    Connecting Env Unit and RFID Unit via Grove Hub on M5StickC
    12 Posts 4 Posters 22.5k Views 1 Watching
    • W Offline
      ws1088
      It looks like Env unit has 2 I2C addresses (92, 118)? But many times 92 will go away in the scan loop. Strange...
        All I can think is that the two sensors are drawing too much power for the bus.
        I have both units and also the hat versions. if I find time over the week end I may have some time to test but I may need a reminder on saturday.
        Double check the address's. The published addresses are in Hex but they are displayed in binary on the screen!
          ajb2k3 @ws1088
          @ws1088 Confirmed, the RFID Unit will not work with the ENV unit and will not work with the ENV hat
          W 2 Replies Last reply Reply Quote 0
          • W Offline
            ws1088 @ajb2k3
            @ajb2k3 said in Connecting Env Unit and RFID Unit via Grove Hub on M5StickC:
            Is the reason as you mentioned that there is not enough power? I guess not because you test it on the ENV hat with RFID unit. I noticed a lot of bus error (timeout), maybe it's a software issue? I am using UIFlow, btw. Are you using Arduino IDE and C++?
              ajb2k3 @ws1088
              @ws1088 said in Connecting Env Unit and RFID Unit via Grove Hub on M5StickC:
              Nope, only UIFlow as I'm trying to write the book on it.
              • W Offline
                ws1088 @ajb2k3
                Could this be related?
                http://community.m5stack.com/topic/523/problems-with-the-i2c-grove-interface
                • W Offline
                  ws1088 @ajb2k3
                  wow, RFID unit will not work with ENV hat even? I though RFID unit is I2C (G32 and G33) and ENV hat is on G26 and G36...
                    ajb2k3 @ws1088
                    I could not get them to work together but then i am not a good programmer.
                      maknis3
                      Fellow users from the past, I encountered the same problem but managed to get it working. The problem lies in the paralell access of the RFID and ENV module. If the access is isolated in a paralell process and saved in to variables, further getting the values by using these variables, you should be able to use the two modules in unison.
                      • robskiR Offline
                        robski @ws1088
                        I use the following code to test:
                        from m5stack import *
                        from m5ui import *
                        from uiflow import *
                        import i2c_bus
                        setScreenColor(0x111111)
                        devices = None
                        scan = None
                        i2c0 = i2c_bus.easyI2C(i2c_bus.PORTA, 0x68)
                        devices = []
                        while True:
                          scan = i2c0.scan()
                          if devices != scan:
                            lcd.clear()
                            lcd.print(str(scan), 0, 0, 0xffffff)
                          devices = scan
                          wait_ms(2)
                        I can see the I2C addresses for the Env unit and RFID unit combinations when I plug them into the Grove Hub. I can plug the Env unit in to see addresses 92 and 118, then add RFID unit to see [40, 92, 118] etc.
                        So I am pretty clueless why the following will fail:
                        rfid0 = unit.get(unit.RFID, unit.PORTA)
                        env1 = unit.get(unit.ENV, unit.PORTA)
                        Looks like I need to go to the source code and see what's going on...
                        are modules working ok on their own and you see issue when both connected?
