    i2c driver install error
    15 Posts 9 Posters 15.3k Views 4 Watching
    • kurikoK Offline
      kuriko @LucidXVR
      @LucidXVR
      known issue, seems doesn't affect anything, will fix it soon
      K H 2 Replies Last reply Reply Quote 0
      • felmueF felmue referenced this topic on
        kmk68 @kuriko
        @kuriko Yes, it affects. The program does not start on my M5 Core after this message....
        • kurikoK Offline
          kuriko @kmk68
          @kmk68
          Are you able to show your code?
          K 1 Reply Last reply Reply Quote 1
            kmk68 @kuriko
            @kuriko it's created by block editing...
            import os, sys, io
            import M5
            from M5 import *
            from label_plus import LabelPlus
            from hardware import *
            import time
            from unit import EncoderUnit
            label0 = None
            label1 = None
            label2 = None
            label3 = None
            BtnA = None
            BtnB = None
            BtnC = None
            rect0 = None
            rect1 = None
            rect2 = None
            rect3 = None
            rect4 = None
            rect5 = None
            rect6 = None
            rect7 = None
            rect8 = None
            rect9 = None
            rect10 = None
            rect11 = None
            rect12 = None
            rect13 = None
            rect14 = None
            rect15 = None
            rect16 = None
            rect17 = None
            rect18 = None
            rect19 = None
            label7 = None
            label8 = None
            label9 = None
            label10 = None
            label11 = None
            label12 = None
            label13 = None
            LA_4 = None
            LA_3 = None
            LA_2 = None
            LA_1 = None
            LB_4 = None
            LB_3 = None
            LB_2 = None
            LB_1 = None
            LC_4 = None
            LC_3 = None
            LC_2 = None
            LC_1 = None
            pin3 = None
            pin1 = None
            pin2 = None
            pin5 = None
            i2c1 = None
            pin25 = None
            pin26 = None
            pin35 = None
            pin36 = None
            encoder_0 = None
            l_enc_inc = None
            INT_clock = None
            t_values = None
            enc_mode = None
            curr_value = None
            loc_value = None
            Describe this function...
            def init_all_out_pins_as_():
            global l_enc_inc, INT_clock, t_values, enc_mode, curr_value, loc_value, label0, label1, label2, label3, BtnA, BtnB, BtnC, rect0, rect1, rect2, rect3, rect4, rect5, rect6, rect7, rect8, rect9, rect10, rect11, rect12, rect13, rect14, rect15, rect16, rect17, rect18, rect19, label7, label8, label9, label10, label11, label12, label13, LA_4, LA_3, LA_2, LA_1, LB_4, LB_3, LB_2, LB_1, LC_4, LC_3, LC_2, LC_1, pin3, pin1, pin2, pin5, i2c1, pin25, pin26, pin35, pin36, encoder_0
            pin3 = Pin(3, mode=Pin.OUT, pull=Pin.PULL_UP)
            pin1 = Pin(1, mode=Pin.OUT, pull=Pin.PULL_UP)
            pin2 = Pin(2, mode=Pin.OUT, pull=Pin.PULL_UP)
            pin5 = Pin(5, mode=Pin.OUT, pull=Pin.PULL_UP)
            pin25 = Pin(25, mode=Pin.OUT, pull=Pin.PULL_UP)
            pin26 = Pin(26, mode=Pin.OUT, pull=Pin.PULL_UP)
            pin35 = Pin(35, mode=Pin.OUT, pull=Pin.PULL_UP)
            pin36 = Pin(36, mode=Pin.OUT, pull=Pin.PULL_UP)
            def relay_outs_pin_set():
            if t_values[-1] == INT_clock:
            pin3.value(1)
            if t_values[0] == INT_clock:
            pin1.value(1)
            if t_values[1] == INT_clock:
            pin2.value(1)
            if t_values[2] == INT_clock:
            pin5.value(1)
            if t_values[3] == INT_clock:
            pin25.value(1)
            if t_values[4] == INT_clock:
            pin26.value(1)
            if t_values[5] == INT_clock:
            pin35.value(1)
            if t_values[6] == INT_clock:
            pin36.value(1)
            if t_values[7] == INT_clock:
            pin25.value(0)
            if t_values[8] == INT_clock:
            pin26.value(0)
            if t_values[9] == INT_clock:
            pin35.value(0)
            if t_values[10] == INT_clock:
            pin36.value(0)
            if t_values[7] + 25 == INT_clock:
            pin3.value(0)
            if t_values[8] + 25 == INT_clock:
            pin1.value(0)
            if t_values[9] + 25 == INT_clock:
            pin2.value(0)
            if t_values[10] + 25 == INT_clock:
            pin5.value(0)
            def all_out_pins_to_zero():
            pin3.value(0)
            pin1.value(0)
            pin2.value(0)
            pin5.value(0)
            pin25.value(0)
            pin26.value(0)
            pin35.value(0)
            pin36.value(0)
            def setup():
            global label0, label1, label2, label3, BtnA, BtnB, BtnC, rect0, rect1, rect2, rect3, rect4, rect5, rect6, rect7, rect8, rect9, rect10, rect11, rect12, rect13, rect14, rect15, rect16, rect17, rect18, rect19, label7, label8, label9, label10, label11, label12, label13, LA_4, LA_3, LA_2, LA_1, LB_4, LB_3, LB_2, LB_1, LC_4, LC_3, LC_2, LC_1, pin3, pin1, pin2, pin5, i2c1, pin25, pin26, pin35, pin36, encoder_0, l_enc_inc, INT_clock, t_values, enc_mode, curr_value, loc_value
