update on this? Arduino IDE support is limited as is...
      i think we have micro basic support in Arduino, base on https://docs.m5stack.com/#/en/quick_start/m5paper/quick_start_arduino
      we can use M5EPD in basic operations.
      • OyczEO Offline
        OyczE
        @Zontex btw the Arduino example Wake and BM8563 should be a clone ?
          @Zontex why have 2 seperate API's for the Coreink and the EPD, Could you not merge most of the API's into one unified e-ink api?
          ZontexZ 1 Reply Last reply Reply Quote 2
          • OyczEO Offline
            OyczE
            bump
            @Zontex there is any chance to get some update ? its starting a bit sad there is grate pice of hardware already at customers home without core UIFlow support ..
            • OyczEO Offline
              OyczE
              Since @Zontex is away maybe @lukasmaximus or @m5stack could give us some update.
                Medy
                Well as long as it comes ... ideally 2021 ... im cool ... was just afraid there would be no support at all ... since I dont plan on learning C or using arduino ide ....
                Hopefully this is just the start of bigger screens.... I would love to have a bigger m5 lcd version as well
                • ZontexZ Offline
                  Zontex @ajb2k3
                  @ajb2k3 regarding the API difference, we are actually working now to merge them together into one API.
                  @Mati @Medy @ben-myburgh Sorry guys ! for some reason I didn't get a notification over this post, I'll follow up on the progress and keep you guys updated. seems this is the highest priority we currently have.
                  • ZontexZ Offline
                    Zontex
                    Guys, good news - the estimated release of this support is by the Chinese new year holiday which will be in approximately 2 weeks from now :)
                    OyczEO 1 Reply Last reply Reply Quote 1
                      @Zontex sweet, I will get to see how my guesses have worked out.
                      • OyczEO Offline
                        OyczE @Zontex
                        @zontex said in [M5Paper] UiFlow support:
                        nice to hear ! I am disappointed by the fact that the product appeared in the store and only after more than a month does it receive the advertised functionality.
                          Hello guys
                          today in M5Burner I discovered an Alpha version of UIFlow for M5Paper. Already seems to work reasonably well.
                          Cheers
                            doubleness
                            @felmue Hey, are you able to run the code on your device? Not sure what I am doing wrong, I burned UiFlow alpha version, and connected to my device, also it seems like code is being uploaded to m5paper device, and screen refreshes probably restarting, but nothing shows up in the screen.
                            Everytime I try to upload the code I get warning ' Lack block "Set screen set show" or "Set screen parital show" '
                            Not sure what I am doing wrong, any idea?
                            world101W ajb2k3A 2 Replies Last reply Reply Quote 0
                            • world101W Offline
                              world101 @doubleness
                              @doubleness said in [M5Paper] UiFlow support:
                              You need to have one of those blocks in your program to update the screen. They are under UI, then Screen in uiFlow.
                                ajb2k3 @doubleness
                                You need to have the "Set Screen Show" block as the information is only stored in memory and not drawn to the screen until set screen show or set screen partial show is called.
                                  doubleness
                                  @world101 @ajb2k3
                                  Thank you guys it works! You saved me :) ... finally I can switch to micropython, programming using arduino IDE was kind of slow and painful
                                    Jank
                                    Any information on when the support for M5paper is coming to the official VS code extension for micropython? I can set my device to usb mode but it doesn't find it.
                                      ajb2k3 @doubleness
                                      @world101 @ajb2k3
                                      Like having teeth pulled!
                                      No worries, glad to help.
                                      • TitiMobyT Offline
                                        TitiMoby
                                        That's very nice to be able to use UIFlow with M5Paper, thanks. 🥰
                                        This also open the door to micropython.
                                        I tried it and it works in UIflow.
                                        Now, I'm trying to figure out how to add libraries.
                                        With M5 core, I use either thonny or rshell.
                                        But I could not connect to M5Paper with those.
                                        The only tool that worked was Mu editor, but only to see the REPL. Could not access files.
                                        Is there a trick to upload files on M5Paper?
                                        • TitiMobyT Offline
                                          TitiMoby
                                          Does anyone have ideas to put MicroPython libraries on the M5Paper?
                                            ajb2k3 @TitiMoby
                                            @titimoby said in [M5Paper] UiFlow support:
                                            Yes, there is a trick but alas i forget the trick and struggle to upload.
                                            I'm using thonny and its hit and miss accessing the paper.
