@M5Stack team: I am looking for any ressources / tutorials on how to use remote+ in uiflow. I do not find any project on hackster.io. please provide a test case tutorial sothat people may use the graphical interface...
Has anybody used it successfully?
Posts made by DR_Froggy_rD
RE: help needed to get started.
job_repository
creating a special forum subpart for small_jobs from community to the community...
RE: M5stickC plus as a remote vibration sensor (using uiflow and remote function)
still nobody... to gve an hint...
I have uploaded the m5file document on hackster.io.
PLease help me...
https://www.hackster.io/DR_Froggy_rD/trying-to-get-stickc-as-vibration-dataloger-for-3d-printer-09ac41 -
@Anybody-
I tried to get stick C plus to run it but the uiflow says api key null
boring -
@m5stack
sad to see no answer/ no suggestion here -
RE: 2023 December Community Challenge.
@trini-cobra you want to get a camera feed to check from away like a domotic home security?
@trini-cobra I know the feeling- I want to do something simple but I cannot get it working. I was able to upload the firmware after two weeks with the aid of ajb2k3. and because they updated the burner and uiflow
but then I could start playing with the background colour of the lcd -
I am not sure if you are serious or trolling me
@ajb2k3 another Idea: having a simple retrolighted button to create a music groove box sub unit (orbuildingblock for this but diy:
https://novationmusic.com/categories/samplers-grooveboxes). that one can connect to others in one single row or several rows button. so meaning we need also a lateral connectivity. I can think of different way to enable that. not only 1D connectivity like we have between a stick C and
an hat -
@ajb2k3 I have another idea:
getting a stick C / remote function to work like an oscilloscope that send data to your smartphone. I am pretty confident this is possible. although I do not have the skills to program this... and making the file available to all as a m5files...
Best reg.I thought also we can organise a sort of job market plce for people to propose some jobs and to pay for the service inside the community.... I think I would be ready to pay for receiving a ready to use imu datalogger. stick C plus. or for the M5 file for it. By buying a or severalm5stack unit for instance for that purpose.
Hi there I would like to know if anyone has successfully used the remote add on on uiflow.
As you see I want to get a kind of graph for all three vibration directions. using the remote + stuff provided in uiflow.
I think I am not sofar I can provide my m5file for that...
The issue seems to be A) I do not know what the IMU is really measuring. B) how to get remote to read the value and convert it to a kind of data logger.It seems I cannot change the x axis egend, which actually needs to be the frequency and not the time. It measure as a function of time interval. which is kind of ok.. but not exactly what I want.
Hi there, why not trying to get a iot sensing device working together with a 3d printer to get sense of all vibrations in order to cancel out any disturbances..Maybe a long shot
RE: UiFlow 2.0 discuss(how-to, bug, feature request or sometings)
@ajb2k3 said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
alas, I don't know
what people use instead? -
I see- the page view was cropped too tight..
I did reset those now I see those...
this is idiotic but ar least I can get it now.
I wanted to get the remote +
Will it be enable in the future? -
Hi there,
I tried to do something but uiflow2 is somehow confusing:
I was able to burn uifllw 2.0 on my atom s3 thank to adam!
Now I wanted to play with it: so I changed the bacground colour! this worked.
Now I was looking to other option as he one found for the stick C plus (IMU and so on) but those arenot available for the atoms3...
the second picture is from uiflow where all hardware options are listed... even the remote + options which is very promissing to me if I achieve that. but I cannot delete all at once...I cannot see the end of the window so I cannot delete everything...or clear to start from scratch on microsoft edge...
boring somehow -
Hi there so thanks to ajb2k3 I was able to burn the atoms3. the issue was a software one.
which has been resolved so far by latest m5 burner update. Once I could log in onto my account from the software.
Now I can even start to play with background colour as well but uiflow2 atom s3 misses a lot of subpart: i cannot get hardware imu to get pop up. however those are present on uiflow but I cannot run from uiflow.
I see a remote m5 function which seems to be an interface for a smartphone.
which can act as datalogger.. what I was intended to do...
this is awesome.I f I can do that so easily but this is not as straight forward. the option do not appear on uiflow 2...0.17 -
issue by logging with newer m5burner
Hi everybody, so I retried to burn my atom s3... for that I need to start the m5 burner under run administrator status otherwise an error pop up... but then when I try to login... this is not working.. when I used an older version I can login but this version do not integrate the atom s3... only the atom....version 2.51 so version 3 of m5 burner is not enabling loggin!
It is not working with two Tom s3 i own to burn a firmware on it...
So as it seems to be working on another iot dev kit, i will rather advice going for the stick c..
Bsst Regards
Frog Frog -
RE: adding a repository of simple projects that one can easily swap the core type to be dlded directly into uiflow
would be great to have a m5f file repository somewhere