            M5.begin()
            Widgets.fillScreen(0x222222)
            label0 = Widgets.Label("Key 1", 4, 185, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
            label1 = Widgets.Label("Key 1", 4, 135, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
            label2 = Widgets.Label("Key 2", 5, 85, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
            label3 = Widgets.Label("Key 4", 5, 35, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
            BtnA = Widgets.Label("A", 60, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
            BtnB = Widgets.Label("B", 150, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
            BtnC = Widgets.Label("C", 240, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
            rect0 = Widgets.Rectangle(100, 40, 40, 25, 0xffffff, 0x0f0957)
            rect1 = Widgets.Rectangle(143, 40, 40, 25, 0xffffff, 0x0f0957)
            rect2 = Widgets.Rectangle(186, 40, 40, 25, 0xffffff, 0x0f0957)
            rect3 = Widgets.Rectangle(229, 40, 40, 25, 0xffffff, 0x0f0957)
            rect4 = Widgets.Rectangle(100, 68, 40, 25, 0xffffff, 0x0f0957)
            rect5 = Widgets.Rectangle(143, 68, 40, 25, 0xffffff, 0x0f0957)
            rect6 = Widgets.Rectangle(186, 68, 40, 25, 0xffffff, 0x0f0957)
            rect7 = Widgets.Rectangle(229, 68, 40, 25, 0xffffff, 0x0f0957)
            rect8 = Widgets.Rectangle(100, 96, 40, 25, 0xffffff, 0x0f0957)
            rect9 = Widgets.Rectangle(100, 124, 40, 25, 0xffffff, 0x0f0957)
            rect10 = Widgets.Rectangle(100, 152, 40, 25, 0xffffff, 0x0f0957)
            rect11 = Widgets.Rectangle(143, 96, 40, 25, 0xffffff, 0x0f0957)
            rect12 = Widgets.Rectangle(186, 96, 40, 25, 0xffffff, 0x0f0957)
            rect13 = Widgets.Rectangle(229, 96, 40, 25, 0xffffff, 0x0f0957)
            rect14 = Widgets.Rectangle(143, 124, 40, 25, 0xffffff, 0x0f0957)
            rect15 = Widgets.Rectangle(186, 124, 40, 25, 0xffffff, 0x0f0957)
            rect16 = Widgets.Rectangle(229, 124, 40, 25, 0xffffff, 0x0f0957)
            rect17 = Widgets.Rectangle(143, 152, 40, 25, 0xffffff, 0x0f0957)
            rect18 = Widgets.Rectangle(186, 152, 40, 25, 0xffffff, 0x0f0957)
            rect19 = Widgets.Rectangle(229, 152, 40, 25, 0xffffff, 0x0f0957)
            label7 = Widgets.Label("A", 159, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
            label8 = Widgets.Label("B", 202, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
            label9 = Widgets.Label("C", 243, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
            label10 = Widgets.Label("K4", 112, 74, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
            label11 = Widgets.Label("K3", 113, 102, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
            label12 = Widgets.Label("K2", 113, 129, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
            label13 = Widgets.Label("K1", 113, 157, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
            LA_4 = LabelPlus("0,0", 153, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
            LA_3 = LabelPlus("0,0", 153, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
            LA_2 = LabelPlus("0,0", 153, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
            LA_1 = LabelPlus("0,0", 153, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
            LB_4 = LabelPlus("0,0", 195, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
            LB_3 = LabelPlus("0,0", 195, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
            LB_2 = LabelPlus("0,0", 195, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
            LB_1 = LabelPlus("0,0", 195, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
            LC_4 = LabelPlus("0,0", 239, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
            LC_3 = LabelPlus("0,0", 239, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
            LC_2 = LabelPlus("0,0", 239, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
            LC_1 = LabelPlus("0,0", 239, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
            i2c1 = I2C(1, scl=Pin(22), sda=Pin(21), freq=100000)
            t_values = bytearray(12)
            enc_mode = 0
            curr_value = 0
            INT_clock = 0
            encoder_0 = EncoderUnit(i2c1, 0x40)
            def loop():
            M5.update()
            time.sleep_us(20)
            if INT_clock == 0:
            time.sleep_ms(99)
            INT_clock = INT_clock + 1
            l_enc_inc = encoder_0.get_rotary_increments()
            if encoder_0.get_button_status():
            encoder_0.fill_color(0x990000)
            enc_mode = 1
            if l_enc_inc != 0:
            curr_value = curr_value + l_enc_inc
            while curr_value < 0:
            curr_value = curr_value + 12
            while curr_value > 11:
            curr_value = curr_value - 12
            else:
            encoder_0.fill_color(0x000066)
            enc_mode = 0
            if l_enc_inc != 0:
