What are the switch settings for Core? Why can't M5Stack just put the switch settings for each in the document? Instead they have this baffling interactive chart that does not seem related to anything at all.
@sssouthpaw Yes I think the only way to do it is to copy the python file and then paste it into Thonny or VSCode before uploading through the file manager in the UIFlow terminal to get the python file on the device.
OKAY! Excellent. THANK YOU. Didn't understand the USB-C port on the charging base.
Figured this all out with your help and appears to need to be fed the power from the included "dumb" USB-A to USB-C cable and not what I thought I could do from an Apple USB-C / USB-C plugged into my MacBook.
