i2c driver install error
i dont know how to fix it, ive tried two versions of uiflow and theres nothing on youtube or google or any stuff like that. any help?
@LucidXVR
known issue, seems doesn't affect anything, will fix it soon -
F felmue referenced this topic on
@kuriko Yes, it affects. The program does not start on my M5 Core after this message....
@kmk68
Are you able to show your code? -
@kuriko it's created by block editing...
import os, sys, io
import M5
from M5 import *
from label_plus import LabelPlus
from hardware import *
import time
from unit import EncoderUnitlabel0 = None
label1 = None
label2 = None
label3 = None
BtnA = None
BtnB = None
BtnC = None
rect0 = None
rect1 = None
rect2 = None
rect3 = None
rect4 = None
rect5 = None
rect6 = None
rect7 = None
rect8 = None
rect9 = None
rect10 = None
rect11 = None
rect12 = None
rect13 = None
rect14 = None
rect15 = None
rect16 = None
rect17 = None
rect18 = None
rect19 = None
label7 = None
label8 = None
label9 = None
label10 = None
label11 = None
label12 = None
label13 = None
LA_4 = None
LA_3 = None
LA_2 = None
LA_1 = None
LB_4 = None
LB_3 = None
LB_2 = None
LB_1 = None
LC_4 = None
LC_3 = None
LC_2 = None
LC_1 = None
pin3 = None
pin1 = None
pin2 = None
pin5 = None
i2c1 = None
pin25 = None
pin26 = None
pin35 = None
pin36 = None
encoder_0 = Nonel_enc_inc = None
INT_clock = None
t_values = None
enc_mode = None
curr_value = None
loc_value = NoneDescribe this function...
def init_all_out_pins_as_():
global l_enc_inc, INT_clock, t_values, enc_mode, curr_value, loc_value, label0, label1, label2, label3, BtnA, BtnB, BtnC, rect0, rect1, rect2, rect3, rect4, rect5, rect6, rect7, rect8, rect9, rect10, rect11, rect12, rect13, rect14, rect15, rect16, rect17, rect18, rect19, label7, label8, label9, label10, label11, label12, label13, LA_4, LA_3, LA_2, LA_1, LB_4, LB_3, LB_2, LB_1, LC_4, LC_3, LC_2, LC_1, pin3, pin1, pin2, pin5, i2c1, pin25, pin26, pin35, pin36, encoder_0
pin3 = Pin(3, mode=Pin.OUT, pull=Pin.PULL_UP)
pin1 = Pin(1, mode=Pin.OUT, pull=Pin.PULL_UP)
pin2 = Pin(2, mode=Pin.OUT, pull=Pin.PULL_UP)
pin5 = Pin(5, mode=Pin.OUT, pull=Pin.PULL_UP)
pin25 = Pin(25, mode=Pin.OUT, pull=Pin.PULL_UP)
pin26 = Pin(26, mode=Pin.OUT, pull=Pin.PULL_UP)
pin35 = Pin(35, mode=Pin.OUT, pull=Pin.PULL_UP)
pin36 = Pin(36, mode=Pin.OUT, pull=Pin.PULL_UP)Describe this function...
def relay_outs_pin_set():
if t_values[-1] == INT_clock:
pin3.value(1)
if t_values[0] == INT_clock:
pin1.value(1)
if t_values[1] == INT_clock:
pin2.value(1)
if t_values[2] == INT_clock:
pin5.value(1)
if t_values[3] == INT_clock:
pin25.value(1)
if t_values[4] == INT_clock:
pin26.value(1)
if t_values[5] == INT_clock:
pin35.value(1)
if t_values[6] == INT_clock:
pin36.value(1)
if t_values[7] == INT_clock:
pin25.value(0)
if t_values[8] == INT_clock:
pin26.value(0)
if t_values[9] == INT_clock:
pin35.value(0)
if t_values[10] == INT_clock:
pin36.value(0)
if t_values[7] + 25 == INT_clock:
pin3.value(0)
if t_values[8] + 25 == INT_clock:
pin1.value(0)
if t_values[9] + 25 == INT_clock:
pin2.value(0)
if t_values[10] + 25 == INT_clock:
pin5.value(0)Describe this function...
