    UIFlow 2.0.2 firmware preview version
    14 Posts 9 Posters 33.4k Views 2 Watching
      M5Stack_AG @Zetabyte
      @zetabyte Hi there, please wait for the UIflow 2.0
        mory
        会支持tab控件吗?
          mm-uiflow
          how is the status of this? is the update comming soon? is it stable yet?
          • m5stackM Offline
            m5stack @mory
            @mory
            uiflow-lvgl-2.0-xxx 会支持lvgl的所有控件(应该)
            • m5stackM Offline
              m5stack @mm-uiflow
              @mm-uiflow
              Sorry, still under developing, UIFlow 2.0 it's big project, not only the firmware.
                Hello @m5stack
                anything the M5Stack community can help with?
                  Costas
                  Trying to get I2C to work on the new firmware. I have M5's SGP30 sensor. MicroPython is not detecting anything plugged in. Guidance?
                  from machine import SoftI2C, Pin
                  i2c = SoftI2C(sda=machine.Pin(21),scl=machine.Pin(22),freq=100000)
                  devices = i2c.scan()
                  devices = [52, 53, 56, 81, 104], the SGP30 should be on 58, right?
                    ajb2k3 @Costas
                    @costas softI2c?
                    Use I2C not softI2c
                      Costas
                      Same results.
                      from machine import I2C, Pin
                      i2c = I2C(scl=Pin(22), sda=Pin(21), freq=100000)
                      i2c.scan()
                        Hello @Costas
                        from the scan result I suspect you are using an M5Core2, correct?
                        The M5Core2 has an internal (GPIO21/22) and an external (GPIO32/33) I2C bus.
                        Right now your code scans the internal I2C bus, but the SGP30 is connected to port A (external I2C bus), so you need to change your code to scan the external I2C bus.
                        • IAMLIUBOI Offline
                          IAMLIUBO
                          THIS TOPIC WAS ABANDONED.
                          Please check this new topic and discuss。
