    UIFlow 2.0.2 firmware preview version
    14 Posts 9 Posters 32.7k Views 2 Watching
    • Z Offline
      Zetabyte
      Found a bug.
      >>> import io
      ValueError: incompatible .mpy file
      Edit: It helped to delete the io.mpy file under libs/micropython
        M5Stack_AG @Zetabyte
        @zetabyte Hi there, please wait for the UIflow 2.0
          mory
          会支持tab控件吗?
            mm-uiflow
            how is the status of this? is the update comming soon? is it stable yet?
            • m5stackM Offline
              m5stack @mory
              @mory
              uiflow-lvgl-2.0-xxx 会支持lvgl的所有控件(应该)
              • m5stackM Offline
                m5stack @mm-uiflow
                @mm-uiflow
                Sorry, still under developing, UIFlow 2.0 it's big project, not only the firmware.
                  Hello @m5stack
                  anything the M5Stack community can help with?
                    Costas
                    Trying to get I2C to work on the new firmware. I have M5's SGP30 sensor. MicroPython is not detecting anything plugged in. Guidance?
                    from machine import SoftI2C, Pin
                    i2c = SoftI2C(sda=machine.Pin(21),scl=machine.Pin(22),freq=100000)
                    devices = i2c.scan()
                    devices = [52, 53, 56, 81, 104], the SGP30 should be on 58, right?
                      ajb2k3 @Costas
                      @costas softI2c?
                      Use I2C not softI2c
                        Costas
                        Same results.
                        from machine import I2C, Pin
                        i2c = I2C(scl=Pin(22), sda=Pin(21), freq=100000)
                        i2c.scan()
                          Hello @Costas
                          from the scan result I suspect you are using an M5Core2, correct?
                          The M5Core2 has an internal (GPIO21/22) and an external (GPIO32/33) I2C bus.
                          Right now your code scans the internal I2C bus, but the SGP30 is connected to port A (external I2C bus), so you need to change your code to scan the external I2C bus.
                          • IAMLIUBOI Offline
                            IAMLIUBO
                            THIS TOPIC WAS ABANDONED.
                            Please check this new topic and discuss。