def all_out_pins_to_zero():
pin3.value(0)
pin1.value(0)
pin2.value(0)
pin5.value(0)
pin25.value(0)
pin26.value(0)
pin35.value(0)
pin36.value(0)def setup():
global label0, label1, label2, label3, BtnA, BtnB, BtnC, rect0, rect1, rect2, rect3, rect4, rect5, rect6, rect7, rect8, rect9, rect10, rect11, rect12, rect13, rect14, rect15, rect16, rect17, rect18, rect19, label7, label8, label9, label10, label11, label12, label13, LA_4, LA_3, LA_2, LA_1, LB_4, LB_3, LB_2, LB_1, LC_4, LC_3, LC_2, LC_1, pin3, pin1, pin2, pin5, i2c1, pin25, pin26, pin35, pin36, encoder_0, l_enc_inc, INT_clock, t_values, enc_mode, curr_value, loc_valueM5.begin()
Widgets.fillScreen(0x222222)
label0 = Widgets.Label("Key 1", 4, 185, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
label1 = Widgets.Label("Key 1", 4, 135, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
label2 = Widgets.Label("Key 2", 5, 85, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
label3 = Widgets.Label("Key 4", 5, 35, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
BtnA = Widgets.Label("A", 60, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
BtnB = Widgets.Label("B", 150, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
BtnC = Widgets.Label("C", 240, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
rect0 = Widgets.Rectangle(100, 40, 40, 25, 0xffffff, 0x0f0957)
rect1 = Widgets.Rectangle(143, 40, 40, 25, 0xffffff, 0x0f0957)
rect2 = Widgets.Rectangle(186, 40, 40, 25, 0xffffff, 0x0f0957)
rect3 = Widgets.Rectangle(229, 40, 40, 25, 0xffffff, 0x0f0957)
rect4 = Widgets.Rectangle(100, 68, 40, 25, 0xffffff, 0x0f0957)
rect5 = Widgets.Rectangle(143, 68, 40, 25, 0xffffff, 0x0f0957)
rect6 = Widgets.Rectangle(186, 68, 40, 25, 0xffffff, 0x0f0957)
rect7 = Widgets.Rectangle(229, 68, 40, 25, 0xffffff, 0x0f0957)
rect8 = Widgets.Rectangle(100, 96, 40, 25, 0xffffff, 0x0f0957)
rect9 = Widgets.Rectangle(100, 124, 40, 25, 0xffffff, 0x0f0957)
rect10 = Widgets.Rectangle(100, 152, 40, 25, 0xffffff, 0x0f0957)
rect11 = Widgets.Rectangle(143, 96, 40, 25, 0xffffff, 0x0f0957)
rect12 = Widgets.Rectangle(186, 96, 40, 25, 0xffffff, 0x0f0957)
rect13 = Widgets.Rectangle(229, 96, 40, 25, 0xffffff, 0x0f0957)
rect14 = Widgets.Rectangle(143, 124, 40, 25, 0xffffff, 0x0f0957)
rect15 = Widgets.Rectangle(186, 124, 40, 25, 0xffffff, 0x0f0957)
rect16 = Widgets.Rectangle(229, 124, 40, 25, 0xffffff, 0x0f0957)
rect17 = Widgets.Rectangle(143, 152, 40, 25, 0xffffff, 0x0f0957)
rect18 = Widgets.Rectangle(186, 152, 40, 25, 0xffffff, 0x0f0957)
rect19 = Widgets.Rectangle(229, 152, 40, 25, 0xffffff, 0x0f0957)
label7 = Widgets.Label("A", 159, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
label8 = Widgets.Label("B", 202, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
label9 = Widgets.Label("C", 243, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
label10 = Widgets.Label("K4", 112, 74, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
label11 = Widgets.Label("K3", 113, 102, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
label12 = Widgets.Label("K2", 113, 129, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
label13 = Widgets.Label("K1", 113, 157, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
LA_4 = LabelPlus("0,0", 153, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
LA_3 = LabelPlus("0,0", 153, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
LA_2 = LabelPlus("0,0", 153, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
LA_1 = LabelPlus("0,0", 153, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
LB_4 = LabelPlus("0,0", 195, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
LB_3 = LabelPlus("0,0", 195, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
LB_2 = LabelPlus("0,0", 195, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
