    m5stickc plus 2 cannot be flashed
    5 Posts 4 Posters 5.1k Views
      Fedor_bug
      I bought m5stickc plus 2 quite recently, I started testing different firmware, first marauder, then decided to download nemo, but after installing nemo, the screen stopped going out, and now when connecting and trying to flash it, it gives an error
      etc Jul 29 2019 12:21:46
      rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
      waiting for download
      And also writes: you must log in before using this firmware
      please help me, I have not found any information about this anywhere, and I do not have special programming skills (((
      • robskiR Offline
        robski
        Open M5Burner, log in to your M5stack account, pick M5StickCplus2 latest firmware, choose right com port press burn, or you can do erase and then burn.
          Fedor_bug @robski
          @robski Thanks, it helped
          • B Offline
            bbarker23
            im trying to flash but it keeps saying this
            Detecting chip type...
            ESP32
            Chip is ESP32-PICO-V3-02 (revision v3.1)
            Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, Embedded PSRAM, VRef calibration in efuse, Coding Scheme None
            Crystal is 40MHz
            MAC: 14:2b:2f:b2:0b:14
            Uploading stub...
            Note: If issues persist, try installing the WCH USB-to-Serial MacOS driver.
            A fatal error occurred: Failed to write to target RAM (result was 01070000: Operation timed out)
              ajb2k3 @bbarker23
              @bbarker23 well, have you tried installing the driver?
