    UIFlow 2.0.2 firmware preview version
    14 Posts 9 Posters 32.7k Views 2 Watching
      mory
      会支持tab控件吗?
        mm-uiflow
        how is the status of this? is the update comming soon? is it stable yet?
        • m5stackM Offline
          m5stack @mory
          @mory
          uiflow-lvgl-2.0-xxx 会支持lvgl的所有控件(应该)
          • m5stackM Offline
            m5stack @mm-uiflow
            @mm-uiflow
            Sorry, still under developing, UIFlow 2.0 it's big project, not only the firmware.
              Hello @m5stack
              anything the M5Stack community can help with?
                Costas
                Trying to get I2C to work on the new firmware. I have M5's SGP30 sensor. MicroPython is not detecting anything plugged in. Guidance?
                from machine import SoftI2C, Pin
                i2c = SoftI2C(sda=machine.Pin(21),scl=machine.Pin(22),freq=100000)
                devices = i2c.scan()
                devices = [52, 53, 56, 81, 104], the SGP30 should be on 58, right?
                  ajb2k3 @Costas
                  @costas softI2c?
                  Use I2C not softI2c
                    Costas
                    Same results.
                    from machine import I2C, Pin
                    i2c = I2C(scl=Pin(22), sda=Pin(21), freq=100000)
                    i2c.scan()
                      Hello @Costas
                      from the scan result I suspect you are using an M5Core2, correct?
                      The M5Core2 has an internal (GPIO21/22) and an external (GPIO32/33) I2C bus.
                      Right now your code scans the internal I2C bus, but the SGP30 is connected to port A (external I2C bus), so you need to change your code to scan the external I2C bus.
                      • IAMLIUBOI Offline
                        IAMLIUBO
                        THIS TOPIC WAS ABANDONED.
                        Please check this new topic and discuss。