LB_1 = LabelPlus("0,0", 195, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
LC_4 = LabelPlus("0,0", 239, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
LC_3 = LabelPlus("0,0", 239, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
LC_2 = LabelPlus("0,0", 239, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
LC_1 = LabelPlus("0,0", 239, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)init_all_out_pins_as_()
i2c1 = I2C(1, scl=Pin(22), sda=Pin(21), freq=100000)
t_values = bytearray(12)
enc_mode = 0
curr_value = 0
INT_clock = 0
encoder_0 = EncoderUnit(i2c1, 0x40)def loop():
M5.update()
time.sleep_us(20)
if INT_clock == 0:
time.sleep_ms(99)
INT_clock = INT_clock + 1
l_enc_inc = encoder_0.get_rotary_increments()
if encoder_0.get_button_status():
encoder_0.fill_color(0x990000)
enc_mode = 1
if l_enc_inc != 0:
curr_value = curr_value + l_enc_inc
while curr_value < 0:
curr_value = curr_value + 12
while curr_value > 11:
curr_value = curr_value - 12
else:
encoder_0.fill_color(0x000066)
enc_mode = 0
if l_enc_inc != 0:
loc_value = t_values[int(curr_value - 1)] + l_enc_inc
if loc_value < 0:
loc_value = 0
if loc_value > 99:
loc_value = 99
t_values[int(curr_value - 1)] = loc_value
if curr_value==0:
LA_4.setText(str(((str((loc_value / 10))).strip())))
elif curr_value==1:
LA_3.setText(str(((str((loc_value / 10))).strip())))
elif curr_value==2:
LA_2.setText(str(((str((loc_value / 10))).strip())))
elif curr_value==3:
LA_1.setText(str(((str((loc_value / 10))).strip())))
elif curr_value==4:
LB_4.setText(str(((str((loc_value / 10))).strip())))
elif curr_value==5:
LB_3.setText(str(((str((loc_value / 10))).strip())))
elif curr_value==6:
LB_2.setText(str(((str((loc_value / 10))).strip())))
elif curr_value==7:
LB_1.setText(str(((str((loc_value / 10))).strip())))
elif curr_value==8:
LC_4.setText(str(((str((loc_value / 10))).strip())))
elif curr_value==9:
LC_3.setText(str(((str((loc_value / 10))).strip())))
elif curr_value==10:
LC_2.setText(str(((str((loc_value / 10))).strip())))
elif curr_value==11:
LC_1.setText(str(((str((loc_value / 10))).strip())))
else:
passif name == 'main':
try:
setup()
while True:
loop()
try:
print_error_msg(e)
except ImportError:
print("please update to latest firmware") -
@kmk68
Can you export .m5f2 file on UiFlow2? -
I have problems with UiFlow 2.2.0.
I could use BLE with UiFlow 2.1.8, but the same program doesn't run in 2.2.0.
The progam can't start. The device return at Uiflow main menu.
I have update UiFlow in the devices (Core M5stack and StickC, but I have the same problem.
Thanks.
@Calvorotas
can you provide the .m5f2 file? imma do a test to check out if it's a firmware problem -
Same issue here with Atom Echo and the Web UIFlow 2.0
https://gist.github.com/e3e6/f8558f8487dad2fe8909c8dc17b80888
There is a few days ago, I wrote a similar trouble. My message was…
I didn't think that I could feel so interested about this system! Sorry for my questions about, because I'm very unexpert.
I'm math teacher in secondary in Spain, and I want to prepare a trigonometric practice very simple.
I've used a potenciometer (angle unit), PaHUB, PbHUB, 8servos unit, and two servos: one 360º limited, and another one, 360º unlimited. Until this moment, all was right. But, I've done some little changes, I wasn't conscient that, when I erased the PaHUB unit, and I added another one, some address changed. I reviewed all the program, and I think that it should run. But, I don't know why now, when my program is running, at the end of compilation, it appears this message "E (112496) i2c: i2c driver install error".
Thank you for your attention
Please, does someone aid me?
Thank you for my poor English. Best regards!
Neus
@kuriko Several months have passed since this post, but the error persists. Do you really plan to fix it?!
