    195 Posts 79 Posters 591.5k Views 13 Watching
      Raed.Alnuaimi
      Hi...
      How to add custom block (m5b) to UiFlow2.0???
        HéctorD
        Is there any way to port projects from UiFlow 1 to UiFlow 2 (.m5f to .m5f2)?
        I've been searching in the forum but didn't find any message about it.
        I've to start all my development from zero or there is any way to port projects from one system to the another?
        I've several developments for M5StickC.
        If it is possible, I think it must be put more visible how to do it. If it's not possible, it must be warning in some place to be visible too.
        Thanks.
        • CAT the TechC Offline
          CAT the Tech
          Since update 2.0.9, the buttons on my M5Stack Stick C Plus 2 have been tangled and unusable
          The button A and power button (aka button C) are now unresponsive. Their respective callbacks do not get triggered at all.
          The button B will trigger the callback for button A!
          Here is my test program:
          import os, sys, io
          import M5
          from M5 import *
          from hardware import *
          import time
          def btnA_wasPressed_event(state):
            print('Pressed A')
          def btnA_wasReleased_event(state):
            print('Released A')
          def btnB_wasPressed_event(state):
            print('Pressed B')
          def btnB_wasReleased_event(state):
            print('Released B')
          def btnPWR_wasPressed_event(state):
            print('Pressed PWR')
          def btnPWR_wasReleased_event(state):
            print('Released PWR')
          def setup():
            print('hello M5')
            M5.begin()
            BtnA.setCallback(type=BtnA.CB_TYPE.WAS_PRESSED, cb=btnA_wasPressed_event)
            BtnA.setCallback(type=BtnA.CB_TYPE.WAS_RELEASED, cb=btnA_wasReleased_event)
            BtnB.setCallback(type=BtnB.CB_TYPE.WAS_PRESSED, cb=btnB_wasPressed_event)
            BtnB.setCallback(type=BtnB.CB_TYPE.WAS_RELEASED, cb=btnB_wasReleased_event)
            BtnPWR.setCallback(type=BtnPWR.CB_TYPE.WAS_PRESSED, cb=btnPWR_wasPressed_event)
            BtnPWR.setCallback(type=BtnPWR.CB_TYPE.WAS_RELEASED, cb=btnPWR_wasReleased_event)
          def loop():
            M5.update()
            time.sleep_ms(50)
          if __name__ == '__main__':
            try:
              setup()
              while True:
                loop()
              try:
                print_error_msg(e)
              except ImportError:
          All was working well in UiFlow 2.0.8 yesterday, please fix this so I can continue to use it.
            CAT the Tech
            I also tried some other methods since, none of them had the desired effect:
            Method 2 - Pin buttons
            • This method works only with mode High (pull_low=False), with or without pull
            • It is incredibly slow to respond (about 1 second)
            import os, sys, io
            import M5
            from M5 import *
            import time
            Btn37 = None
            Btn39 = None
            Btn35 = None
            def btn37_wasPressed_event(state):
              global Btn37, Btn39, Btn35
              print('Pressed A')
            def btn39_wasPressed_event(state):
              print('Pressed B')
            def btn35_wasPressed_event(state):
            def btn35_wasReleased_event(state):
            def btn39_wasReleased_event(state):
              print('Released B')
            def btn37_wasReleased_event(state):
              print('Released A')
            def setup():
              print('hello M5')
              M5.begin()
              # Pin 37 == button A
              # Pin 39 == button B
              Btn37.setCallback(type=Btn37.CB_TYPE.WAS_PRESSED, cb=btn37_wasPressed_event)
              Btn37.setCallback(type=Btn37.CB_TYPE.WAS_RELEASED, cb=btn37_wasReleased_event)
              Btn39.setCallback(type=Btn39.CB_TYPE.WAS_PRESSED, cb=btn39_wasPressed_event)
              Btn39.setCallback(type=Btn39.CB_TYPE.WAS_RELEASED, cb=btn39_wasReleased_event)
              Btn35.setCallback(type=Btn35.CB_TYPE.WAS_PRESSED, cb=btn35_wasPressed_event)
              Btn35.setCallback(type=Btn35.CB_TYPE.WAS_RELEASED, cb=btn35_wasReleased_event)
            def loop():
              M5.update()
              Btn37.tick(None)
              Btn39.tick(None)
              Btn35.tick(None)
              time.sleep_ms(50)
              try:
                setup()
                while True:
                  loop()
                try:
                  print_error_msg(e)
                except ImportError:
            Method 3 - machine.Pin (IRQ)
            • It is fast, responsive
            • It cannot report accurately if the button was pressed or released if multiple events are queued one after the other
