    new m5stack: Failed to write to target RAM (result was 01070000)
    Bug Report
    13
    22
    68.2k
      ajb2k3 @darul75
      @darul75 said in new m5stack: Failed to write to target RAM (result was 01070000):
      I have installed latest driver https://www.silabs.com/documents/public/software/Mac_OSX_VCP_Driver.zip and can see the corresponding extension in /Library/Extensions with
      drwxr-xr-x@ 3 root wheel 96 Oct 15 10:46 SiLabsUSBDriver.kext
      but then when running M5Burner it only show a tty device of type Bluetooth or usb modem
      ls /dev/tty.*
      /dev/tty.Bluetooth-Incoming-Port
      /dev/tty.usbmodem51850037101
      I am running macOS Catalina
      /dev/tty.usbmodem51850037101 is the correct device, I'm not sure what's going on in OSX but this is how it appears for me and the device that works for me.
      • D
        darul75
        Great thanks, I will try again later, in the meantime I switched to a Windows machine to make it working.
        • D
          didier9
          I had weird problems like this with an M5Stamp-PICO until I put more capacitance across the bus (5V and 3.3V). I used a couple of tantalum capacitors I had on hand, not sure the value, probably 33uF. I was powering the device through the USB serial adapter and apparently it was power limited.
          I have had no problem whatsoever since then.
          www.ko4bb.com
            Mackone @ajb2k3
            Same thing is happening to me:
            Start Burn
            --chip esp32 --port /dev/tty.usbmodem53190095701 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x1000 /Applications/M5Burner.app/Contents/Resources/packages/fw/core/Core2_Tools-v1.0.0.bin
            esptool.py v2.5.0
            Serial port /dev/tty.usbmodem53190095701
            Connecting...
            Chip is ESP32D0WDQ6 (revision 1)
            Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse
            MAC: 08:3a:f2:66:b7:70
            Uploading stub...
            A fatal error occurred: Failed to write to target RAM (result was 01070000)
            Burn Failed
            Fighting for over 10 hours.. I'm dying here..
              Mackone @darul75
              @darul75
              Same here - Have You found any solution?
              • E
                erich
                This was a known issue with Big Sur (something related to the python and / or serial port implementation in Big Sur.
                I did contact M5Stack support but no solution has ever been found.
                I gave up and reverted back to Catalina and it worked fine again.
                Now I just installed the latest Monterey but haven't tested the Core2 yet.
                In the meantime I was also using a windows computer....
                  Mackone @erich
                  @erich I'm on Mojave 10.14 and problem still exists :/
                    I’m actually getting it with Catalina
                      slugs
                      Has anyone managed to get the core 2 to work with an M1 mac? I think that you do not need the driver for the m1? With a m5stick C it works fine, but not with the core 2
                      • ExieE
                        Exie
                        I have the same issue when I use the M5Stack ESP32 Downloader.
                        However when I use a simple M5Stack Atom Matrix, its works fine.
                        I am on OSX Big Sir.
                        I feel like the issue is related to the CH9102 chip on the ESP32 Downloader where the Atom has the CP2104 I think.
                        This theory is supported by this article here:
                        https://blog.squix.org/2021/08/ch9102-driver-issues-failed-to-write-to-target-ram.html
                        Confirmed, installing the driver from this thread here worked for me
                        https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139
                        • E
                          erich @Exie
                          @exie said in new m5stack: Failed to write to target RAM (result was 01070000):
                          I guess you're right as I noticed on banggood/ aliexpress some products using this CH9102 chip are tagged as not Mac compatible.
                          • L
                            labixiaoxin8888 @Mackone
                            @mackone try connecting the downloader's 3V3 to Stamp Pico's 5V
                            • P
                              parahooner
                              I found a solution that works on Montery :-)
                              Make sure you follow the PDF instructions, this works M1 Mac M5 Epaper
                              http://www.wch.cn/downloads/CH34XSER_MAC_ZIP.html
                              B 1 Reply Last reply Reply Quote 2
                              • B
                                Bludotz @parahooner
                                @parahooner Very many thanks for posting this, it completely resolved the problem.
                                • drjakobD
                                  drjakob
                                  I still have the same problem with 5 new M5Fire on Big Sur. Two older ones burned succesful.
                                    ajb2k3 @drjakob
                                    @drjakob Check which USB driver is in the new cores as the driver chip was changed due to the part shortage.
