    UiFlow 2.0 discuss(how-to, bug, feature request or sometings)
    UiFlow 2.0
    74
    188
    443.8k
    • CAT the TechC
      CAT the Tech
      I also tried some other methods since, none of them had the desired effect:
      Method 2 - Pin buttons
      • This method works only with mode High (pull_low=False), with or without pull
      • It is incredibly slow to respond (about 1 second)
      import os, sys, io
      import M5
      from M5 import *
      from hardware import *
      import time
      Btn37 = None
      Btn39 = None
      Btn35 = None
      def btn37_wasPressed_event(state):
        global Btn37, Btn39, Btn35
        print('Pressed A')
      def btn39_wasPressed_event(state):
        print('Pressed B')
      def btn35_wasPressed_event(state):
        print('Pressed PWR')
      def btn35_wasReleased_event(state):
        print('Released PWR')
      def btn39_wasReleased_event(state):
        print('Released B')
      def btn37_wasReleased_event(state):
        print('Released A')
      def setup():
        print('hello M5')
        M5.begin()
        # Pin 37 == button A
        # Pin 39 == button B
        # Pin 35 == button PWR (aka button C)
        Btn37 = Button(37, active_low=False, pullup_active=False)
        Btn37.setCallback(type=Btn37.CB_TYPE.WAS_PRESSED, cb=btn37_wasPressed_event)
        Btn37.setCallback(type=Btn37.CB_TYPE.WAS_RELEASED, cb=btn37_wasReleased_event)
        Btn39 = Button(39, active_low=False, pullup_active=False)
        Btn39.setCallback(type=Btn39.CB_TYPE.WAS_PRESSED, cb=btn39_wasPressed_event)
        Btn39.setCallback(type=Btn39.CB_TYPE.WAS_RELEASED, cb=btn39_wasReleased_event)
        Btn35 = Button(35, active_low=False, pullup_active=False)
        Btn35.setCallback(type=Btn35.CB_TYPE.WAS_PRESSED, cb=btn35_wasPressed_event)
        Btn35.setCallback(type=Btn35.CB_TYPE.WAS_RELEASED, cb=btn35_wasReleased_event)
      def loop():
        M5.update()
        Btn37.tick(None)
        Btn39.tick(None)
        Btn35.tick(None)
        time.sleep_ms(50)
      if __name__ == '__main__':
        try:
          setup()
          while True:
            loop()
          try:
            print_error_msg(e)
          except ImportError:
      Method 3 - machine.Pin (IRQ)
      • It is fast, responsive
      • It cannot report accurately if the button was pressed or released if multiple events are queued one after the other
      import os, sys, io
      import M5
      from M5 import *
      import time
      from machine import Pin
      pin37 = None
      pin39 = None
      pin35 = None
      p = None
      # Describe this function...
      def button_callback(p):
        global pin37, pin39, pin35
        i = int(str(p)[4:-1])
        print(f"Button id: {i}, value: {p.value()}")
      def setup():
        print('hello M5')
        M5.begin()
        pin37 = Pin(37, mode=Pin.IN)
        pin39 = Pin(39, mode=Pin.IN)
        pin35 = Pin(35, mode=Pin.IN)
        pin37.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=button_callback)
        pin39.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=button_callback)
        pin35.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=button_callback)
      def loop():
        M5.update()
        time.sleep_ms(50)
        try:
          setup()
          while True:
            loop()
          try:
            print_error_msg(e)
          except ImportError:
      Edit:
      Oh, right, I almost forgot.
      There is no such thing as the following in the machine.Pin method:
      p.irq().flags()
      I don't know if it is because of the micropython port you guys use or if it is the esp32-pico-v3-02's fault, but I think there is something missing there...
      • lbuqueL
        lbuque @CAT the Tech
        @CAT-the-Tech I tried running your code and found that it works well.
        CAT the TechC 1 Reply Last reply Reply Quote 0
        • CAT the TechC
          CAT the Tech @lbuque
          @lbuque Really?
          Which method did you use? (1, 2, or 3)
          What device are you using?
          Thanks
          lbuqueL 1 Reply Last reply Reply Quote 0
          • CAT the TechC
            CAT the Tech
            Since version 2.1.0, The Pin Buttons method (method 2) does not work AT ALL anymore
            • lbuqueL
              @CAT-the-Tech stickc_plus2
              • lbuqueL
                cores3 works fine
                • CAT the TechC
                  @lbuque Weird...
