    TAB5 I2C issues using UIflow2
    Cores
    638
    • B
      BR123456
      I'm trying to handle some stepper motors using the "stepmotor driver module V1.1" on the UIflow 2.3.8 IDE.
      I'm connecting the module to the M-Bus at the back of the TAB5, but the TAB5 won't recognize it and won't show it on the I2C list using the default scanner that comes with the official TAB5 UIflow2 firmware.
      It does recognize an 8Servo unit when connected to the I2C Port.A at the side of the TAB5.
      I've tried also connecting a 4in8out module on the TAB5 M-Bus, but it is not recognized as well.
      The 2 modules (stepmotoer driver and 4in8out ) do work when connected to a Core2 M-Bus, so these units are OK.
      It's either my TAB5 arrived faulty, or there is an issue with the I2C on the M-Bus of the TAB5, at least when using UIFlow2 IDE.
      Any suggestions?
      • kurikoK
        kuriko
        @BR123456
        The default internal I2C scanner of Tab5 in UiFlow2 has bug, we are now fixing it!
        B 3 Replies Last reply Reply Quote 0
        • B
          BR123456 @kuriko
          @kuriko Thanks.
          • B
            BR123456 @kuriko
            @kuriko Hi Kuriko,
            Any estimation when this bug will be fixed?
            Is there a way to bypass this bug? I do need to operate the ""Stepmotor driver V1.1"" with the TAB5.
            • B
              BR123456 @kuriko
              @kuriko said in TAB5 I2C issues using UIflow2:
              @BR123456
              I've just found a hack for this bug.
              One has to define the I2C port pins before initializing the stepmotor module, as shown in the image.
              The module works fine now.
