    M5Paper blank display
    13 Posts 4 Posters 20.3k Views
    • ZontexZ Offline
      Zontex
      @powersoft said in M5Paper blank display:
      e upload is okee. I found also when I chanhe the font the output is not working. By the way all examples in the ide ore not working wich are manipulating the canvas.
      Could you please try to burn the factory_test from the m5stack burner and see if the screen can react?
      P 2 Replies Last reply Reply Quote 0
        Powersoft @Zontex
        @zontex
        That's working fine! Tried this several times with succes!
        When compiling the examples I use the board "M5Stack-Fire".
        When I try to run the example "M5EPD_TTF" then it is not workin, blank screen. Have you tried this example found in the example directory?
        The SHT30 example is working fine.
        All thing related to the canvas like fonts, drawing etc gives the problem.
        Do you have could run all example files?
          Powersoft @Zontex
          @zontex
          Have running all demo programs
          Here the results:
          Button: failed
          DISPLAY_URL_JPG: failed
          HELLOWORLD: pass
          M5EPD_TTF: failed
          RTC_BM8563: pass
          SHT30: pass
          TOUCH: failed
          This is very strange!
          • ZontexZ Offline
            Zontex @Powersoft
            @powersoft Will try to re-produce and will let you know the results ASAP.
              Powersoft @Zontex
              @zontex
              I appreciate that
                Powersoft @Powersoft
                @powersoft
                Is there progress on this topic?
                  @powersoft
                  Found the solution. After setting into the preference the right url and loading the m5stack I was able to choose the M5Paper. Examples are running now👍
                  JopJ 1 Reply Last reply Reply Quote 0
                  • JopJ Offline
                    Jop @Powersoft
                    @powersoft
                    I met the same problems with my new M5Paper.
                    Please, can you be a bit more specific with "After setting into the preference the right url..."
                    I my boards I see different M5-products but not the M5Paper. Will this change by your solution?
                    Kind regards,
                    Jop
                    • m5stackM Offline
                      m5stack @Jop
                      @jop after change the board manager URL, did you reinstall the board? (update to the latest version.)
                      check this tutorial:
                      https://docs.m5stack.com/#/en/quick_start/m5paper/quick_start_arduino
                      board manager URL:
                      • JopJ Offline
                        Jop @m5stack
                        @m5stack thnx, I solved this problem - indeed I had to load board definitions
                        Also this YT-video 'M5Paper Seasons Greetings Display' was helpful: https://youtu.be/Tjz4fGRn8fo
                        Kind regards,
                        Jop
