    new m5stack: Failed to write to target RAM (result was 01070000)
    22 Posts 13 Posters 72.9k Views 2 Watching
      darul75
      Great thanks, I will try again later, in the meantime I switched to a Windows machine to make it working.
        didier9
        I had weird problems like this with an M5Stamp-PICO until I put more capacitance across the bus (5V and 3.3V). I used a couple of tantalum capacitors I had on hand, not sure the value, probably 33uF. I was powering the device through the USB serial adapter and apparently it was power limited.
        I have had no problem whatsoever since then.
        www.ko4bb.com
          Mackone @ajb2k3
          Same thing is happening to me:
          Start Burn
          --chip esp32 --port /dev/tty.usbmodem53190095701 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x1000 /Applications/M5Burner.app/Contents/Resources/packages/fw/core/Core2_Tools-v1.0.0.bin
          esptool.py v2.5.0
          Serial port /dev/tty.usbmodem53190095701
          Connecting...
          Chip is ESP32D0WDQ6 (revision 1)
          Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse
          MAC: 08:3a:f2:66:b7:70
          Uploading stub...
          A fatal error occurred: Failed to write to target RAM (result was 01070000)
          Burn Failed
          Fighting for over 10 hours.. I'm dying here..
            Mackone @darul75
            @darul75
            Same here - Have You found any solution?
            • E Offline
              erich
              This was a known issue with Big Sur (something related to the python and / or serial port implementation in Big Sur.
              I did contact M5Stack support but no solution has ever been found.
              I gave up and reverted back to Catalina and it worked fine again.
              Now I just installed the latest Monterey but haven't tested the Core2 yet.
              In the meantime I was also using a windows computer....
                Mackone @erich
                @erich I'm on Mojave 10.14 and problem still exists :/
                  I’m actually getting it with Catalina
                    slugs
                    Has anyone managed to get the core 2 to work with an M1 mac? I think that you do not need the driver for the m1? With a m5stick C it works fine, but not with the core 2
                    • ExieE Offline
                      Exie
                      I have the same issue when I use the M5Stack ESP32 Downloader.
                      However when I use a simple M5Stack Atom Matrix, its works fine.
                      I am on OSX Big Sir.
                      I feel like the issue is related to the CH9102 chip on the ESP32 Downloader where the Atom has the CP2104 I think.
                      This theory is supported by this article here:
                      https://blog.squix.org/2021/08/ch9102-driver-issues-failed-to-write-to-target-ram.html
                      Confirmed, installing the driver from this thread here worked for me
                      https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139
                      • E Offline
                        erich @Exie
                        @exie said in new m5stack: Failed to write to target RAM (result was 01070000):
                        I guess you're right as I noticed on banggood/ aliexpress some products using this CH9102 chip are tagged as not Mac compatible.
                        • L Offline
                          labixiaoxin8888 @Mackone
                          @mackone try connecting the downloader's 3V3 to Stamp Pico's 5V
                            parahooner
                            I found a solution that works on Montery :-)
                            Make sure you follow the PDF instructions, this works M1 Mac M5 Epaper
                            http://www.wch.cn/downloads/CH34XSER_MAC_ZIP.html
                            B 1 Reply Last reply Reply Quote 2
                            • B Offline
                              Bludotz @parahooner
                              @parahooner Very many thanks for posting this, it completely resolved the problem.
                              • drjakobD Offline
                                drjakob
                                I still have the same problem with 5 new M5Fire on Big Sur. Two older ones burned succesful.
                                  ajb2k3 @drjakob
                                  @drjakob Check which USB driver is in the new cores as the driver chip was changed due to the part shortage.
