    M5Stack - Simple Applications Menu + some APPs
    40 Posts 10 Posters 250.1k Views 6 Watching
      TomSuch
      Added QR-Code APP
        TomSuch
        Added Serial Interface for remote control:
        Serial control at 115200 8N1 and NL&CR termination
        bright [0-255] - display bright
        EXAMPLE: bright 128
        clr - clear display
        sleep - power sleep, wakeup on BTN_B
        qrc [text] - show QRCODE with text
        EXAMPLE: qrc www.google.com
        Send iBeacone message
        ibeacon [major code 0-65535] [minor code 0-65535] [power 0-255]
        EXAMPLE: ibeacon 1024 2048 50
        Send Eddystone TLM message
        eddystonetlm [voltage 0-65535] [temperature 0-65535] [pocket cound 0-4294967295] [second from up 0-4294967295]
        EXAMPLE: eddystonetlm 100 200 300 400
        Send Eddystone URL message
        eddystoneurl [prefix 0-3] [power 0-255] [url]
        EXAMPLE: eddystoneurl 1 1 google.com
        PREFIXES:
        0 http://www.
        1 https://www.
        2 http://
        3 https://
          TomSuch @JJ
          @jimit Thank you for the positive bond ...
          • JJJ Offline
            JJ @TomSuch
            @tomsuch
            No problem Tom. Very much deserved !
            Have got a wifi scan working with this under the Apps menu... but need to more spend a bit more time to get the screen output layout right... so each scan displays from the same line each time.
            • m5stackM Offline
              Awesome, i think we should do some offical support about this good idea.
              T 1 Reply Last reply Reply Quote 3
                TomSuch @m5stack
                @m5stack Thank you. I'd like to create something like a Swiss knife for makers.I like M5Stack and I'd like to create applications like a simple pocket oscilloscope, multimeter, I2C / SPI sniffer, signal generator, and so on. I think M5Stack is a platform with a lot of potential. Regards..
                  TomSuch
                  New version:
                  Added:
                  • APP - GY-512 (MPU6050) - gyro/accelerometer
                  • APP - variable speed Serial PASS-THRU USB<->UART2
                  • SYSTEM - System Informatins (CPU Speed, Flash Size, Flash SPEED, SDK Version .......)
                  • Serial Commands - WiFiScan, I2CScan
                  • m5stackM Offline
                    @TomSuch I got your mind, and similar to me, i really hope it like a swiss knife. useful and meaningful.
                      Kryten
                      I get errors on all
                      [code]
                      #pragma mark
                      [/code]
                      Will comment out and try again
                        TomSuch @Kryten
                        @kryten Please specify the error. Arduino version. Take PrintScreen.
                        Do you have installed M5.libraries ? ESP32 libraries ?
                        • reaper7R Offline
                          reaper7
                          @tomsuch 在 M5Stack - Simple Applications Menu + some APPs 中说:
                          APP - GY-512
                          very nice system!
                          APP - GY-512 works also with built-in MPU9250 :)
                          Can You modify TIM MEASUREMENT APP?
                          S/S button should 1.START->2.STOP->3.START without reset between 2 and 3 step...(something like continous measurement with pause). For reset value we have RES button
                            TomSuch @reaper7
                            @reaper7 Hi, thanks for the subject. I edited the application of the stopwatch and is already out. Regards...
                            • JJJ Offline
                              JJ
                              T 2 Replies Last reply Reply Quote 0
                                TomSuch @JJ
                                @jimit Hi, good work. But I did not find the code on your git ...
                                • JJJ Offline
                                  JJ @TomSuch
                                  @tomsuch
                                  Oops... sorry bout that. Have added them now....
                                    TomSuch @JJ
                                    @jimit OK, I'm going to check it out ..
                                      TomSuch @JJ
                                      @jimit Hello Jimi, I have redesigned your WiFi scanner application and there is a new version M5Stack-SAM with this APP out there.
                                      https://github.com/tomsuch/M5Stack-SAM
                                      • JJJ Offline
                                        JJ @TomSuch
                                        @tomsuch Thanks Tom... looks much better ! One thing - for me once the scan is done it lists the networks but the screen refreshes immediately before they can be read.... tested on two different M5s ? Strange if it's not happening for you too. Hate to respond with a negative when you've done such nice work. BTW, the system info page you added is great to have and the others too. Awesome work.
                                          TomSuch @JJ
                                          @jimit Hi Jim, I think I found and remove the bug. Can you try a new, fixed version? Thank you...
                                          https://github.com/tomsuch/M5Stack-SAM/
                                          • JJJ Offline
                                            JJ @TomSuch
                                            @tomsuch
                                            Awesome... all wifi scanner functions working perfectly - thou i couldn't test the page function due to lack of networks... excellent work Tom !! Thanks for making it happen.