                  Can you show me the StickC Plus 2's code you used?
                  Are you sure your core3 AND StickC Plus 2 are at the latest version? (2.1.0 as of yesterday) (You can see this when it boots, in the terminal)
                  • D
                    digiponta
                    I need it supports M5Stack DIN base with M5 stack/S3.
                    • lbuqueL
                      lbuque @digiponta
                      @digiponta said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                      DIN base does not require software support, it can be used directly.
                      • CAT the TechC
                        CAT the Tech @CAT the Tech
                        @lbuque I tried some more ideas to make the buttons work again:
                        M5 buttons - manual loop
                        • Same results as the original M5 buttons method (button A and PWR (C) won't work no matter what, and button B thinks it is button A)
                        import os, sys, io
                        import M5
                        from M5 import *
                        import time
                        def button_check():
                          if BtnA.wasPressed():
                            print('Pressed A')
                          if BtnA.wasReleased():
                            print('Released A')
                          if BtnB.wasPressed():
                            print('Pressed B')
                          if BtnB.wasReleased():
                            print('Released B')
                          if BtnPWR.wasPressed():
                          if BtnPWR.wasReleased():
                        def setup():
                          print('hello M5')
                          M5.begin()
                        def loop():
                          M5.update()
                          button_check()
                          time.sleep_ms(50)
                          try:
                            setup()
                            while True:
                              loop()
                            try:
                              print_error_msg(e)
                            except ImportError:
                        Pin buttons - manual loop
                        Okay, so this one is an absolute monster via blockly (visual editor)
                        • Same results as the original Pin buttons method (it takes some time for the buttons to register the actions and the press/release is inverted))
                        import os, sys, io
                        import M5
                        from M5 import *
                        import time
                        Btn37 = None
                        Btn39 = None
                        Btn35 = None
                        code_str = None
                        Btn37_last_state = None
                        Btn39_last_state = None
                        Btn35_last_state = None
                        def button_check():
                          global code_str, Btn37_last_state, Btn39_last_state, Btn35_last_state, Btn37, Btn39, Btn35
                          if execute_mpy_code('Btn37.wasPressed()') and not Btn37_last_state:
                            print('Pressed A')
                            Btn37_last_state = True
                          elif execute_mpy_code('Btn37.wasReleased()') and Btn37_last_state:
                            print('Released A')
                            Btn37_last_state = False
                          if execute_mpy_code('Btn39.wasPressed()') and not Btn39_last_state:
                            print('Pressed B')
                            Btn39_last_state = True
                          elif execute_mpy_code('Btn39.wasReleased()') and Btn39_last_state:
                            print('Released B')
                            Btn39_last_state = False
                          if execute_mpy_code('Btn35.wasPressed()') and not Btn35_last_state:
                            Btn35_last_state = True
                          elif execute_mpy_code('Btn35.wasReleased()') and Btn35_last_state:
                            Btn35_last_state = False
                        def execute_mpy_code(code_str):
                          global Btn37_last_state, Btn39_last_state, Btn35_last_state, Btn37, Btn39, Btn35
                          return eval(code_str)
                        def setup():
                          global Btn37, Btn39, Btn35, Btn37_last_state, Btn39_last_state, Btn35_last_state
                          print('hello M5')
                          M5.begin()
                        def loop():
                          M5.update()
                          Btn37.tick(None)
                          Btn39.tick(None)
                          Btn35.tick(None)
                          button_check()
                          time.sleep_ms(50)
                          try:
                            setup()
                            while True:
                              loop()
                            try:
                              print_error_msg(e)
                            except ImportError:
                        I believe my unit is not the issue, because the machine.Pin method worked as expected (except that I cannot get the state of the button the moment the callback was called)
                        What are the next steps / things to try?
                        • felmueF
                          felmue @CAT the Tech
                          Hello @CAT-the-Tech
                          using M5StickCPlus2 with UIFlow2.1.1 firmware works for me using either Button or Pin Button blocks.
                          Button blocks example in ProjectZone: M5StickCPlus2_BtnABPWR_Test_UIFlow2.1.1
                          Pin Button blocks example in PlayZone: M5StickCPlus2_PinButtonTest_UIFlow2.1.1
                          Note: with Button blocks responds time is much quicker.
