    new m5stack: Failed to write to target RAM (result was 01070000)
    22 Posts 13 Posters 69.7k Views 2 Watching
      Mackone @erich
      @erich I'm on Mojave 10.14 and problem still exists :/
        I’m actually getting it with Catalina
          slugs
          Has anyone managed to get the core 2 to work with an M1 mac? I think that you do not need the driver for the m1? With a m5stick C it works fine, but not with the core 2
          • ExieE Offline
            Exie
            I have the same issue when I use the M5Stack ESP32 Downloader.
            However when I use a simple M5Stack Atom Matrix, its works fine.
            I am on OSX Big Sir.
            I feel like the issue is related to the CH9102 chip on the ESP32 Downloader where the Atom has the CP2104 I think.
            This theory is supported by this article here:
            https://blog.squix.org/2021/08/ch9102-driver-issues-failed-to-write-to-target-ram.html
            Confirmed, installing the driver from this thread here worked for me
            https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139
            • E Offline
              erich @Exie
              @exie said in new m5stack: Failed to write to target RAM (result was 01070000):
              I guess you're right as I noticed on banggood/ aliexpress some products using this CH9102 chip are tagged as not Mac compatible.
              • L Offline
                labixiaoxin8888 @Mackone
                @mackone try connecting the downloader's 3V3 to Stamp Pico's 5V
                  parahooner
                  I found a solution that works on Montery :-)
                  Make sure you follow the PDF instructions, this works M1 Mac M5 Epaper
                  http://www.wch.cn/downloads/CH34XSER_MAC_ZIP.html
                  B 1 Reply Last reply Reply Quote 2
                  • B Offline
                    Bludotz @parahooner
                    @parahooner Very many thanks for posting this, it completely resolved the problem.
                    • drjakobD Offline
                      drjakob
                      I still have the same problem with 5 new M5Fire on Big Sur. Two older ones burned succesful.
                        ajb2k3 @drjakob
                        @drjakob Check which USB driver is in the new cores as the driver chip was changed due to the part shortage.