            import os, sys, io
            import M5
            from M5 import *
            import time
            from machine import Pin
            pin37 = None
            pin39 = None
            pin35 = None
            p = None
            # Describe this function...
            def button_callback(p):
              global pin37, pin39, pin35
              i = int(str(p)[4:-1])
              print(f"Button id: {i}, value: {p.value()}")
            def setup():
              print('hello M5')
              M5.begin()
              pin37 = Pin(37, mode=Pin.IN)
              pin39 = Pin(39, mode=Pin.IN)
              pin35 = Pin(35, mode=Pin.IN)
              pin37.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=button_callback)
              pin39.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=button_callback)
              pin35.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=button_callback)
            def loop():
              M5.update()
              time.sleep_ms(50)
              try:
                setup()
                while True:
                  loop()
                try:
                  print_error_msg(e)
                except ImportError:
            Edit:
            Oh, right, I almost forgot.
            There is no such thing as the following in the machine.Pin method:
            p.irq().flags()
            I don't know if it is because of the micropython port you guys use or if it is the esp32-pico-v3-02's fault, but I think there is something missing there...
            • lbuqueL Offline
              lbuque @CAT the Tech
              @CAT-the-Tech I tried running your code and found that it works well.
              CAT the TechC 1 Reply Last reply Reply Quote 0
                CAT the Tech @lbuque
                @lbuque Really?
                Which method did you use? (1, 2, or 3)
                What device are you using?
                  CAT the Tech
                  Since version 2.1.0, The Pin Buttons method (method 2) does not work AT ALL anymore
                  • lbuqueL Offline
                    @CAT-the-Tech stickc_plus2
                    • lbuqueL Offline
                      cores3 works fine
                        @lbuque Weird...
                        Can you show me the StickC Plus 2's code you used?
                        Are you sure your core3 AND StickC Plus 2 are at the latest version? (2.1.0 as of yesterday) (You can see this when it boots, in the terminal)
                          digiponta
                          I need it supports M5Stack DIN base with M5 stack/S3.
                          • lbuqueL Offline
                            lbuque @digiponta
                            @digiponta said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                            DIN base does not require software support, it can be used directly.
                              CAT the Tech @CAT the Tech
                              @lbuque I tried some more ideas to make the buttons work again:
                              M5 buttons - manual loop
                              • Same results as the original M5 buttons method (button A and PWR (C) won't work no matter what, and button B thinks it is button A)
                              import os, sys, io
                              import M5
                              from M5 import *
                              import time
                              def button_check():
                                if BtnA.wasPressed():
                                  print('Pressed A')
                                if BtnA.wasReleased():
                                  print('Released A')
                                if BtnB.wasPressed():
                                  print('Pressed B')
                                if BtnB.wasReleased():
                                  print('Released B')
                                if BtnPWR.wasPressed():
                                if BtnPWR.wasReleased():
                              def setup():
                                print('hello M5')
                                M5.begin()
                              def loop():
                                M5.update()
                                button_check()
                                time.sleep_ms(50)
                                try:
                                  setup()
                                  while True:
                                    loop()
                                  try:
                                    print_error_msg(e)
                                  except ImportError:
                              Pin buttons - manual loop
                              Okay, so this one is an absolute monster via blockly (visual editor)
                              • Same results as the original Pin buttons method (it takes some time for the buttons to register the actions and the press/release is inverted))
                              import os, sys, io
                              import M5
                              from M5 import *
                              import time
                              Btn37 = None
                              Btn39 = None
                              Btn35 = None
                              code_str = None
                              Btn37_last_state = None
                              Btn39_last_state = None
                              Btn35_last_state = None
                              def button_check():
                                global code_str, Btn37_last_state, Btn39_last_state, Btn35_last_state, Btn37, Btn39, Btn35
                                if execute_mpy_code('Btn37.wasPressed()') and not Btn37_last_state:
                                  print('Pressed A')
                                  Btn37_last_state = True
                                elif execute_mpy_code('Btn37.wasReleased()') and Btn37_last_state:
                                  print('Released A')
                                  Btn37_last_state = False
                                if execute_mpy_code('Btn39.wasPressed()') and not Btn39_last_state:
                                  print('Pressed B')
                                  Btn39_last_state = True
                                elif execute_mpy_code('Btn39.wasReleased()') and Btn39_last_state:
                                  print('Released B')
                                  Btn39_last_state = False
                                if execute_mpy_code('Btn35.wasPressed()') and not Btn35_last_state:
                                  Btn35_last_state = True
                                elif execute_mpy_code('Btn35.wasReleased()') and Btn35_last_state:
                                  Btn35_last_state = False
                              def execute_mpy_code(code_str):
                                global Btn37_last_state, Btn39_last_state, Btn35_last_state, Btn37, Btn39, Btn35
                                return eval(code_str)
                              def setup():
                                global Btn37, Btn39, Btn35, Btn37_last_state, Btn39_last_state, Btn35_last_state
                                print('hello M5')
                                M5.begin()
                              def loop():
                                M5.update()
                                Btn37.tick(None)
                                Btn39.tick(None)
                                Btn35.tick(None)
                                button_check()
                                time.sleep_ms(50)
                                try:
                                  setup()
                                  while True:
                                    loop()
                                  try:
                                    print_error_msg(e)
                                  except ImportError:
                              I believe my unit is not the issue, because the machine.Pin method worked as expected (except that I cannot get the state of the button the moment the callback was called)
                              What are the next steps / things to try?