                          Thanks
                          Felix
                          Code examples
                          • CAT the TechC
                            CAT the Tech @felmue
                            Hi @felmue ,
                            Unfortunately, I had the same results with your code as with mine.
                            The only thing I changed to make your code 'work' is add print statements (I broke my screen, so no more labels for me).
                            I also had to put the Pin Buttons' init statements to mode=High (otherwise my buttons won't work)
                            Basically the only difference between your code and mine, other than that, is that you didn't sleep in your loop
                            I shared my test projects too:
                            (M5 Buttons) buttons callback test
                            (pin buttons) buttons callback test
                            for the pin buttons one, please fill in the callbacks' names to: [37, 37, 39, 39, 35, 35] (there is a bug that whenever you import the project they dissapear)
                            • felmueF
                              Hello @CAT-the-Tech
                              ok, I think I figured it out. The issue seems to be the broken screen. I get the same results as you do if I remove the screen of my M5StickCPlus2.
                              UIFlow2 firmware is based on M5Unified (C code) which uses the different screens (or lack thereof) to distinguish between device models. The board ID for M5StickCPlus2 is 5. However without screen it thinks it is an M5Atom (board ID 129). And the M5Atom has a single button connected to GPIO39. That is why pressing BtnB on an M5StickCPlus2 (w/o screen) signals BtnA. See here.
                              Thanks
                              Felix
                              Code examples
                              CAT the TechC 1 Reply Last reply Reply Quote 1
                              • CAT the TechC
                                @felmue @lbuque Finally! It worked!
                                As felmue said, it was the broken/unplugged screen that caused my StickCPlus2 to act like a M5Atom
                                My screen looks to have only the outer plastic/glass layer broken (it still lights on, but it is cracked and only shows lines and stuff).
                                So I plugged the screen back in, and now the buttons work!
                                Thank you all for helping me, I will soon order another StickCPlus2 from Mouser.
                                To the developers:
                                Can you please make it so that UIFlow2 distinguish between the different models using a model number taken from when M5Burner flashes UIFlow2?
                                • CAT the TechC
                                  CAT the Tech
                                  Feature requests
                                  • An 'Execute mpy code' block that plugs into another block (a value block(?))
                                  • The possibility to go back versions in UIFlow2's web interface
                                  Bug/feature request
                                  Normally, when you want to rotate the display, you execute this:
                                  M5.begin()
                                  # M5 inits labels, etc
                                  Widgets.setRotation(1)
                                  But this is wrong! Because it inits the labels BEFORE the screen is rotated, which makes the labels appear once before the screen is rotated, and then stays in the wrong orientation even after the screen is flipped.
                                  What I need to do:
                                  # trick M5  begin
                                  eval("M5" + ".begin()")
                                  if False:
                                    M5.begin()
                                  a
                                  • C
                                    chrol @CAT the Tech
                                    Hi,
                                    I noticed the THERMAL2Unit name is capitalised wrong in UIFlow 2 web - in the m5stack/unit/init.py it is called "ThermalUnit2" => Import error.
                                    (Even after doing manual codeblock edit I don't get an import error but other errors - but this should likely be fixed anyway)
                                    Thanks
                                    C
                                    • C
                                      chrol @chrol
                                      I see that the ThermalUnit2 is now fixed :)
                                      Next issue -
                                      • how can I access temperature data buffer and include in REST API or
                                      • present it on screen (e.g. do I use it as source for an image UI component somehow?)
                                      Thanks!
                                      @chrol said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                                      Hi,
                                      Thanks
                                      C
                                      • Coopersmith-24601C
                                        Coopersmith-24601
                                        This post is deleted!
                                          Coopersmith-24601
                                          FEATURE REQUEST!
                                          It would be extraordinarily helpful for there to be a type of LABEL in UiFlow2 which could fill the screen and word-wrap long text strings.
                                          IAMLIUBOI 1 Reply Last reply Reply Quote 0
                                          • IAMLIUBOI
                                            IAMLIUBO @Coopersmith-24601
                                            @Coopersmith-24601 said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                                            FEATURE REQUEST!
                                            Yes. Thanks for suggestion. We will consider this.
