    CoreMP135 Debian image
    46 Posts 8 Posters 62.0k Views 4 Watching
      aradke @flypeek
      @flypeek Please note that the issue is that files and folders are owned by UID 1000 not UID 0.
      You are asking about a completely different thing. Whether I access the command prompt by the console or SSH won't change the fact that file permissions and ownerships are incorrect. Whether I am logged in as root, or an unprivileged user, or as a user that has used sudo / su to elevate to root privileges isn't relevant to incorrect permissions.
      An example is that timedatectl won't function properly because certain files under /etc are not owned by root. Correcting the permissions is possible and it fixes it, but the entire OS image has files all over the place owned by UID 1000. At this point it would be more reasonable to recreate the image than to try to check every file.
        aradke @ajb2k3
        @ajb2k3 Thanks. :-)
        Probably not a help in this case as we're wanting to fix or recreate the base Debian 12 image.
        The file system ownerships being incorrect is the first big hurdle. But we also have a couple of USB devices that need a newer Linux kernel and would like to be able to create test images with newer kernels if possible.
          Ok I will work on the image side next and see if I can solve a few things. I know SUDO isn’t installed but yet referance is made to it.
            The source is located here but I'm going crosseyed from looking through it.
            I can see how to set the file and directory permissions but not where they are set.
            It looks to be a build root version of archlinux
              aradke @ajb2k3
              @ajb2k3 sudo isn't included on a minimal Debian installation. It's usually the very first things that we install so that the rest of the system can be fully configured by Ansible.
                aradke @ajb2k3
                @ajb2k3 if you are building the base filesystem inside a chroot environment then you should be able to install packages as normal via apt.
                The permissions from the original source should be fine, and apt will make sure any further permissions are also correct. Going back to fix already damaged permissions would be difficult and it would be very easy to miss something.
                  ajb2k3 @aradke
                  @aradke said in CoreMP135 Debian image:
                  That's why I spent last night going through the source so I could find where these are set. I could not find the config for the directory like /etc.
                  Ah it's the host system that set the file permissions.
                  When the image was generated it wasn't compiled under root so directorys weren't set as root but to the permissions of the host.
                  The image need to be re generated as root.
                    aradke @ajb2k3
                    @ajb2k3 :-)
                    When creating Linux container templates the same issue can arise. If you do any part of it as a non-root account the file and directory ownerships will all end up being the same as the UID you are currently working with instead of as root, etc.
                    Sometimes things will appear to function okay for a while but if a directory is meant to be owned by a non-root account, such as www-data, then anything using it will completely fail.
                    Is there any chance you'll be able to document the procedure for creating the image? It would be very, very good to be able to create customised ones and to test different kernels.
                      ajb2k3 @aradke
                      @aradke that’s what I’m doing at the moment. I am taking to the programmer about how to build the image
                        prima @ajb2k3
                        I am currently writing an Ansible playbook to automate the customization of my device, and some things like setting the time zone don't work for the reason described above. Hopefully this can get fixed soon.
                        I am also working on the LCD screen, as I would prefer to use Python rather than the proposed C environment.
                          ajb2k3 @prima
                          @prima well currently I'm trying to get the code to compile following the online instructions but they dont work
                            ajb2k3 @ajb2k3
                            Ah ha I got it to compile, the instructions are wrong.
                            You need to run
                            make BR2_EXTERNAL=../CoreMP135_buildroot-external-st/ m5stack_coremp135_515_defconfig
                            make -j4
                            To get it to compile.
                            I'm Using a CM4Stack so its slow going.
                            The issue turns out to be a typo in the line. The guide says /Core135_ but the command is actually CoreMP135
                              prima
                              On a side note and not sure this is a related issue, but I can't seem to shut down the device cleanly. I have tried: shutdown, poweroff, halt and the device always reboots instead of shutting down.
                                ajb2k3 @prima
                                @prima yeh I noticed that too after issuing the Shutdown now command.
                                • N Offline
                                  nnn @ajb2k3
                                  A script to build Debian image is now available in the M5Stack repository.
                                  • CoreMP135_buildroot-external-st
                                    https://github.com/m5stack/CoreMP135_buildroot-external-st/blob/st/2023.02.10/tools/creat_coremp135_debian12_image.sh
                                  • How to implement (Japanese)
                                    https://qiita.com/nnn112358/items/44921e2470353653058e
                                  ajb2k3A M 2 Replies Last reply Reply Quote 0
                                    ajb2k3 @nnn
                                    @nnn said in CoreMP135 Debian image:
                                    Nice
                                      mgrouch @nnn
                                      @nnn
                                      Is there Debian image for CoreMP135 which includes kernel built with all drivers for hardware interfaces of CoreMP135.
                                      I’m considering buying that CoreMP135 and
                                      I need to make sure I will be able to use CAN Bus interfaces, i2c, uart, USB, Bluetooth, RS485, Both Ethernets and WiFi, as well as
                                      touchscreen of CoreMP135 with the Debian image provided.
                                      When it boots, does it boot into some kind of framebuffer LVGL GUI on 2” touchscreen?
                                      Is there code example how to do that?
                                      Or CoreMP135 is sold as hardware platform and users are left to build own Linux kernel and Debian images to support hardware CoreMP135?
                                      Or there is a Debian image which fully supports
                                      CoreMP135 Hardware and all interfaces?
                                      Hardware is not much of use for me if there is no software with drivers supporting it.
                                      Thanks!
                                      P teastainT 2 Replies Last reply Reply Quote 0
                                        prima @mgrouch
                                        @mgrouch said in CoreMP135 Debian image:
                                        AFAIK there is no wifi/BT on this device. Dual ethernet works using the available Debian image though. That image has some defects but I guess this is being sorted out.
                                        You can now build your own image (see post above) but I haven't tried that yet.
                                        • I have not tried the CAN bus and the other interfaces.
                                        • USB: seems to work, but I only plugged in a mouse and keyboard
                                        • The serial console works over USB-C and I also use the USB-C cable to power the device from my PC.
                                        If that can help: I recently posted on how to develop Python apps in GTK or QT, using the frame buffer with Xorg/Openbox.
                                        This is roughly the approach I have used for developing on Raspberry PI and other SBCs.
                                        The touch screen work without problem for me.
                                        • teastainT Offline
                                          teastain @mgrouch
                                          @mgrouch https://github.com/m5stack/M5Stack_Linux_Libs
                                          The Official M5Stack CoreMP135 library repository.
                                            mgrouch @prima
                                            @prima said in CoreMP135 Debian image:
                                            Ok. No wifi or bt is not an issue for me as long as Ethernet works.
                                            Is it working as DHCP client? I mean it’s just plug into router and I could ssh?
                                            I do care about working CAN, i2c, UART, and RS-485 out of the box with provided Debian image.
                                            Does anyone have experiences with those interfaces on CoreMP135 with their provided OS image?
