    Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error)
    General
    5
    33
    1.4k
    • K
      Kenzo @robski
      @robski Thanks for replying! With nothing connected to the Tube pressure sensor, I am getting a RAW value of 3,287 (12 bit option selected in the ADC parameter).
      In regards to a 3.6V reference, where is that in the documentation?
      I think we are getting close to solving this problem!
      K 1 Reply Last reply Reply Quote 0
      • K
        Kenzo @Kenzo
        @robski - I stumbled across this youtube video about an Arduino Pressure Sensor and was thinking about testing a version of his method for coming up with a calculation...
        https://youtu.be/UrqPxwsPWGk?si=4Ho9CQwpoFZstMBk&t=321
        • robskiR
          robski
          with your raw value as 3287
          sensor range -100 to 200
          analog range 0 to 4095
          your calculated pressure should be around 140
          M5StickC, M5StickCPlus, M5StickCplus2,M5GO, M5Core, M5Tough, M5Core2, M5 Demo Board, M5Dial, M5Paper, M5Atom, M5Cardputer, M5StampS3, CoreMP135, StamPLC, AirQ, M5Tab
          K 2 Replies Last reply Reply Quote 0
          • K
            Kenzo @robski
            @robski - hmmm.... Well that raw value was with nothing connected to the Tube Pressor sensor. Because nothing is connected to the tube pressure sensor I would assume it would be closer to 0 Kpa... 140Kpa is a big difference from 0 Kpa... I wonder what we are missing?
            • K
              Kenzo @robski
              @robski I keep coming up with 140Kpa also...
              We must be missing something...
              • robskiR
                robski
                just connect voltage to sensor and measure what voltage it is giving out between output pin and ground. for 0 kPa your raw Analog value should be around 1300 i think
                K 2 Replies Last reply Reply Quote 1
                • K
                  Kenzo @robski
                  @robski - I think you hit on something there! I measured the voltage between the ground and the sensor and it came to around 1.1v which according to the graph should be around 0 Kpa. (see attached photos) Something is definitely strange...
                  • K
                    Kenzo @Kenzo
                    This post is deleted!
                    • K
                      Kenzo @Kenzo
                      Also here is the formula I was using to calculate Kpa
                      So for 12 bit parameter, this gives a kpa resolution of 300Kpa/4096 bits or 0.0732421875 kpa/bit (73.2pa/bit)
                      x = ( (0.0732421875 kpa/bit * Raw Value bit) - 100Kpa)
                      x = ( (0.0732421875 kpa/bit * 3287 bit) - 100Kpa) = 140.7Kpa
                      For the 16 bit parameter this gives a kpa resolution of 300Kpa/65536 bits or 0.00457763671875 kpa/bit (4.6pa/bit)
                      x = ( (0.00457763671875 kpa/bit * Raw Value bit) - 100Kpa)
                      x = ( (0.00457763671875 kpa/bit * 52600 bit) - 100Kpa) = 140.8Kpa
                      • K
                        Kenzo @robski
                        @robski I sent an email to M5Stack Support about the possible issue with the Tab5 and Tube Pressure sensor BUT no response so far....
                        kurikoK 1 Reply Last reply Reply Quote 0
                        • kurikoK
                          kuriko @Kenzo
                          @Kenzo
                          This is an ADC problem. We are fixing UiFlow2 codes. Please be patient.
                          • K
                            Kenzo @kuriko
                            @kuriko Thanks Kuriko for responding and taking a further look into the issue! Looking forward to testing out the updated version of UiFlow with the fix!
                            I will now wait quietly and patiently while your team works on an ADC fix.
                            • K
                              Kenzo @kuriko
                              @kuriko Just finished testing the latest release of UiFlow (v2.3.2 ).
                              The Kpa readings was better this time but the accuracy is not there yet... See attached photo.
                              Hopefully the next release will improve the accuracy of the Tube/Air sensor and Tab5...