            loc_value = t_values[int(curr_value - 1)] + l_enc_inc
            if loc_value < 0:
            loc_value = 0
            if loc_value > 99:
            loc_value = 99
            t_values[int(curr_value - 1)] = loc_value
            if curr_value==0:
            LA_4.setText(str(((str((loc_value / 10))).strip())))
            elif curr_value==1:
            LA_3.setText(str(((str((loc_value / 10))).strip())))
            elif curr_value==2:
            LA_2.setText(str(((str((loc_value / 10))).strip())))
            elif curr_value==3:
            LA_1.setText(str(((str((loc_value / 10))).strip())))
            elif curr_value==4:
            LB_4.setText(str(((str((loc_value / 10))).strip())))
            elif curr_value==5:
            LB_3.setText(str(((str((loc_value / 10))).strip())))
            elif curr_value==6:
            LB_2.setText(str(((str((loc_value / 10))).strip())))
            elif curr_value==7:
            LB_1.setText(str(((str((loc_value / 10))).strip())))
            elif curr_value==8:
            LC_4.setText(str(((str((loc_value / 10))).strip())))
            elif curr_value==9:
            LC_3.setText(str(((str((loc_value / 10))).strip())))
            elif curr_value==10:
            LC_2.setText(str(((str((loc_value / 10))).strip())))
            elif curr_value==11:
            LC_1.setText(str(((str((loc_value / 10))).strip())))
            else:
            pass
            if name == 'main':
            try:
            setup()
            while True:
            loop()
            try:
            print_error_msg(e)
            except ImportError:
            • kurikoK Offline
              kuriko @kmk68
              @kmk68
              Can you export .m5f2 file on UiFlow2?
                Calvorotas
                I have problems with UiFlow 2.2.0.
                I could use BLE with UiFlow 2.1.8, but the same program doesn't run in 2.2.0.
                The progam can't start. The device return at Uiflow main menu.
                I have update UiFlow in the devices (Core M5stack and StickC, but I have the same problem.
                Thanks.
                C kurikoK 2 Replies Last reply Reply Quote 0
                  Calvorotas @Calvorotas
                  @Calvorotas
                  Another program without BLE.
                  I am not using MQTT in this program.
                  Thanks.
                  • kurikoK Offline
                    kuriko @Calvorotas
                    @Calvorotas
                    can you provide the .m5f2 file? imma do a test to check out if it's a firmware problem
                    nmstackN C 2 Replies Last reply Reply Quote 0
                    • _ Offline
                      _e3e6
                      Same issue here with Atom Echo and the Web UIFlow 2.0
                      https://gist.github.com/e3e6/f8558f8487dad2fe8909c8dc17b80888
                      • nmstackN Offline
                        nmstack @kuriko
                        @kuriko
                        There is a few days ago, I wrote a similar trouble. My message was…
                        I didn't think that I could feel so interested about this system! Sorry for my questions about, because I'm very unexpert.
                        I'm math teacher in secondary in Spain, and I want to prepare a trigonometric practice very simple.
                        I've used a potenciometer (angle unit), PaHUB, PbHUB, 8servos unit, and two servos: one 360º limited, and another one, 360º unlimited. Until this moment, all was right. But, I've done some little changes, I wasn't conscient that, when I erased the PaHUB unit, and I added another one, some address changed. I reviewed all the program, and I think that it should run. But, I don't know why now, when my program is running, at the end of compilation, it appears this message "E (112496) i2c: i2c driver install error".
                        Thank you for your attention
                        Please, does someone aid me?
                        Thank you for my poor English. Best regards!
                        Neus
                        Neus Morlà
                          Calvorotas @kuriko
                          @kuriko
                          This is the file.
                          1 Reply Last reply Reply Quote 4
                            Hulkco @kuriko
                            @kuriko Several months have passed since this post, but the error persists. Do you really plan to fix it?!
                            M 1 Reply Last reply Reply Quote 2
                              mearsuit @Hulkco
                              yep...Same problem, i cant upload any python code without getting this error. Its a shame because its a really neat dev board and i really wish the people at m5stack would fix this problem. They would begin to see more projects being posted on the m5burner and it would only help their sales. Screenshot_2025-09-25_18-21-33.png
                              robskiR 1 Reply Last reply Reply Quote 1
                              • robskiR Offline
                                robski @mearsuit
                                @mearsuit i see this error from some time but projects are working ok
