    new m5stack: Failed to write to target RAM (result was 01070000)
    Bug Report
    13
    22
    68.2k
    • ZontexZ
      Zontex
      Hi @erich , could you please send me an email so I could assist you regarding this issue: roni@m5stack.com so I could assist you better?
      • E
        erich @Zontex
        @zontex Thanks a lot! Email sent with the full explanation of the issue
        • D
          darul75
          Hello @Zontex could you advise me also as I got a similar problem
          Start Burn
          --chip esp32 --port /dev/tty.usbmodem51850037101 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x7ff000 /Applications/M5Burner.app/Contents/Resources/packages/fw/other/wifi.bin 0x1000 /Applications/M5Burner.app/Contents/Resources/packages/fw/core/UIFlow_Core2-v1.8.5-core2.bin
          esptool.py v2.5.0
          Serial port /dev/tty.usbmodem51850037101
          Connecting...
          Chip is ESP32D0WDQ6 (revision 1)
          Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse
          MAC: 08......HIDINGIT
          Uploading stub...
          A fatal error occurred: Failed to write to target RAM (result was 01070000)
          Burn Failed
          I guess it is the driver not loading well as I can only see this tty of type modem but I have found no easy way to make it working, I am using the Apple Multi Adaptor (HDMI/USB) on USB C.
          • D
            darul75
            I have installed latest driver https://www.silabs.com/documents/public/software/Mac_OSX_VCP_Driver.zip and can see the corresponding extension in /Library/Extensions with
            drwxr-xr-x@ 3 root wheel 96 Oct 15 10:46 SiLabsUSBDriver.kext
            but then when running M5Burner it only show a tty device of type Bluetooth or usb modem
            ls /dev/tty.*
            /dev/tty.Bluetooth-Incoming-Port
            I am running macOS Catalina
              ajb2k3 @darul75
              @darul75 said in new m5stack: Failed to write to target RAM (result was 01070000):
              ls /dev/tty.*
              /dev/tty.usbmodem51850037101 is the correct device, I'm not sure what's going on in OSX but this is how it appears for me and the device that works for me.
              • D
                darul75
                Great thanks, I will try again later, in the meantime I switched to a Windows machine to make it working.
                • D
                  didier9
                  I had weird problems like this with an M5Stamp-PICO until I put more capacitance across the bus (5V and 3.3V). I used a couple of tantalum capacitors I had on hand, not sure the value, probably 33uF. I was powering the device through the USB serial adapter and apparently it was power limited.
                  I have had no problem whatsoever since then.
                  www.ko4bb.com
                    Mackone @ajb2k3
                    Same thing is happening to me:
                    Start Burn
                    --chip esp32 --port /dev/tty.usbmodem53190095701 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x1000 /Applications/M5Burner.app/Contents/Resources/packages/fw/core/Core2_Tools-v1.0.0.bin
                    esptool.py v2.5.0
                    Serial port /dev/tty.usbmodem53190095701
                    Connecting...
                    MAC: 08:3a:f2:66:b7:70
                    Uploading stub...
                    Burn Failed
                    Fighting for over 10 hours.. I'm dying here..
                      Mackone @darul75
                      @darul75
                      Same here - Have You found any solution?
                      • E
                        erich
                        This was a known issue with Big Sur (something related to the python and / or serial port implementation in Big Sur.
                        I did contact M5Stack support but no solution has ever been found.
                        I gave up and reverted back to Catalina and it worked fine again.
                        Now I just installed the latest Monterey but haven't tested the Core2 yet.
                        In the meantime I was also using a windows computer....
                          Mackone @erich
                          @erich I'm on Mojave 10.14 and problem still exists :/
                            I’m actually getting it with Catalina
                              slugs
                              Has anyone managed to get the core 2 to work with an M1 mac? I think that you do not need the driver for the m1? With a m5stick C it works fine, but not with the core 2
                              • ExieE
                                Exie
                                I have the same issue when I use the M5Stack ESP32 Downloader.
                                However when I use a simple M5Stack Atom Matrix, its works fine.
                                I am on OSX Big Sir.
                                I feel like the issue is related to the CH9102 chip on the ESP32 Downloader where the Atom has the CP2104 I think.
                                This theory is supported by this article here:
                                https://blog.squix.org/2021/08/ch9102-driver-issues-failed-to-write-to-target-ram.html
                                Confirmed, installing the driver from this thread here worked for me
                                https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139
                                • E
                                  erich @Exie
                                  @exie said in new m5stack: Failed to write to target RAM (result was 01070000):
                                  I guess you're right as I noticed on banggood/ aliexpress some products using this CH9102 chip are tagged as not Mac compatible.
                                  • L
                                    labixiaoxin8888 @Mackone
                                    @mackone try connecting the downloader's 3V3 to Stamp Pico's 5V
                                    • P
                                      parahooner
                                      I found a solution that works on Montery :-)
                                      Make sure you follow the PDF instructions, this works M1 Mac M5 Epaper
                                      http://www.wch.cn/downloads/CH34XSER_MAC_ZIP.html
                                      B 1 Reply Last reply Reply Quote 2
                                      • B
                                        Bludotz @parahooner
                                        @parahooner Very many thanks for posting this, it completely resolved the problem.
                                        • drjakobD
                                          drjakob
                                          I still have the same problem with 5 new M5Fire on Big Sur. Two older ones burned succesful.
                                            ajb2k3 @drjakob
                                            @drjakob Check which USB driver is in the new cores as the driver chip was changed due to the part shortage.
