    Stamp ext IO2 (SKU:S002) able to use individual pins, not just one mode for the whole board!
    Features Wish List
    12
    12.9k
    • teastainT
      teastain
      Currently it seems that the Stamp ext IO2 can only be in one mode for all pins, set by the command: (for example)
      extio_io_mode_t mode = DIGITAL_OUTPUT_MODE;
      or
      extio.setAllPinMode(RGB_LED_MODE);
      Also like the RGB mode to support a string, not just one SK6812.
      Thanks for listening.
      Terry
        ajb2k3 @teastain
        @teastain thanks, it’s sat on my bench waiting to be tested but been busy with writing up other documents
          Hello @teastain
          I've just created a pull-request in the github repository which adds a function to set the mode of a single pin.
            macsbug
            • teastainT
              teastain @macsbug
              Hi! @macsbug thanks for responding, I usually use the Adafruit library because it Works! Easily! Logically!
              Actually I'm referring to the Stamp io2 ext module which is accessed via I2C.
              The resident controller is an STM, the Stamp has to send the request through I2C and be executed by the STM !
              Terry
              • teastainT
                teastain @felmue
                @felmue Thanks Felix, I'll try it once The Powers That Be approve !!!
                Does it work for you?
                Thanks Terry
                  Hello @teastain
                  yes, it works for me. I've tested it with pin 2 as RGB output, pin 5 as digital output and the rest as digital inputs.
                      extio.setAllPinMode(DIGITAL_INPUT_MODE);
                      extio.setPinMode(2, RGB_LED_MODE);
                      extio.setPinMode(5, DIGITAL_OUTPUT_MODE);
                  P.S. be prepared that approval could take some time. In the past some of my pull-requests took almost a full year to be approved by M5Stack.
                    macsbug @teastain
                    @teastain
                    Hi! @teastain
                    I'm sorry.
                    I didn't understand the question.
                    Therefore, the post has been deleted.
                      Hello @teastain
                      FYI: I stand corrected. My pull-request already has been approved. Nicely done M5Stack.
                      teastainT 2 Replies Last reply Reply Quote 0
                      • teastainT
                        teastain @felmue
                        @felmue GOOD JOB!
                        I downloaded the new library and made a mixed program with one pin Output and another RGB...
                        Works perfectly. I studied your library...maybe next time I will try!
                        Much thanks, Terry
                        • teastainT
                          teastain @felmue
                          @felmue Hi Felix, me again.
                          Regarding the PaHub:
                          I found the Official M5Stack PaHub example to be of little help to write a useful project with 2 sensors with the same I2C address. I made this example very minimalist using a M5Stack Core Basic controller.
                          PaHub Example with 2 ENVII temperature sensors:
                          I put it on GitHub https://github.com/teastainGit/Simple-PaHub-example
                          Would you have time to look it over and "Maybe" submit it to M5Stack? To be added to their example for PaHub?
                          If not could you tell me how to submit it? I am asking you because you have a great reputation with them!!!
                          Cheers! Terry
                            Hello @teastain
                            your example looks fine to me. Nicely done.
                            Regarding submission: you can create a pull-request for yourself, inside the M5Stack repository, which adds your example and M5Stack engineers eventually will check it out.