                                felmue @CAT the Tech
                                Hello @CAT-the-Tech
                                using M5StickCPlus2 with UIFlow2.1.1 firmware works for me using either Button or Pin Button blocks.
                                Button blocks example in ProjectZone: M5StickCPlus2_BtnABPWR_Test_UIFlow2.1.1
                                Pin Button blocks example in PlayZone: M5StickCPlus2_PinButtonTest_UIFlow2.1.1
                                Note: with Button blocks responds time is much quicker.
                                  CAT the Tech @felmue
                                  Hi @felmue ,
                                  Unfortunately, I had the same results with your code as with mine.
                                  The only thing I changed to make your code 'work' is add print statements (I broke my screen, so no more labels for me).
                                  I also had to put the Pin Buttons' init statements to mode=High (otherwise my buttons won't work)
                                  Basically the only difference between your code and mine, other than that, is that you didn't sleep in your loop
                                  I shared my test projects too:
                                  (M5 Buttons) buttons callback test
                                  (pin buttons) buttons callback test
                                  for the pin buttons one, please fill in the callbacks' names to: [37, 37, 39, 39, 35, 35] (there is a bug that whenever you import the project they dissapear)
                                    Hello @CAT-the-Tech
                                    ok, I think I figured it out. The issue seems to be the broken screen. I get the same results as you do if I remove the screen of my M5StickCPlus2.
                                    UIFlow2 firmware is based on M5Unified (C code) which uses the different screens (or lack thereof) to distinguish between device models. The board ID for M5StickCPlus2 is 5. However without screen it thinks it is an M5Atom (board ID 129). And the M5Atom has a single button connected to GPIO39. That is why pressing BtnB on an M5StickCPlus2 (w/o screen) signals BtnA. See here.
                                    CAT the TechC 1 Reply Last reply Reply Quote 1
                                      @felmue @lbuque Finally! It worked!
                                      As felmue said, it was the broken/unplugged screen that caused my StickCPlus2 to act like a M5Atom
                                      My screen looks to have only the outer plastic/glass layer broken (it still lights on, but it is cracked and only shows lines and stuff).
                                      So I plugged the screen back in, and now the buttons work!
                                      Thank you all for helping me, I will soon order another StickCPlus2 from Mouser.
                                      To the developers:
                                      Can you please make it so that UIFlow2 distinguish between the different models using a model number taken from when M5Burner flashes UIFlow2?
                                        CAT the Tech
                                        Feature requests
                                        • An 'Execute mpy code' block that plugs into another block (a value block(?))
                                        • The possibility to go back versions in UIFlow2's web interface
                                        Bug/feature request
                                        Normally, when you want to rotate the display, you execute this:
                                        M5.begin()
                                        # M5 inits labels, etc
                                        Widgets.setRotation(1)
                                        But this is wrong! Because it inits the labels BEFORE the screen is rotated, which makes the labels appear once before the screen is rotated, and then stays in the wrong orientation even after the screen is flipped.
                                        What I need to do:
                                        # trick M5  begin
                                        eval("M5" + ".begin()")
                                        if False:
                                          M5.begin()
                                        a
                                          chrol @CAT the Tech
                                          I noticed the THERMAL2Unit name is capitalised wrong in UIFlow 2 web - in the m5stack/unit/init.py it is called "ThermalUnit2" => Import error.
                                          (Even after doing manual codeblock edit I don't get an import error but other errors - but this should likely be fixed anyway)
                                          C
                                            chrol @chrol
                                            I see that the ThermalUnit2 is now fixed :)
                                            Next issue -
                                            • how can I access temperature data buffer and include in REST API or
                                            • present it on screen (e.g. do I use it as source for an image UI component somehow?)
                                            Thanks!
                                            @chrol said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                                            C
