    Connecting Env Unit and RFID Unit via Grove Hub on M5StickC
    12 Posts 4 Posters 22.5k Views 1 Watching
    • W Offline
      ws1088
      I use the following code to test:
      from m5stack import *
      from m5ui import *
      from uiflow import *
      import i2c_bus
      setScreenColor(0x111111)
      devices = None
      scan = None
      i2c0 = i2c_bus.easyI2C(i2c_bus.PORTA, 0x68)
      devices = []
      while True:
        scan = i2c0.scan()
        if devices != scan:
          lcd.clear()
          lcd.print(str(scan), 0, 0, 0xffffff)
        devices = scan
        wait_ms(2)
      I can see the I2C addresses for the Env unit and RFID unit combinations when I plug them into the Grove Hub. I can plug the Env unit in to see addresses 92 and 118, then add RFID unit to see [40, 92, 118] etc.
      So I am pretty clueless why the following will fail:
      rfid0 = unit.get(unit.RFID, unit.PORTA)
      env1 = unit.get(unit.ENV, unit.PORTA)
      Looks like I need to go to the source code and see what's going on...
      • W Offline
        ws1088
        It looks like Env unit has 2 I2C addresses (92, 118)? But many times 92 will go away in the scan loop. Strange...
          All I can think is that the two sensors are drawing too much power for the bus.
          I have both units and also the hat versions. if I find time over the week end I may have some time to test but I may need a reminder on saturday.
          Double check the address's. The published addresses are in Hex but they are displayed in binary on the screen!
            ajb2k3 @ws1088
            @ws1088 Confirmed, the RFID Unit will not work with the ENV unit and will not work with the ENV hat
            W 2 Replies Last reply Reply Quote 0
            • W Offline
              ws1088 @ajb2k3
              @ajb2k3 said in Connecting Env Unit and RFID Unit via Grove Hub on M5StickC:
              Is the reason as you mentioned that there is not enough power? I guess not because you test it on the ENV hat with RFID unit. I noticed a lot of bus error (timeout), maybe it's a software issue? I am using UIFlow, btw. Are you using Arduino IDE and C++?
                ajb2k3 @ws1088
                @ws1088 said in Connecting Env Unit and RFID Unit via Grove Hub on M5StickC:
                Nope, only UIFlow as I'm trying to write the book on it.
                • W Offline
                  ws1088 @ajb2k3
                  Could this be related?
                  http://community.m5stack.com/topic/523/problems-with-the-i2c-grove-interface
                  • W Offline
                    ws1088 @ajb2k3
                    wow, RFID unit will not work with ENV hat even? I though RFID unit is I2C (G32 and G33) and ENV hat is on G26 and G36...
                      ajb2k3 @ws1088
                      I could not get them to work together but then i am not a good programmer.
                        maknis3
                        Fellow users from the past, I encountered the same problem but managed to get it working. The problem lies in the paralell access of the RFID and ENV module. If the access is isolated in a paralell process and saved in to variables, further getting the values by using these variables, you should be able to use the two modules in unison.
                        • robskiR Offline
                          robski @ws1088
                          from m5ui import *
                          import i2c_bus
                          devices = None
                          scan = None
                          devices = []
                          while True:
                            scan = i2c0.scan()
                            if devices != scan:
                              lcd.clear()
                            devices = scan
                            wait_ms(2)
                          are modules working ok on their own and you see issue when both connected?
